Question about Linksys EA4500 Smart Wi-Fi Router Enabled N900 Dual-Band Gigabit USB DLNA
How to turn off the firewall on my rg router
Ipad can't connect
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 51 Answers
Are you sure it is the firewall,
I would suggest using a simpler encryption protocol for your wireless.
Posted on May 01, 2014
2 Suggested Answers
rcw1962
  • 2571 Answers
SOURCE: my linksys router will now
usually with the IPAD. You need to put the correct settings into the wireless connection settings.
You wll need your SSID (the name your router shows up as when you search for wireless connections)
Your security type ( WEP or WPA/WPA2)
your wifi password.
I have connected many IPADS, as long as you have the correct details it should work
Are you setting the correct security type?
Posted on Aug 08, 2010
I am trying to connect my ipad 3 to my dlink 600L. It will ask for password but will not connect when password is putin
Here's a video Harshit kumar suggested as a solution to your problem from YouTube:
Fast D-Link Wireless Router Security Setup
Apr 19, 2013 | D-Link Dir-600l Wireless N 150m Home Cloud...
My router was working fine with my iphone and ipad , now it will not connect and i still have a connection with my ps3
If you reset the router and have not turned off and back on all your devices you probably have conflicting addresses. some versions of ps3 will not connect for some reason unless they have the first ip available on the router.
Turn off your wirelss on your iphone and ipad, turn off the ps3. Reboot the router when it comes back up turn on the ps3 and get a good connection, the enable wireless on your ipad or iphone and get a connection the doe the same with the other.
This will avoid conflicting addresses.
An IP address has a 24 hour lease if you reboot a router it forgets what device had whipch ip address. If you need to reboot your router you need to refresh the ip address of all your devices to avoid conflicting ip's.
In this case I suspect you ipad and iphone are attempting to use the same ip address.
Jan 29, 2013 | SMC Barricade g SMC2804WBR Wireless Router
Dell XPS M1530 laptop can't access Internet with Netgear router DGN 1000.
Have you opened Internet Options, Connections tab, Lan settings, Check Auto Detect. OR release and renew your IP address : http://www.wikihow.com/Refresh-Your-IP-Address-on-a-Windows-Computer Is your wireless adapter enabled? Drivers up-to-date? in working order? Have you run the diagnose in Manage Network Connections. What is your Anti Virus? Try connecting with it disabled?
Dec 26, 2012 | NetGear DGN1000 Wireless Router
Comcast ipad wifi problem
I'm sure you've done this but try turning off wifi on iPad and then turning back on. Does your wifi name show?
Jun 17, 2017 | Apple iPad 32 GB 3G Tablet PC
Ipad connects to D-Link DI-524, authenticates and drops the connection 1 second later. How do fix it so that the connection remains up?
I think the problem is that your router has a firewall that your iPad can't get through.
You could try going to D-Link's web site and find directions to allow your iPad to access the internet.
=) hope this helps
Jul 10, 2010 | D-Link (DI-784) Wireless Router
Just setup my Belkin router and I cant get a wireless signal on my Ipad
>>>>Connect any of the computer to the router using a cable
>>>>Open the internet explorer page and in the address bar enter the numbers 192.168.2.1
>>>>On your left hand side you will be able to see Firewall
>>>>Click on firewall
>>>>It will ask for the password
>>>>Leave the password and click submit
>>>>Disbale the firewall
>>>>Click on apply changes
THANKS....
With Regards......
Vaishu
Jun 21, 2010 | Belkin (F5D5231-4) Router
Installing a linksys router with a u-verse RG.
Hi sgolob48,
First, make sure that the wireless network capability ofthe U-Verse RG is diabled (since you're using the Linksys for that purpose).
Second, make sure the ethernet cabel from the back of the RG connects to an LAN port on the Linksys (NOT the Linksys's WAN port).
Finally,disable the DHCP feature on the Linksys (since DHCP should be active on the U-VerseRG). Here's how:
1) Install the Linksys software on your computer and open your internet browser.
2) Type the URL 192.168.1.1 (default for Linksys access ponts).
3) You'll be asked to enter a username and password. The default is username "admin" and password either "admin" or [blank].
4) Once you've logged in, scroll down on the basic settings page (the one that loads automatically) to where it says Network Address Server Settings (DHCP). Click the radio button next to Disable, then click Save Settings at the bottom.
What you've basically done is make the Linksys another computer in your network, and the one that others will connect to the RG through.
I hope this helps - please let me know if I can be of any further assistance.
Kind regards,
H2H
Dec 16, 2008 | Linksys Wireless-G WRT54G Router
Hello my mtu is sayin its failed
The MTU(Maximum Transmission Unit) failure when testing the xbox's connection can be do to a few things because Xbox live requires a minimum MTU setting of 1364. Sharing a slower internet connection with other PC's in the house can cause this error, The incorrect MTU setting in your routers programming can cause this error, The lack of firmware updates to your router can cause this error, an older modem from your service provider can cause this. Old or worn network cables and jacks and or RG(coax) cables if you have cable internet could cause this. Your Router or gateway could be incompatible with Xbox live.
Try a direct connection to the Xbox without a router and reset your modem before doing it. If your able to connect then you know its the router. If not you know its the modem or cables or jacks or even your Xbox if you havent tested it elsewhere.
You can tell your ISP to mail you the newest updated modem... sometimes they will have a guy just drop one off.
May 02, 2008 | Computers & Internet
Linksys EA4500 Smart Wi-Fi Router Enabled N900 Dual-Band Gigabit USB DLNA Logo
108 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
