Question about Maytag Neptune MCE8000AY Electric Dryer
Need a shaker bar assembly where can i get one
The shaker bar has quit working
  • 33 Answers
Replaced SD card now Shaker won't play
Hi Cathi!
Few things you need to know about Sansa Shaker and the SD card:
  1. The Sansa Shaker DOES NOT support SDHC memory cards. Only regular SD cards are supported.
  2. Maximum capacity for supported SD cards - 2GB!
  3. Any SD card which doesn't meet the requirement above might cause the problem you encounter. REPLACE the card with a supported one - SD card with up to 2GB in capacity.
  4. No software/data is stored or needed to be on the memory card - apart from your music files.
  5. MP3 file type is fully supported by Sansa Shaker.
Regards,
Pelu.
Apr 10, 2010 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
Control the volume on each of the 12 bass shakers i plan to install
Please note that you can't simply wire them together in series or parallel. Connecting any more than 2 would likely cause damage to your amplifier. (depending on the impedance of the bass shaker 4 ohms, 8 ohms, etc.)
The Buttkicker brand recommends the following configuration for four buttkickers into one amp: Click here
As you can see, you need a combination of parallel and series connections to make sure the amp is "seeing" the correct load. I'd recommend purchasing three dedicated subwoofer amps (there are some good inexpensive ones at http://www.parts-express.com.
This will give you volume control over each set of four shakers at the amp itself. If you need control at each shaker, the only solution I know if is to use an impedance matching volume control.
Check Parts Express for those, too.
If this solved your problem, please rate it as FixYa. If not, let me know how else I can help you.
Apr 21, 2009 | Audio Players & Recorders
My shaker does not play all of the loaded songs.
I had the same problem. The songs that won't play are probably MP4 files and the shaker only plays MP3 files. You need to change the file format of the songs on the shaker to MP3 files. I downloaded "Media Coder" which was free and it converted all the songs on the shaker that wouldn't play to MP3 files and they play now. Google "Media Coder" and download the free program, it is very easy to use. I had the songs converted in about 2 minutes. Make sure the shaker is plugged into computer so that you can choose the files on the shaker to convert. Hope this helps.
Dec 23, 2008 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
A problem with my sansa shaker
Hi again audreytagle. Please take your slip and take your sansa to the place you bought it and show them the problem they will probably give you a new one. before you do that try inserting new batteries into the sansa shaker and see if the product works. if not use the above mentioned solution.
Jul 30, 2008 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
Sansa Shaker stopped working
Hello there. i hope i am not too late with my solution. The sansa shaker has acted like yours is some numerous times but the solution can be as simple as ever. Try replacing the battery with a brand new one. However if this solution does not work simply take it back to the place you bought it with the slip and tell them your problem... they will probably give you a new one.
Jul 28, 2008 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
Why???
Well maybe you got a corrupted file on it. Scan your files with your anti virus software. If that isn't the case then change the batteries (AAA). If none of these solutions work then go to some technical support and ask if they can open it. Mine is having headphone problems so these things have problems quite oftenly.
Dec 08, 2007 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
Sansa shaker
SHAKER ONLY TAKES MP3 FORMAT!!!!!
Use this site to change your format to the correct one for the sansa shaker. This is the only way to load songs from your cds MWA will not work at all. Must convert all files to MWA use site below
http://www.wma-mp3.org/
Nov 17, 2007 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
Sansa shaer
Nov 15, 2007 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
"uh oh"
The music has to be in MP3 format.
If you have copied CD's to your computer, you will need to change the settings in Windows Media Player to copy them as MP3's.
Windows Media Player>Tools>Settings>Rip Music (Copy Music)>Chane Rip Music as to MP3.
Delete all the songs you copied before from your computer and from the Shaker.
Copy the new songs back to the Shaker after you change the settings.
Best of Luck.
Oct 16, 2007 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
Maytag Neptune MCE8000AY Electric Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
