Question about Ricoh KR-30SP 35mm SLR Camera
Can't see image through lens
I loaded my film and clicked on shutter release button, and advanced it until 1 appeared in the exposure counter. When I turn it on I cannot see an image through the lens, only black and the indications in the viewfinder. I have not use a 35 mm camera in a while. Can you help me figure out, what I have missed? Thanks!
  • Jessica Kaiser
    Jessica Kaiser Mar 20, 2014
    Thank you for the excellent work you did on finding a solution. After following your guidance and checking the AE Lock, I also decided to unhook the lens, and check it. After doing so, and attaching it back to the camera the viewfinder was clear. Many thanks again!! Arigato gozaimasu!!
  • 20 Answers
It would seem that the mirror is locked up. Some cameras have a mirror lock to reduce vibration after the view is focused and ready to expose. Check your camera features. If it doesn't have this feature than the camera may need servicing.
Posted on Mar 20, 2014
SOURCE: XR 7 locked up
Just read on another forum where the film rewind button can get stuck (little button on the bottom of the camera, used to initiate rewind), and removing the camera bottom allows access to unjam it.  I'll try... takes a small philips eyeglass screwdriver and young eyes (or my reading glasses...)
Posted on Sep 18, 2008
SOURCE: Ricoh KR-5 SUPER II Shutter will not activate.
I doubt you still need help with this considering it's over 8 months later... but the same thing has been happening to me lately, I've had to force the self timer to start by giving it a little push, once it gets going it starts to work normally again.
Posted on Oct 01, 2008
  • 185 Answers
SOURCE: The film won't advance
Look on the shutter release button, there is a lock switch on bottom of the button. turn it toward the prism.
Posted on Dec 07, 2008
SOURCE: mirror is stuck in "up" position and film will not advance
Normally, stuck mirror is due to weak batteries with a elcetromagnetic shutter like the Ricoh. Try with brand new silver oxides and see if it helps!
Posted on May 28, 2009
  • 185 Answers
SOURCE: I am unable to view through the viewfinder. I have
is the mirror stuck in the up position? if so the rubber bumpers have become sticky. try to ( gently ) pull the mirror down it should fall freely, then clean the mirror with alcohol. you may have to remove the foam rubber bumper to prevent the mirror from sticking again. the mirror mechanism will work without the bumper just fine.
Posted on Aug 02, 2009
I purchased a Nikon N60 used. The film will not automatcally load therefore not shoot
Please follow these instructions: 1. Open the camera back 2. Pull the film leader across the red film index mark (red line) 3. Check to ensure film is properly positioned with no slack, then close camera back 4. Fully depress shutter release button to advance to frame 1. Check the rewind lever if it turns counter clockwise when you depress the shutter release button.
Keep on trying this procedure until you get it right. Most of the time, the error is in not pulling the film leader enough to reach the red film index mark.
If you're still having a problem with this, the next best option is to have the camera checked by a competent camera technician.
Mar 25, 2011 | Nikon N60 35mm SLR Camera
Just recieived a used Nikon N80 and it gives the message of open door.Frame counter and film indicator flashes when door is shut and no film is in in camera?
Confirm tht DX shows in LCD. If not then press and hold shift button then press ISO so "DX" appears.Open Camera Back. Insert film cartridge, pull film leader out to right and align with red index mark (inside film chamber on right). Make sure there is no slack in leader.Close camera back until lock release snaps closed. Fully depress shutter until film advances to first frame.
Confirm " 1" and film transport show in LCD. If Film is not loaded correctly, "ERR" show on LCD. Open cack and reload film.
Users manual can be downloaded from:
http://www.lensinc.net/manuals/Nikon_N6006L.pdf
Nov 03, 2010 | Nikon N80 35mm SLR Camera
Can't roll film for double exposure.
After taking the first shot, hold down the Multi-Exposure button while cocking the film-advance lever. This cocks the shutter without winding the film. You can continue to do this for as many exposures as you want. Just don't hold down the M-E button while cocking after the last exposure.
The Multi-Exposure button is the button on the front of the camera just below the shutter release button.
