Question about Garden
Engine revs up down while in idle
I have a rockwell power task pressure washer , when i switch it on the engine goes straight to hight revs and wont drop when im using the lance. any ideas ?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 165 Answers
Check carby for missing spring or damage
Posted on Apr 21, 2014
  • 92 Answers
SOURCE: pressure washer
Dear Davidpaulson,
There are many reasons why there is no pressure. The simplest one is try a new lance. The lance you say it is not blocked, but it could have a wider hole with wear and tear.
The second most possible reason is, faulty valves. The suction valves are the most that give low pressure when they are faulty. To check the suction valves, put on the machine in the normal way and as it is working, disconnect the water supply. Than check if air or water is blowing out from the inlet. This is not 100% but you can have a picture of the function of the suction valves.
On the other hand if you do this exercise with the outlet, after removing the gun, you can check for the delivery valves. If you feel suction at the outlet, than the delivery valves can be faulty.
If all is correct, than there must be a fault in the swash plate. This could become loose and so the pistons will stop moving. Also another fault could be broken springs.
Also if the machine is leaking, the high pressure and low pressure seals are damaged. This also lowers pressure.
Other faults are related to the famous spill valve. Also faults could be to internal water leakages, due to corrosion in heads. Finaly I like to add that a faulty electric motor, could also not deliver enough rotation and power, and this also reduces pressure. This could be rewinded or changed for a new one.
Regards,
MG.
Posted on Nov 05, 2008
  • 83 Answers
SOURCE: honda pressure washer cuts out when lance trigger released.
You most likely need to set your valve clearances. If it is hard to pull over or the recoil snaps back after starting your valves need to be set for sure. This may not be the entire problem but it is a good start. Also change the spark plug, a bad plug will cause odd problems and is too cheap not to eliminate as a source. In addition check your fuel, pour a little out into a white container (I like spray paint can caps for this) and look at the color. If it is yellow to orange it is bad. You can pour it into you car, the car electronic sensors will compinsate for it quality but a small engine can't. Use a NGK BP6ES or BPR6ES plug.
You need:
Feeler gages
10mm open end wrench
14mm open end wrench
1 long shaft screw driver or rod
1 spark plug socket and ratchet
Remove the spark plug and the valve cover. Pull the recoil over slowly until the intake valve opens (intake is closes to the carb and it will go down when it opens). Now put your long screwdrive down the spark plug hole. Slow pull the engine over until the screwdriver handle is at it highest point, this is top dead center. It may take a few attempts. Now check your valve clearance between the rockers and the top of the valve. The intake should be .006 and the exhaust .008, both can be +/- .001. To adjust: hold the large nut with the 14mm then loosen the small one with the 10mm. Lefty loosey. Now turn your large nut until you get the correct setting and then tighten the small one the lock it in. It may take a few attempts and alway reverify your setting after you lock it down. Once done, find top dead center again and reverify. Now your valves are set.
Posted on Mar 31, 2009
  • 92 Answers
SOURCE: Karcher pressure washer won't start
Dear ralph_birtwi,
Most pressure washers when their gun is released, the machine stops automaticaly. This is done ny means of a control valve. When the gun is closed...pressure is built and the control valve moves and switches a micro switch off. In your case the micro switch is still closed in off position. Now this happens if a machine is left and stored with pressure in it., This control valve could get jammed and leaving the micro switch in off position. It could also stay in off position by sticking, due to incorrect chemical.
So the control valve or even called spill valve, must be renewed.
Sometimes a little lubrication with the right type of silicon grease will get the control valve working again. This job is sometimes delicate and better done by a qualified technician.
Regards,
fulltech.
Posted on Apr 12, 2009
  • 21 Answers
SOURCE: Karcher Power Washer that surges up and down with water pressure.
Before you start it up:
1. Disconnect the high pressure hose 2. Connect the water supply and turn on 3. Make sure water is flowing through the pump
Start the motor, run for about 10 seconds and then turn off.
Turn off the water supply, connect the high pressure hose, turn water back on, start the motor and away you go.
Posted on May 29, 2009
  • 174 Answers
SOURCE: Karcher G 3000 BH Engine Pumping Problem
This may not be a motor problem. It sounds like your pump is not working properly and the motor is just following the pump. First thing to do is check for leaks in the pump, wand hose, gun etc. It may also be a blown water seal inside the pump.
Posted on Aug 18, 2009
I have a Robin eh 34 engine in a Simpson power washer. The engine starts and runs but wont rev much past a fast idle. Carb has been cleaned thoroughly. gas is fresh. Suggestions
Butch if carb was good and clean and linkages were re installed properly including governor, it is possible the throttle tab/lever (what linkage hooks to) is loose on the shaft that opens the throttle butter fly. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
DIY Tecumseh Snowblower Carburetor Throttle Shaft Lever Repair PART 1
Apr 13, 2016 | Simpson PS2600 PowerShot Commercial-Duty...
