Question about Keurig Caf One-Touch Milk Frother
Whisk broken seeking replacement whisk
Why can't I remove the whisk attachment?
forgot to push up before turning possibly
Mar 21, 2016 | Cuisinart SM-55 Stand Mixer
Kitchenaid whisk will no longer slip past the locking pin to rotate and attach on the spindle.
this might help... the whisk has a slightly larger whole then the other attachments. it is also inset. there is a washer that holds the spring on. if that is slightly off or bent it won't sit in the Whisks inset right. look a little closer to that and the spring. if there happened to be dried on food that could be the slight difference that can prevent it from staying one. Hope this helps!!!
25298509-2el2bftwapqh2uesegcwr3xp-2-0.jpg 25298509-2el2bftwapqh2uesegcwr3xp-2-1.jpg
Nov 27, 2014 | KitchenAid Professional 620 6-quart...
What are the parts of the central ''spinner'' of a milk frother?
There are no moving parts in the frother other than the whisk assembly. The whisk assembly is spun magnetically. I am not sure if it is possible to have the magnet in the whisk assembly in the wrong orientation, but if so, be sure that it is reassembled with the magnet side down. Additionally, if I haven't removed the whisk in a while (I normally just immediately rinse and wipe the interior with a cloth) then the metal stem can build up with milk solids... and cause the whish to "stick"... the magnetic force is not exceptionally strong and it could be that the plastic assembly is "sticking" on the metal post... pull off the whisk and give the post a good wiping with a wet cloth to remove any possible residue.
Jul 24, 2014 | Nespresso Aeroccino Automatic Milk Frother
I have a kenwood gourmet fp505 - how do I use the whisk attachments? Also where can I get a manual for this product?
I was wondering too how to assemble the Whisk, saw your post, searched again for the manual and happily found it buried in a drawer! Here is a copy of section on the Whisk attachment.
Nov 18, 2010 | Kenwood Food Processors
Lost whisk. how can I get a replacement?
They sell the parts at the Nespresso.com, I also saw the frother for sale on ebay
May 04, 2010 | Nespresso Aeroccino Automatic Milk Frother
Whisk attachment is stuck on mixer.
I took a small crowbar, and put the curved end up inside the whisk, and hammered the other end lightly. After about 20 taps, the peg was lined up with the sideways opening so I could twist it off. When I got it off, it looked like there was either flour inside the part where the whisk attaches, or some light corrosion was going on. Either way, I'm going to put a little grease in there so it doesn't happen again.
Mar 09, 2010 | Food Mixers
Parts for mixer whisks
need beaters for blck & decker mx230 hand mixer
Aug 16, 2008 | K-Tec Food Mixers
Keurig Caf One-Touch Milk Frother Logo
15 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
