Question about Broksonic CTGV-5463TCT TV
Trying to get my TV set setup for Direct TV
My TV set was somehow changed and now I cannot reset my TV to pick up Direct TV. Can you help walk me through this
    Sergeant:
  • 239 Answers
Http://www.youtube.com/watch?v=6QTOiCgHQfU
Posted on Mar 19, 2014
Sony KV-36FV26- no remote control. trying to reset to factory settings. Any ideas?
There is no other way to select factory setting, without its remote control.
Apr 04, 2013 | Sony KV-20S20 20" TV
Reset All Settings *Back to factory*
Unplugs everythings like all those cables boxes and the tv also,replugs the tv and those cable boxes,like Time Warner,Telecoms companies Veizon,AT&T,Dish Network,Direct tv boxes about an hour later.Let those boxes updates it softwares.Go in ur tv menu.Go to the menu selection PICTURE,go down select reset.That should reset the incomming broast Tuner board in the tv.Go to tv menu AUDIO,go down to reset.That should reset the audio setting.Now all those boxes have it updates softwares,and the tv reset it back to the factory setting.Now go to tv menu,go to SETUP,go down to CH. setup pick CABLE not AIR.Now the tv will go into scan modes to pick all those cable channels incomming broscast that ur pay for.
Jun 02, 2010 | JVC HD-52G786 52" Rear Projection HDTV
Word Component1 shows up when changing local channels
Your Direct TV box is switching between a Standard Definition channel and a High Definition channel. When this happens, the TV has to switch the display format. As the format is changing, you will briefly loss picture, the TV detects the new format, and then displays it. What you are seeing is the normal operation of the TV. It the TV did not blank the picture, you would see a broken chopped up picture during the transition. If you are familiar with the setup menu of the Direct TV box, you could change the video format settings so than it locks to the High Definition format. If you are not familiar with the Setup menu, you should contact Direct TV and ask then to walk you though this procedure. Specifically, ask them to "Help me set my Direct TV box so that it always displays in 1080i format." You pay for them for the service, they should be able to provide you with some phone support at no charge. I hope this was helpful, best wishes.
Apr 24, 2010 | Philips Magnavox 51MP392H Rear Projection...
How do i enable the closed caption on my samsung tv/direct tv?
Correct solution WITH DIRECT TV is NOT going to SETUP MENU on your Samsung TV and enabling it, this won't work with Direct TV!! I'll walk you through it. Grab your Direct TV remote, hit "Menu", pan down to "Parental, Fav & Setup", next click "System Set-up", next click "Display", now at the top of the screen between "Preferences" and "Clock" is "Captioning", click on it, now the first box reads Captioning TURN IT FROM OFF TO ON! You now have Captioning.
Aug 05, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
How to get the dell 4200 ed to pick up digital channels
there are 2 coaxial inputs on the back of your tv. plug the antenna into the digital coax. with your remote, do a fac reset: menu, setup, fac reset, all settings, passcode 3355. after the reset, hit input, select digital tv. perfprm a chan scan: menu, setup, channel scan, antenna. this should solve the problem.
Feb 09, 2009 | Dell W4200 42 in. HD-Ready Plasma...
Change to channel 3 rather than 2 on Zenith 27" withot a remote
You can use the menu button on the front to autoprogram the unit. Make sure the direct tv is on so the tuner will pick it up. After that, you can program the direct tv remote to operate the tv. The reason the channels won't change is there are none in the memory
Dec 19, 2008 | Zenith C27A24T 27" TV
Panasonic 42 inch HD Plasma TV (2 years old) remote sensor
take your tv and remote to a technician to check on your emitting diode and a photo senser, both are working but not very sensitive. the components are not gone but about to go. if you remove a senser from tv it can not receive, so that senser is sensing some thing, also check an amplifier just after a senser plse do that.
Nov 16, 2008 | Panasonic TH-42XVS30U 42 in. Plasma HDTV
Tivo won't change my TV Channels anymore with direct cable
I re-did the guided setup in the Tivo under Messages & Settings/Restart-Reset System/Restart menu section in Tivo. Once I did that, it cleared this issue, even though I didn't have to change any of my settings thru this guided setup. I tried a reset alone first, but that did not fix it. Only this fixed it. We had lost both power and cable during a recent tree fall in a storm, and when both were restored, this problem started. I have a cable coax directly in the back of the TV (no cable box/IR etc) and the system is on a home wireless network. I actually have 2 identical Tivo's in the house set up the same way but only one had this problem. The other worked no different after the outage.
Oct 12, 2008 | Tivo Series 2 80-Hours Video Recorder
Direct TV Hookup
please help my remote has change language and jumping chanel and pause on mute
Sep 03, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Ps3 defaults to 576p when connected through onkyo 606 receiver
You have to tell the PS3 what the Okyo can do and it probably cannot do 1080P 60Hz (but can likely do 1080P 24Hz).  Try ticking more resolutions in the PS3s setup
Jun 22, 2008 | Audio Players & Recorders
Broksonic CTGV-5463TCT TV Logo
52 people viewed this question
Top Broksonic Televison & Video Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Broksonic Televison and Video Expert? Answer questions, earn points and help others