Check engine light goes on after I rev engine. when rpm is low light comes on. why?
Dear friend. This issues appears when we have a fuel pump problem. I had the same issue. When the fuel pump pressure is low, the eletronic injection control send a sign for EPC control to blink the engine ligth. With rpm hight you increase the pressure automtic due to hight rotation motor applied on the fuel pump. To solve it, change the fuel pump, check if you have any hose blocked with dirt and so on. Afterthat verify the eletronic injectors nozzles and the timing belt position.
Hope to help you.
Regards.
Erik Weide
Jul 03, 2014 | 1992 Mitsubishi 3000GT
Rpm's fluctuate at idle
The oil pressure quage is moving around because the engine is slowing down and speeding up. As far as the idle surging goes try this.
Mar 14, 2014 | 2002 GMC Envoy
Bmw316i oil light comes on while idlingand goes off when revs are higher
In general terms, the problem could be a faulty oil pressure switch, or you could actually have low oil pressure. You can verify which issue you have by checking oil pressure with a mechanical gauge or by replacing the switch.
Mar 12, 2014 | Cars & Trucks
Motor wont rev up when starting cold with choke on trys to run on idle but will not rev up
the motor wont rev high on choke.the motor is suppose to fire once on choke. then turn the choke off.pull the start cord and the motor should start and run.check that the throttle conrol is on full. it should run fine.
Dec 26, 2010 | Honda 8 HP Engine
Idle problem,engine revs up and down
This may be due to a bad idle air control valve, or being low on coolant will cause this problem also. the only other thing is the power steering preasure switch, this switch when it goes bad it causing idle to go up and down, hope this is helpful.
Sep 10, 2010 | 1996 Honda Accord
When I release the tigger the pressure washer stops running. Runs fine as long as trigger is depressed. What could cause this?
When the trigger is pushed, the engine is supposed to rev up to increase the pressure. So from the description, is sounds like the idle speed is simply set to low and it dies. So just set the idle speed higher. You could set it as high as pulling the trigger does if you want, but that would waste gas.
Sep 04, 2010 | Briggs & Stratton Power Products 1539...
Oil pressure dropping after about 2 hrs running time mainly during a stoplight
first up.Is the oil recently changed.2nd is it the right type..3rd.Oil pressure will drop down when the engine is idling.If, when you give the engine a rev and the pressure builds straight back up,there is not a problem.Its normal.Cold oil will always give a higher pressure than hot oil.Check these few things and I hope this helps
Sep 24, 2009 | 1988 Ford F 150
Have a toro power stage max model 826LE electric start, runs irre
Sounds like carb. may need adjusting. Take the heat box off to expose carb., there should be 2 adjustment screws- 1 on the bottom of the bowl and 1 on the side of the carb just above the edge of the bowl ( depending how the carb sets off the engine - if the carb comes straight out it will be on the side facing towards the front of the snow blower or if it goes towards the handles then standing other side of the snow blower the screw will be facing you), turn both screws in til they just bottom out the turn them out 1 1/4 turns out then start the machine. While the machine is running at low idle turn the screw on the side of the carb. in (clockwise) a little at a time listening for the engine to start to rev up and then start to rev down, bog or studder then turn back slightly to bring idle back up. Once the idle is up then the screw on the very top of the carb. turn that out to lower idle to a normal idle. Repeat those adjustments till you cant get the idle to go up anymore. Now for the screw on the bottom of the bowl- move the throttle up to max and turn the screw in till you hear it rev up higher and starts to bog or sputter then turn it back slightly to bring the high rev to a smooth rev. That should take care of it. If it does not solve it then the carb may need cleaning then the adjustments done again. If you need more help on this please feel free to ask. Sometimes you have to do process of elimination and you start with the easiest first. Also the adjustments should help with the carbon build up on the plug.
Jan 15, 2009 | Agri-Fab Agri - Fab Snow Blower - 42"
95 Softail oil light comes on when it's warm only at idle.
the only way to check the oil pressure switch is to remove it and replace it, or test with a analog guage, if the pressure at idle is 5psi or higher at idle just replace the switch, the switch is not real percise and harleys have a dry sump oil system, and the pump is a g-rotor style dry sump pump at idle the engine might have 5-15lbs of pressure when warm and higher with engine revs you didnt say what weight oil you are running it could be to light of a viscosity 10-50, use a heaver weight oil 20-50 or like i use in my bike (2002 FLHTCU w/sidecar) straight 60wt hopes this helps
Jan 15, 2009 | 2000 Harley Davidson FLHT Electra Glide...
Garden Logo
128 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
