Question about Singer Futura Xl-400 All-In-One Sewing And Embroidery Machine
Needles break when embroidery carraige moves to sew new area
Im tuned in now to the point where i am getting great looking designs and lettering, however for example if i am doing a monogram.... and it finishes the first letter, moves to the second letter, the first time the needle goes down it apparently strikes the plate and breaks. can i turn the tension lower than "E" while embroidering? I have a sneaky feeling that might be the problem.
    Problem Solver:
  • 11 Answers
My needles break occasionally- either due to wrong needle for fabric type, or density of the embroidered design or Machine set at speed to fast for the design as each design have their own techniques when designing files. or thread tension, which is where a thread stand comes in handy
Posted on Mar 26, 2014
    Habit-Forming:
  • 45 Answers
Check your needle for burrs or bends. If your needle is bent it will hit the plate. Try changing the needle
Posted on Mar 19, 2014
5 Suggested Answers
SOURCE: needle breaking-CE 250
I had that same problem and it was due to the thread being too tight. Put the thread net on your thread and it should be ok.
Posted on Dec 25, 2007
  • 23 Answers
SOURCE: Needle keeps catching the embroidery foot and breaking
Happened to me to All I did was to press the embroidary foot a little backwards and check if the little arm that rest on the shaft that goes up and down is seating correclty.
Posted on Mar 31, 2009
  • 5 Answers
SOURCE: The needle constantly breaks while embroidering.
My foot does this with different thickness of fabrics, it will make the foot land in different, areas, sometimes making the needle hit the foot. Always check needle position before you start embroidering. once your hoop is ready, check the clearance. I often have to use a small roll of non slip material under the foot handle, the one used to bring the foot down. And I use this to adjust the needle postition so it will always land in the middle of the embroidery foot. There is also a way to adjust the height of the needle arm but that's too complicated to get into here and I've never personally tried it.
Posted on Oct 20, 2009
SOURCE: needle breaks during embroidering--also lettering is incorrectly spaced and some letters are wrong
Sounds like your embroidery foot isn't on properly. I have had this exact same problem and have had many needles break... it's because I didn't have the foot on nice and straight, even though it seemed like it. Try taking it off and putting it back on - you may have to do it several times, but once it's on properly, the needle should be dead-center of the little metal loop of the embroidery foot. If it's off, even a bit, the needle will break. Hope that helps. Remember -- patience, patience, patience!!!
Posted on Dec 05, 2009
What is the needle size for brothe 911 sewing machine
Be sure to change the needle frequently, ie every time you start a new project. Needles will cause a great deal of frustration yet are the least expensive item to fix.
Perhaps this will help:
All About Needles
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&ved=0ahUKEwia3-aY5LrQAhUHqVQKHUgcC5UQjBAIJDAB&url=http%3A%2F%2Fwww.schmetzneedles.com%2Fneedle-guide%2F&usg=AFQjCNG5DmrsyBAUhhGLeiVfmc4jHpjYsQ
Nov 21, 2016 | Sewing Machines
Elba 8600 st/no how to reset it?
Reload the design you are trying to sew. Needle breaks can trigger circuit protection and affect the design being sewn from being saved in machine's memory properly..
Cheers,
Embroidery Services
San Diego, CA
Jul 03, 2016 | Elna Xplore 8600 Computerized Sewing...
Embroidery problem
Hai, 1.You should thick and white or blank cover run a letters embroiderys. 2. After don't remove the frame. 3. Put on the embroidery cloth. 4.Marking. 5.Frame setting with smooth needles. 6.Put the frame. 7.Trace the machine after running and finshed the design.
Mar 23, 2014 | Brother SE400 Computerized Sewing and...
I bought the SINGER FUTURA XL400 in august. It sews,monograms an embroiders. Sews like a dream with no issues. The monogramming part has me at my wits end. It skips stiches, leaves big loops an looks bad...
Be sure to install a brand new sharp needle before sewing. Check that the needle, thread, and fabric are compatible. An embroidery needle or top stitch needle may help.
When threading the top thread, ALWAYS RAISE the presser foot before threading to insure the thread seats in the tension disk.
Apr 08, 2017 | Singer Futura Xl-400 All-In-One Sewing And...
Brother Sewing Embroidery Machine
I agree with sylviaivie about find another repairman, they are suppose
to guarantee the work they do.
when the upper shaft is replaced & then the machine is retimed
the machine should work just fine.
but just don't take it back to that man to be repaired
here is a tip if it happens again,,
always try to cut the top thread first,
& turn the machine up on it's back to access the bottom cover
take the cover off the bottom to get access to the bobbin thread
where you can cut the bobbin thread
then you should be able to get the needle out without breaking it &
damaging the upper shaft, replace the needle & make sure
that the thread is good quality & not knotty, clean out the bobbin area of lint or thread
always change the needle on the embroidery machine every project
make sure the bobbin area is kept clean of lint or thread
clean under the needle plate at least once a week for lint if you
embroidery everyday or just often
Aug 01, 2012 | Brother Sewing Machines
Husqvarna Rose Embroidery Unit problem
Call Viking direct
440-808-6550
800-358-0001
Aug 20, 2009 | Husqvarna Rose
Husqvarna Viking Designer 1 keeps breaking needles
The threading may be out of the channels. Rethread. Put in a fresh needle. Make sure you are using an embroidery needle and a new one for each new project. You can't use YLI bobbin thread. It stinks. If all this doesn't help, take it in to be checked These work great when there is not thread stuck in the bobbin case and it is threaded properly. If all is well, it will go like gangbusters.
May 21, 2009 | Husqvarna Designer I
Pfaff creative half-speed and thread breaks
YIKES - what a nightmare! We can approach your problem two ways, but to determine whether the problem is your machine or your design, I need to know if you have been using one design, or if you've tried to embroidery several different designs and are getting threadbreaks about every 10,000 stitches, no matter what design, needle, thread, and bobbin you use.
Here are some rules you should following whenever you embroider on your machine:
  • Change your needle and insert a newly wound bobbin every time you start a new project
  • Use a size Embroidery Needle - size 90 for most projects
  • Check the backside of your design - you should see alot more bobbin thread than embroidery thread. If you don't see enough bobbin thread, loosen your top tension. If the tension is set automatically, change it manually.
  • Your design might be the problem. Some designs have WAY to many stitches. If you haven't already, choose several different designs with different styles - for example, a monogram, a design that is mostly satin stitches, a design that is mostly straight stitches, and so on. Sew one or all over and over so you determine whether your thread will continue to break about every 10,000 stitches.
I hope this helps. Machine embroidery is so much fun once you've learned and practiced. I hope to hear from you - machine embroidery is not hard to learn, but there is a lot to learn. Thanks.
If you want to get right to work, skip the troubleshooting and answer as many questions as you can or have time for. It is possible that your problem is the design and not the machine. Try one suggestion at time so you what helps and what doesn't. Questions first:
  1. Is the machine brand new, or new to you?
  2. Do you have your manual?
  3. Do you been embroidering by machine for a while, or are you just learning?
  4. Does this problem occur with every design you sew, or is it one particular design that you are having trouble with?
  5. How many total stitches are in the design you are trying ot sew?
  6. What kind of thread are you using (rayon, poly, sewing?)
  7. Did you buy the machine from a dealer, and if so, does it have a warranty?
  8. Have you taken lessons on how to use your machine for both sewing and embroidery?
  9. Are you familiar with embroidery backings, needles, and threads and how to choose which to use for a particular project?
Feb 01, 2009 | PfaFF Creative 7570
Singer Futura Xl-400 All-In-One Sewing And Embroidery Machine Logo
132 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
