Question about 2000 Chevy S10 Pickup - Fits the S-10 with a V6 Engine - Cat-Back Exhaust System
Does a 00 s10 have a key chip
Need to know if it has a ohm chip
  • Chris s Apr 30, 2014
    You may have a key Fob for security, Or a lock/panic button But as for a so called "Smart Key" a key that only comunicates with your specific Truck, I don't think so. If you call your local dealer, they will ask you for your vin, they will actually deliver a "Cut" key directly to you ready to go.
    Sergeant:
  • 327 Answers
Best way to find out is to take it to your local keymaker and ask for a replacement key. If they say dealer only, you can bet it has the chip. And that is why my newest vehicle is a 1992.
Posted on Apr 11, 2014
I have a 95 trans am the key was lost how can I find witch key that I am going to need I know there is 15 of them
No way to know what you need without the old key, you measure the ohms of the embedded resistance chip in the key to figure what switch you need. You can bypass the system by following the instrtuctions at the link below. How To Permanently Disable GM PassLock System
Apr 20, 2017 | Cars & Trucks
Have a 2004 Alero 3.4 liter I need to know what the ohms would be between my key
You can not check the ohms of the key on this. If you have dug the chip out of the key.. Get a new key and do a relearn on the system. Turn it on for ten minutes, off for thirty seconds. 3 times. Try to start the car. If it doesn't start. Have the codes read for security.
Nov 05, 2016 | Cars & Trucks
I have lost my chipped key but have an unchipped spare is there anyway to bypass the chip to use the key I have
Nope... You would have to know the resistance of the original chip and then tap a resistor of the same ohms into the security system to by-pass it
Jul 12, 2015 | Cars & Trucks
Ford focus -00 Key fob problem
did you buy the car used. I had a 00 ford focus. and to make it cheaper to install a security system I took the chip out of the orginal key and placed it inside (where the key goes.) the only reason I am mentioning this is because the person I sold it to just got rid of it. Now its a one and a million shot but hey you never know. lol Is it black?
Dec 02, 2013 | Ford Cars & Trucks
I have a 92 Oldsmobile Toronado that was recently broken into and my igniton was broke. And now I can't start it. I can put the key in it and turn like usual but the information center is saying starting...
I believe that your key has a resistor chip. You will need to find the resistance of your chip. Once found, go to an electronics store and buy a resistor with the same value. Follow the two wires that go from the ign switch down the steering column , into a 2 wire plug into the ign module. Unplug the connector. Plug the resistor to the module. The module will read this value and allow you to start the car.
Nov 24, 2013 | Cars & Trucks
I think i have a problem with the chip on the ignition key but not to sure
hi, if you have access to an ohm meter, or volt/ohm meter, you can test the resistance value of the key chip by holding each of the test leads to the little metal part in the middle of the black chip. one lead per side, there are many different resistance values, but they all should be a low amount of ohms like 4.4 ohms or 7.1 ohms. if you get no continuity, or open loop, this is a bad resistor chip. but in order to be exact in testing, take the key down to the dealership of which the vehicle is manufactured by, and speak with the parts department, they can look up the exact resistance value the key is supposed to be and you can check at this time to make sure it is correct.
Jun 25, 2010 | Cars & Trucks
The key to the ignition with the chip need to be replace but how and where do i go to get a new key and can the old key be reprogram?
Don't go to the dealer, cause they are way expensive.  Call a couple of local locksmith shops to find the cheapest price.  Also, look on e-bay for the key and chip to save money and then all you gotta do is pay for the labor to have the locksmith program the thing for you.
Nov 23, 2009 | 1997 Pontiac Bonneville
Oscillator out. No radio and clock is locked up
could be a 555 ic. 555 is the widest used timer ic or "clock" chip. you will need to check the gates of this ic.
May 06, 2009 | Car Audio & Video
Sony Xplod-XM-554ZR-- - - Resistor on circuit board HELP!!!
R466 is chip resistor 220 Ohms 1/8 watt connecting between Emitter pins of Q408 and Q409.
Its part number is ...
R466 "1-216-182-00" RES-CHIP 220 5% 1/8W
Available in Part Store.
Let me know if you need further info.
Apr 02, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Replaced multiswitch in 2000 chevy s10 blazer and now the car won
at the base of the steering column there a orange and white wires these two wires come from the ing switch, you will see the connector that they go to disconnect that take a ohm meter, take the leads one lead to one wire the other lead to the other there should be res, if there is not, try a different setting . take your ing key on the the key you will see a chip take two leads from your meter and either side of the chip place the leads you will see a res reading, you should see the same at the orange and white wires . if you do not replace the ing switch the switch will come with these wires. replacing the switch takes a couple specail tools good luck and let me know how it gose
Dec 22, 2008 | 2000 Chevrolet Blazer
2000 Chevy S10 Pickup - Fits the S-10 with a V6 Engine - Cat-Back Exhaust System Logo
65 people viewed this question
Top Heartthrob Exhaust Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Heartthrob Exhaust Vehicle Part and Accessory Expert? Answer questions, earn points and help others
