Question about JVC RX-318 Receiver
The amplifier model #RX318BK the sound is distorted badly.
Have changed TA7317P, TC9164N, BA15218N and NJM4580LD
Speakers have a crackle in the sound also rear speakers not working
can mean several things. The crackle is subjective and can mean distortion. Distortion most of the time comes out of the amplifier. Could be you have blown a capacitor in the power supply of the amplifier, making it work with quasi half the voltage. There is no need to change the polarity on a speaker, because when one is not working infuse, it won't distort the music. You only could have difficulty with the stereo sound. It could be a bit unclear where the sound is coming from and could sound a little less powerful.Check the speakers on a different amplifier, to hear if I'm right. Only if you switched on sound while the amp was giving full power, you could have blown the speakers, but most of the time they don't give any noise after that.
Jan 16, 2015 | Ranger Communications 1998 1999 2000 Ford...
Fosgate p325.1 amp comes on and appears to be
distortion means you have a bad source or the amp could be damaged. if no sound when on low or hi it definitely mean the amp is at fault
Oct 21, 2014 | Car Audio & Video
Teac A R300 right speaker has s badly distorted sound after 20 minutes. When I turn it off nad turn it on again, Same problem after 20 minutes. Left channel working perfect.
Have you changed the speakers to see if it is a driver, or amplifier, issue? If it follows the speaker, get it reconed. If it follows the channel, look into that channel.
Aug 19, 2014 | Audio Players & Recorders
Distorted sound / fuse blows off when changing amp class.
The class A switch adjusts, via an optocoupler, the bias on the output transistors.
I would check the standard bias and class A bias adjustments.
Mar 22, 2014 | Marantz PM7200 2-Channel Amplifier
Distortion sound
probably crossed ground/ positive connections. if not u have bad channels or a blown reciver
May 04, 2012 | Yamaha P3500S Amplifier
Toshiba tv, model cf32c50 has a garbled sound issue.
distorted sound sometimes accompanied by buzzing is caused by detuned circuit in the SIF amplifier and sound detector circuit. a distorted sound alone is caused by a breakdown in AF amplifier circuit so try to change the sound ic since its the only options left. good luck!
Jul 27, 2010 | Toshiba Televison & Video
Does this boss chaos c550 amp match up to perform correctly with 2 12inch kenwood peak power 600 watt magnet 500g (17.6)oz impedence 4 ohm kfc-w300s speakers
It's not bad, but at 400 watts, it's a bit underpowered
It'll be plenty loud, but the amp will distort before the speakers do, particularly if your subs are wired in parallel (as dual-driver boxes are typically wired)
Listen for distortion, and turn it down a bit if the sound gets fuzzy or static-y sounding
Feb 03, 2010 | Boss C550 Car Audio Amplifier
Distorted sound, from any of the inputs
All inputs are switched and go through a series of amplification stages. If the volume appears to change correctly, but hte sound is just distorted independent of the voluem, then the problem is likely to be in the beginning stages of the amp. This can be as simple as a defective OpAmp IC or diff-amp section or even a voltage regulator failure. Without the exact model number and some internal measurements, I can not say for sure. Can you supply more details?
Thanks,
Dan
Oct 13, 2009 | Teac Audio Players & Recorders
Poor sound/ Unable to play anything load without distortion.
i can tell you right now base on the vehicle you have a bad system hook wosrt if you are using factory head unit
Mar 25, 2009 | Kenwood KAC-8151D Car Audio Amplifier
Distorted sound.
Your turntable is a preamp. Your amplifier might be going bad. did you connect it into phono? dont connect it into the cd or dvd input because those wont work.
May 11, 2008 | Technics SL-1200MK5 Turntable
JVC RX-318 Receiver Logo
41 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
