Question about NEC ETW 8-2 Corded Phone
I need to find a user manual.
Phone has gone back to default settings after a blackout.
    Novelist:
  • 201 Answers
This phone requires a phone system. The system itself stores the information. You need a programming and installation manual for your phone system, not the phone. You will need to determine the model number of your main phone system and look for the manual using that information. Phones only have user guides that explain how to use the features and do not get into programming the system.
Also, if you lost your programing in a power outage, most likely the memory battery is dead and this will keep happening in the future. Before making any programming changes, that battery needs to be replaced or you could possibly get away with a UPS battery backup system to power the entire phone system in a power outage.
Posted on Oct 31, 2007
Go back factory condition
Hello Cynthia,
There are several ways to achieve this.
Reset phone
The Reset feature allows you to set your phone options back to
the factory defaults.
  1. From Idle mode, touch Menu-> Settings -> Phone -> Reset phone.
  2. At the "All settings reset to factory defaults. Continue?" prompt, touch Yes to reset, or No to cancel. Once your phone has been reset to its default settings for those selected options, it will restart itself in order to incorporate the new settings.
Restore phone
The Restore feature allows you to delete any user information
that has been added, in addition to setting your phone options
back to the factory defaults.
  1. From Idle mode, touch Menu-> Settings -> Phone ->Restore phone.
  2. At the "All settings reset to factory defaults and all user data will be deleted. Continue?" prompt, touch Yes to reset, or No to cancel.
or
Reset code
Enter *2767*3855# in phone dial.
Warning! All your data including contacts, messages etc. will be lost! Copy all your necessary data/Contacts/Messages etc. to SIM or make backup on your PC before full reset!
Dec 06, 2013 | Samsung SGH-A877 Impression Cell Phone
Tip
Master Reset, Format and Unlock Phone Code Siemens SX1
Warning : This will erase your user data from phone like phone book and messages.
  • Get battery out of your phone and insert back in.
  • now press * and # keys at same time
  • while keeping pressed * and # keys now press power on button.
  • You will see phone says formatting after it your code is gone and phone is in its factory default settings.
on May 13, 2010 | Siemens SX1
How to hard reset samsung sgh-a817
Hard Reset - This process will reset the setting as well as erase all your personal data and downloaded content.
Note: if you have any data that you feel you need to keep please back up before proceed with the below steps. Once the data is gone it is gone forever.
1. Go to the Home screen.
2. Press on the Menu.
3. Next tap on the Settings.
4. Then tap on the Phone option.
5. scroll down the screen and then tap on Restore Phone.
6. Now tap on Yes to confirm.
7. Put in the password and tap on the Confirm button. Do this again to confirm the password.
8. Wait for your phone to reboot and check out if the setting has gone back to default.
or you can do this also...
1.Go to the Home screen.
5. Next tap on Reset Phone.
Oct 01, 2012 | Samsung Sgh A817 Solstice Ii - Black...
Need the 6 number pin for d link wireless dl 624
If you can reset the router back to factory settings(see below)
http://www.ehow.com/how_8417689_reset-dlink-di624-router.html
then you should be able to enter the default pin number inside the user's manual. Other than that, I'm not sure how you could retrieve it once it has been already set up.
Nov 14, 2011 | D-Link AirPlus Xtreme G DI-624 Wireless...
I m unable to allign the omnia screen
Hi user,
Omnia has a little bit of alignment options, in case you have made the setting change. The screen will be aligned as per your manual setting.
In case you want to realign the setting you need to set it up manually or you can do a default setting change in your mobile to get old default settings back.
This may change few other settings as well but atleast your screen will be aligned as it was earlier.
Best of luck!
Take some time and rate my suggestion.
Regards,
Richee
Jun 17, 2011 | Samsung SGH-i900 Omnia Unlocked Cellular...
Why am I being required to type a secret code when the Motorola i1 needs a master reset? Any clue?
Any branded phone is required to enter your code if they wish to reset the phone setting for security purpose. other user can't access,erase or reset your phone if you put a code on it.
if you doesn't know the phone code of yours,
* phone or unlock code is set in 4 digits,for locking some features like message,photo,video and other data you wish to lock up, 1234 will be the default.
* for security code is set in 8 digits,for securing the entire phone settings, 00000000 will be the default.
If you wish a "master reset" ,be sure to back up all necessary data because everything will be gone.
thank you for visiting FixYa..
Jun 16, 2011 | Motorola Mobility i1 Smartphone
Am using verizon 9530 unlocked. phone is working, the backlight is active on buttons...!! the screen is not active.. i could answer / receive calls.. can hear the notifications of receiving emails /...
When you get your blackberry screen blackout? After your blackberry 9530 unlocked or a few days after you unlocked your phone? Did you get my point? If you get that blackout screen after blackberry unlocked process try to reset your phone to default factory setting and if still not working try to reinstall your blackberry os, but if you get that blackout screen a few days after you unlock your phone looks like your screen already broken and you need to replace it in your nearest local mobile repair shop.
Jun 11, 2011 | RIM BlackBerry Storm 9530 Smartphone
Screen blackout
I am too facting the same issue ...Reverted back to def. settings ...uninstalled all unused / downloaded applications but still screen goes black when i slide the set in / out. and i cannot hear on head set..i need to sweitch on the speaker to make and receive calls all the time
Jan 21, 2010 | Nokia 6210 Navigator Cell Phone
Ga n650sli ds4l and intel core2 quad blackout when i restart
You need to reset your computer bios back from its original settings. While turning on your computer keep pressing the del key on your keyboard until you get to the BIOS utility screen. Select the BIOS default option and then save settings and exit.
Dec 18, 2009 | Gigabyte GA-N650SLI-DS4L Core 2 Quad...
Got an alpine cda 9855 the screen keeps goin black but if you touch the button it comes back on it has like a 5 sec delay then it goes black but still plays any help
Blackout Display Mode: When the Blackout mode is activated, the display turns off to reduce power consumption. The additional power made available by turning off the display helps enhance sound quality. If a button is pressed during the Blackout mode, the display will illuminate for 5 seconds before blacking out again. Blackout Mode On and Off (CDA-9855 only) When Blackout mode is turned on, the display will turn off to reduce power consumption. This additional power enhances the sound quality. Press and hold FUNC. for at least 2 seconds to activate the blackout mode. The display will turn off. If any button on the unit is pressed during the blackout mode, the function will be displayed for 5 seconds to show the operation before returning to Blackout mode. To cancel Blackout mode, press and hold FUNC. for at least 2 seconds.
Copied from the alpine user manual..
Hope this helps
Aug 01, 2009 | Alpine Car Audio & Video
NEC ETW 8-2 Corded Phone Logo
501 people viewed this question
Top NEC Lands Phones Experts
Craig Butler
Craig Butler
Oloyede Monsuru
SC Spike
Level 1 Expert
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
