Question about AOC 2436Vw LCD Monitor
AOC 2436Vw LCD Monitor - Repair capacitors board
  • 8 Answers
SOURCE: AOC LM729 17" LCD Monitor
Where are the ring inductance coils on the power supply board?
Posted on Feb 04, 2008
  • 8 Answers
SOURCE: AOC LM729 17" LCD Monitor - Manuel
I assume you only found the 4 mount screws in the back... You also need to take off the front silver edging - it pops off with some negotiating, but if you find the right spots and don't pry hard it will come off clean without too much difficulty. Then take out the screws that hold the screen inside and it should drop out.
SOURCE: Inverter board
just change the 4 bloated caps on the board (2)100mfd 16v and (2) 470mfd 16v
Posted on Mar 31, 2008
webdevil
  • 43 Answers
SOURCE: aoc LCD monitor problem
If some of the pins inside the monitor cable are bent or broken you can losr primary colors and cause this. Check them. If they seem OK try reseating both ends of the cable. If no go, then try the monitor of a differnt computer to see wether its the videocard or the monitor thats defective.
Posted on Jan 06, 2009
budmrtn
  • 11361 Answers
SOURCE: AOC LCD MONITOR
The cable from the Monitor USB input to PC USB output is good? Check to see if you do have 5vdc on pin 1 of the USB connector. Your monitor is basically a powered USB hub when it is connected to PC through a USB cable.
Posted on Jan 20, 2010
Aoc monitor power button will not turn on
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Take it to a repair shop.
Apr 07, 2014 | AOC Computers & Internet
Aoc 2436VW monitor SOUND DOES NOT COME ON
Most monitors with speakers built in need a 3.5 audio cable with jack on both ends,very inexpensive cable, that you connect from the audio port on monitor to the audio out on your sound card. You may have to go into the menu on your monitor and turn the volume up or make proper adjustments...
Dec 27, 2012 | AOC Computers & Internet
How do I activate the USB port on my Monitor?
Make sure it's plugged in to a USB port on the motherboard and check device manager to make sure the device is detected. Also might need drivers. If any disc came with your monitor you may wanna run that.
Jun 26, 2012 | AOC 2436Vw LCD Monitor
Where can i get a manual for my new 2436vw lcd 24 inch class
Here is the link to the Online User's Manual for that model:
http://support.aocmonitorap.com/userguide/2436vw/English/v-01.htm
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
Just click on the tab for whatever topic you wish to read about and the information will then come up on your screen.
Thank you very much and good luck.
Apr 11, 2011 | AOC 2436Vw Monitor
I can not install the soft ware disc that came with this monitor
The disc may be for a different operating system than your current one, however operating systems typically import all of the necessary information to use the monitor properly. And thus the disc is almost never necessary. If you really want to download it regardless, visit the link below and enter in the model of your monitor to access their downloads.
http://us.aoc.com/support/downloads
Mar 26, 2011 | AOC 2436Vw Monitor
Can't figure out where the volume controls are.
Unfortunately, the 24" AOC 2436Vw Monitor does not have built in Stereo Speakers. I know that is not the best answer to hear, but after doing a little more research, I found that the 24" AOC 2436Vh Monitor has 2 built 1.5W Stereo Speakers for just $50 more.
Mar 05, 2011 | AOC 2436Vw Monitor
Everytime i start my computer it come on for awhile then the monitor show no signal
Failing powerboard capacitors, capacitors not holding charge, needs repair by tv type repairman
Jan 28, 2011 | AOC 917Sw 19" LCD Monitor
Same problem--AOC monitor "goes to sleep" after an hour online
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you can't do the repair we offer a repair service, contact us for more details.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Aug 09, 2009 | AOC 19LVWK LCD Monitor
the inverter needs to be replaced
not real hard, but must have some knowledge of the process
Feb 02, 2008 | AOC LM729 17" LCD Monitor
AOC 2436Vw LCD Monitor Logo
Top AOC Computers & Internet Experts
Raj Patel
Mohammed Ebrahim M
Mohammed Ebrahim M
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
