Question about Whirlpool Refrigerators
Fan working,engine does not start
Engine trys to start but does not kick in
    Problem Solver:
  • 7 Answers
You will most likely need to replace the start device on the compressor (engine). If that doesn't work you will need to have the compressor replaced by a qualified professional
Posted on Mar 20, 2014
My truck wont start, sounds like it wants too, trys to, but wont kick all the way over. Radio, lights all work
First step is to make sure there is at least 55 psi coming form the fuel pump. Without the correct fuel pressure, the truck's engine will only sputter because there is not enough pressure to open the injectors.
Mar 04, 2015 | 2000 GMC Sierra
Its been working great and now for the last two days it works fine the compresser kicks on but when it kicks off and trys to come back on it pops the electric breaker. its been working fine on the same...
Whether its a central air unit or a wall unit, make sure the condensor is clean and air can flow thru it
make sure the condensor fan is running, the condensor fan keeps the compressor from over heating
if the condensor fan stops running the compressor will over heat and trip the circuit breaker. good luck!
Aug 05, 2011 | Heating & Cooling
Hard starting at times when hot excessive cranking engine will kick back the next time it will start perfect
This happens when the engine trys to fire on the first "upstroke' of the pistons before those big flywheels get to spinning. This is common on stock ignition systems as far as I know. Harley may have changed the systems and I might not know about it but I doubt it. Some aftermarket systems, such as the Crane HI-4 have a spark delay system. The plugs will not fire until the engine has turned over three times. This gets those flywheels spinning and eliminates the start up kick back.
good luck
Steve
Oct 11, 2010 | 2005 Harley Davidson FLHTC - FLHTCI...
Fan doesn't run while in idle and begins to over heat until I start driving agin then it cools back down to normal. Also the fan runs when engine is off and drains the battery.
The fan is only supposed to come on when there is excess heat .. in normal driving conditions it doesn't start. When you start your car in the morning the fan won't come on because the engine is cold.
With a hot engine - and it depends how hot the engine is - the fan will only kick in to prevent overheating. In heavy slow moving traffic or a traffic jam, the fan will kick in if needed.
The air flow through the radiator is usually sufficient -in normal driving conditions - to cool the engine.
When you park up and the car has a hot engine, the fan will kick in. This is perfectly normal. It is caused by a surge of hot coolant triggering the fan sensor. Perfectly normal.
The fan then should cut out after a while .. maybe 2-3 minutes at the most. If the fan runs continuously that suggests a fault in the temperature sensor switch.
Next time - wait by the car and see how long it takes for the fan to quit after you have parked up. It should stop of its own accord after a couple of minutes.
If the fan cuts off after a short while, and your battery is becoming drained, that's probably a battery or alternator fault.
Remember: when you start the car the fan won't kick in at idle speed because the engine is COLD, and there is no reason for the fan to start up ..
The fan WILL kick in for a couple of minutes after you have parked the vehicle and the engine is hot
Aug 14, 2010 | 1999 Jeep Grand Cherokee
Cooling fan don't work even if the temperature raise, what should I check?
First if it is electric fan or Viscous Fan. If the electric, check if fuses are ok, connections fine, and if the motor works. If it is the Viscous Fan, there is not much you can do unless you want it to work permanently. Normally the fan will be moving slowly once the engine starts, than when the inner thermostat gets its temperature it kicks in a fan clutch and than the rotor starts spinning as fast as the engine, it is less effective than electric fans as it will only give you the rpm speed of the engine from 1000rpm to 5000rpm where the electric motors give up to 8000rpm.On the Viscous Fan check if it kicks in if not replace it or get someone who knows what he is doing to permanently lock it so it will turn even when engine is cold. Not recommended in normal climate.
Jun 02, 2010 | 1997 Mercedes-Benz E-Class
I have a ARP-30125 portable A.C. just about 1 yr
try a hard start electronic relay(it has a big capacitor to give it extra kick to start) clean both fins...oil fan motor
Aug 18, 2009 | Heating & Cooling
Fan kicking in too often 1998 f150 4x4 4.6 tow
If the engine is not over heating then it is doing its job. The constant cycling is based on the temp of the air traveling through the radiator and the a/c condenser not the outside temp so much. The start up high rev is just how these clutches work in ford fans. It sounds like it is operating correctly.
Jun 24, 2009 | 1998 Ford F150 Regular Cab
Side by side whirlpool refrigerator with easy water and ice, not
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 17, 2009 | Whirlpool 21.7 cu. ft. Side-by-Side...
Refrigerators Logo
82 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
