Question about Husqvarna Designer I
When trying to put the needle in the far left position an error or fix it pops up
It will sew just can't change the needle position
    Scholar:
  • Husqvarna Expert
  • 104 Answers
I think the needle mechanism is out of adjustment. In the center position, is the needle centered over the hole in the needle plate (check with a plate that has the single hole for straight stiching, not the slotted hole for zig-zag sewing). Take it to a professional for a tune up.
Posted on Apr 14, 2014
5 Suggested Answers
  • 3 Answers
SOURCE: Needle position is too far left
It sounds like you have an alignment problem. You can try to move the needle over with the stitch button and run you machine by hand for the first go. If it jumps back over - you are going to have to take it in to be looked at. Good Luck!
Posted on Nov 19, 2007
shaggyrat
  • 1224 Answers
SOURCE: viking 990s sewing machine
take needle back out hit the reset and this should realign back to center some machines have a 3 needle setup this is also a make sure that needle is positioned in middle
3 needle setup is for the thicker decrative sowing
Posted on May 16, 2008
  • 188 Answers
SOURCE: needle stuck in right position, will only sew tiny,tiny stitches
oil it. down the shaft if you can get to it. and where ever there is a hole it always helps.
Posted on Mar 26, 2009
  • 192 Answers
SOURCE: My Viking 980 sewing machine does not catch far
It could still be either problem. Lowering the needle is kind of like curing a cough by not breathing. You still don't know if you have bronchitis or emphysema, but you will stop coughing.
Is the needle centered in the plate side to side?
Does your zigzag have equal clearance on either side in the plate?
Check timing by lowering needle bar to lowest position and then raise it 2.5mm, push the hook back into the driver and the tip of the hook should center on the needle. (raising the bar 2.5mm is easily done with a setting gauge available to authorized technicians)
If timing is correct, set the needle bar height by loosening the screw in the cross head and adjust the bar up or down so that the hook crosses above the eye of the needle while in the far right needle position.
Adjusting the bar height will be the equivalent of lowering the needle but check the timing first. If it is off, the machine will sew but the stitch quality will be poor.
You really should try to find an authorized repair technician in your area. If you change the wrong thing you may make the problem worse and it will just cost that much more when you have someone fix it for you. Also, the tolerances are very close on these adjustments. You may thing that raising the needle about 2.5mm is close enough on the timing check. For that measurement, there is no tolerance. If you go to 2.4 or 2.6 your stitch quality will suffer.
Posted on May 13, 2009
When trying to use the zipper foot the needle will not stay positioned to the side and keeps returning to center hitting the center of the zipper foot and machine stops
set the machine to straight stitching which should keep the needle in the center position
a zipper foot is a normal foot with 1/2 missing
It it still wanders , take it in for a service
Dec 31, 2015 | Sewing Machines
Needle position won't hange
When you turn the machine on does the needle bar initialize? I.e. Move to the left, then to center.
Nov 03, 2013 | Brother SE400 Computerized Sewing Machine
HELP PLEASE!!
I am slightly familiar with older sewing machines but not modern machines. It is a long time since I've seen my machines.
If your presser foot has a wide slot it is clearly possible to use it for zig-zag sewing. If the machine is capable of zig-zag or swing needle sewing, it is sometimes possible to swing the needle and fix it to the left or right and fix it in that position.
I suggest you check in your machine instruction manual. Perhaps the presser foot you are using is unsuitable for your machine...
May 12, 2017 | Juki DDL-8300
Pfaff 7530/ electronic problem?
Where has it been for ten years? This could have a big affect on an electronic sewing machine.
Take the machine in to a sewing machine shop for service.
Feb 22, 2010 | PfaFF Sewing Machines
I have a new Singer 1507 sewing machine- needle position wrong
Turn the big knob on the right of your Singer 1507 machine so that the vertical stitch line in the center. (Currently your machine most likely has the vertical stitch line to the left.) Don't push your needle manually; you will damage the needle.
Nov 22, 2009 | Singer 1507
Needle postion
If you mean left or right with a straight stitch, then yes. You use the stitch width selector - you will notice a small raised section in 3 locations, they mark, far left, center and far right.
Jan 25, 2009 | Brother XL-3510 Mechanical Sewing Machine
Nov 17, 2007 | Husqvarna Rose
Sewing Machines Logo
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
