Question about iLO 3200 32 in. LCD Television
Cannot get new digital signal to my ilo tv
I have an ilo tv and a new outdoor from radio shack and i cannot get any channels but the instruction guy helkp
    President:
  • iLO Master
  • 1,779 Answers
I've done a little research and I don.t see where you have a ATSC tuner that receives the over the air digital signal. You have a basic Analog tuner. The only way you can receive digital is by a HD cable box by having cable or going to Satellite.
Posted on Jun 14, 2009
How can I get free channels from my tv Philips mod 15mf605t/17
you need antenna for the tv
if the tv is digital than in needs digital type antenna version
if you have analog tv than piece of wire, metal coat hanger, analog antenna version
analog versions:
you can pick up cheap at swap meets, yard sales, goodwill, where every they sale tvs, radio shack,walmart, target, homedepot, online,amazon.com, ebay, friend. and so on.
digital versions:
where every they sale tv, radio shack, online, amizon.com.
some digital and analog unit comes with a built in amplify this is very nice to have if you live in a big city or out in the country help with receiving amplified signal to the antenna receiver unit.
Oct 06, 2015 | Philips Magnavox 15mf605t/17 Lcd Tv Screen...
What happens if two digital thermometers are set on the same channel
The same as when you have two radio stations on the same channel or frequency. The receiver wants so receive them both, resulting in a scrambled and useless signal in the receiver.
It won't work.
If the system can work with more than one (wireless) thermometer each will have an own channel number. and you will have to switch on the display to read one or the other.
Jan 05, 2015 | Springfield 91455 Wireless Digital Outdoor...
I can't turn off the squelch on my Radio Shack Digital Trunking scanner.
On all channels, or on one channel ? Some channels are "birdie" channels, check your user manual. Others are problem channels receiving false signals from computers, monitors, receivers, internet equipment, FAX machines, etc. If your in conventional mode, if in Digital mode the squelch is set by the processor, and I don't believe the squelch has any effect in that mode.
Sep 18, 2014 | Radio Communications
I have a pro 23 hand held scanner it scan but I only pick to weather channel. Thanks, George
You will need to program in your local channels - ANALOG ONLY will work, not Digital. I suggest you go to "Radio Refererence DOT com" and go to their database; select your state, then your county, and it will list many frequencies for you to program to your radio. Also, SOME, not many, but SOME, Radio Shacks actually have a ham radio guy working there that can help you program your radio or help you 'CLONE' it from another identical radio. Good luck, and let me know how it goes. Happy New Year my friend.
Dec 31, 2010 | Radio Shack Pro-95 Handheld Scanner
Sony trinitron kd28dl10u has moved house. retuned digital channels but itv and channel 4 are missing?
i think i get the jist - you've moved, and now you're missing a couple channels. from what you're saying, i assume you are using a digital converter box, or have a digital ready tv. i personally have seen many problems since the digital change, specifically loss of channels. even though digital tv is supposed to be 'all that', and it is fine when it works, the quality and placement of your antenna is still critical. you are still receiving a signal on the same channel, only with digital, they have reduced the bandwidth. this action was not done with the consumer in mind, it was done to free up air space for other communicatiomns. try an amplified antenna [available at radio shack for about 20 dollars], and try different positions. if this doesn't work, you might try an outdoor antenna. with digital signals, if there is an obstruction between you and the transmission site, rather than getting a weak, snowy picture, or shadows, as you would back in the days of analog, your receiver will simply not receive the station
Sep 05, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Radio Schack converter doesn't program Ch: 25 like Magnavox!
Returned product to dealer. That fixed my proble.
Thanks...
Aug 19, 2009 | Philips Magnavox 20MT133S 20" TV
ILO 26HD TV: After playing Playstation, the TV
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Feb 22, 2009 | iLO 2600 Television
I have a new RS 15-2142. Followed instructions for programming a LG TV and a toshiba DVD. Remote took codes (blinked twice for each) but devices will not respond (turn on off, change channel start, play)....
I will fix it by returning the item to
Radio Shack. Do not think much ofhe service. Some guy like me makes a suggestion and then you try to up sell to another product.
Dec 06, 2008 | Radio Shack 15-2142 Remote Control
Digital tv
Good Day, tuff65;
Today with "HD TV" get a good UHF/HD antenna. You can get at any local Best Buy, Circuit City, Radio Shack etc.
Good Luck, big IRISH. PS: Inside or outdoors.
Sep 03, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Digital Converter Box
# 1. Why are you using a digital to anaolg box when you only have a analog signal coming in? The box is designed to see digital information then converting it back to analog. Please explain further what you are attemping to do?
Mar 28, 2008 | GE 19GT270 19" TV
iLO 3200 32 in. LCD Television Logo
275 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jim Goldsmith
Jim Goldsmith
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