Apr 11, 2010 | Vivitar V3800N 35mm SLR Camera
My Pentax SPII shoots blank images
You can check the shutter without film in the camera. Remove the lens and open the film door. You will see the cloth curtains of the shutter in the center. Advance the film lever to **** the shutter and set the speed dial to a slower speed like 1/15. Hold the camera so it is aimed a a light source, (a window will do) and fire the shutter. You should see the light through the shutter for the time duration is is set to. (1/15). If you see the light source, repeat the process going up one speed setting until you reach 1/1000. If you see the shutter open and close as described, then try another roll. After you load the film and close the back door, make note of what the rewind knob is doing as you advance the film. It should spin counter-clockwise each time. That is a easy test to know that the film is traveling in the camera properly. Vary your exposures with the new roll at different speeds and f-stops. You should get exposures, but if not let us know.
Jan 31, 2010 | Olympus Stylus 850SW Digital Camera
My Mamiya RB67 triggers and shutter lease lever works but film advance lever doesn't move. Trigger button fired several times but film advance still showing 1.
This is not the best solution as it indicates a faulty film back. The film should advance without resorting to activating the film-wind release lever. That is only for intentionally advancing a partially exposed roll of film. Make sure the multi-exposure lever is not engaged and that the counter does advance and the red mark disappears as you advance to an unexposed frame.
Nov 09, 2009 | Mamiya RB67 Pro SD Medium Format Camera
How do you take a double picture
In much the same way as with any other 35mm SLR:-
1. Turn the rewind crank gently to take up any slack in the film.
2. Take your first photo. The 3800N has a special lens mask to help this process by blanking out one half or one quarter of the image, on other cameras a thin card mask over the lens achieves the same effect.
3. Hold the camera so that your thumb or finger is firmly on top of the rewind knob to stop it turning, whilst doing this press the rewind button on the base of the camera and then operate the film advance lever. By holding the rewind knob and pressing the rewind button, you allow the shutter to c0ck without advancing the film.
4. Turn the lens mask to cover the portion of the image which was just exposed.
5. Press the shutter using the same exposure value (EV) as previously used. Usually you'll use the same shutter speed and aperture, but by varying them and maintaining the same EV you can get some interesting effects.
6. If you're exposing more than two exposures on one frame then repeat as often as required.
7. Note that this is and always has been a bodge: the film frame often moves slightly between exposures except on a few specific SLRs which had a special multiple exposure setting. The V3800N is advertised as a multi exposure model but has no specific control for it, just the plastic lens mask.
Jul 25, 2009 | Vivitar V3800N 35mm SLR Camera
Mamiya RZ 67 lens is stuck on body
This is likely because the shutter has not been cocked all the way. Return the lens to the fully locked position and advance the film with the lever all the way down to reset the shutter. If it still doesn't work, move the lever to M for multiple exposure, make sure the back is aligned and trip the shutter release. Then fully **** the shutter again by pressing the advance lever down fully and again until it is reset. Then try to remove the lens again.
Dec 15, 2008 | Mamiya RZ67 ProII Medium Format Camera
Film advance lever wont move. Shutter button does not register.
the self timer may be the issue. the self timer if not all the way released will not allow you to advance to the next frame :( i sometimes have to push it back to the start position
Nov 13, 2008 | Photography
Taking photos
jeep111
be sure batteries are good. pull up on the rewind knob to open film door. load film ,push down rewind knob. pull enough film to connect to take-up spool. close film door. advance film to counter # 1. look through finder and set meter ( push shutter button to turn on meter ) focus subject and fire shutter repeat to end of film. push rewind button ( bottom of camera ) rewind film.
remove lens by pushing button and turn lens left to remove.
Apr 28, 2008 | Vivitar V3800N 35mm SLR Camera
Film won't advance
Perhaps you've already solved the mystery. There are 2 parts to the back of that camera, the film back + the part that it slips onto. And they have little safety latches/pins that couple in order to advance the film & release the shutter. I'm sure those just aren't in the right place. Here in Los Angeles you could take it to any major camera store or repair shop & they've help you out.
Mar 06, 2007 | Mamiya RB67 Pro SD Medium Format Camera
Ricoh KR-30SP 35mm SLR Camera Logo
78 people viewed this question
Top Ricoh Photography Experts
Lyle Siemens
Lyle Siemens
M_Butkus
Are you a Ricoh Photography Expert? Answer questions, earn points and help others
