Question about Insignia NS-P42Q10A Plasma TV
Tv turns on a second, LED flashes
Tv will only turn on for a second with reddish looking static, then it turns back off and the power LED flashes five times. Any ideas on where to start troubleshooting?
    Top Expert:
  • Insignia Master
  • 75,571 Answers
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
Posted on Mar 19, 2014
5 Suggested Answers
SOURCE: TV turns on for a split second then back to standyby
i think your capacitor is blown, do a google search for insignia, lcd, capacitor...
you can buy another one for about $2 but its a pain to install, you can also instead buy a new powerboard for about $80, its an east install and you wont blow more capacitors
bestbuy.partssearch.com
Posted on May 15, 2008
SOURCE: Insignia LCD TV 32 inch will not come on
I received no replies to my request. I guest I stumped 2 million techs. I'll just buy a new TV with a 5 yr warranty. No thanks to joining your service, I can do bad all by myself.
Posted on Feb 09, 2010
budmrtn
  • 11361 Answers
SOURCE: I have an Insignia NS-46E560A11 LED-LCD TV. I was
Power supply went out, it is under warranty, get it fixed ASAP, this is not good sign taht it failed within 4 months.
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Posted on Oct 07, 2010
SOURCE: insignia 32" begins to power up but shuts down right away
Nice....needs repairs.....I'll never buy another Insignia!! Mine had burned images on it after few months.....also same issue with power button. I'm a computer engineer. I figure change the power supply.....small component.....if anyone has basic electrical experience....you can do it yourself......save you a couple hundred.
Posted on Nov 30, 2012
Five red blinks in Sony LED TV KDL 40W900A.
5 red flashes is a bad panel connection or internal panel short, very carefully take the panel connectors off and reseat them and see if that helps, unfortunately you may have a bad panel.
Oct 14, 2017 | Sony Televison & Video
My introva cp9 wont turn on after my first few usages The led on the front flashes reddish orange and the led on the screen side flashes green then nothing else happens
You may have to hold the power button down longer like five ten seconds, it might not be off at all it could be in deep sleep called S3 standby or worse HIBERNATE. Hold the power button down til it cycles all the way thru and comes on, then I can help you disable all that stuff, the best way to save energy is to insulate your house, dam if I didn\'t have a laptop I\'d have no heat at all.
Feb 14, 2014 | Computers & Internet
Will not power on led flashing red and now no led
Reset your TV. Unplug your iLO TV from the wall and remove any connected devices. Hold the front power button in for five seconds, then release. Plug your TV back in, turn it on and confirm that it is working again.
Read more: http://www.ehow.com/how_5458819_troubleshoot-ilo-tv.html#ixzz2tRuiKHvE
Jan 21, 2014 | iLO LCT32HA36 Television
Hello. My Panasonic PT-50LC13 is not turn on. First flashing green light for one minute on the power button then starts to blink red and at the same time it starts blinking red LED lights every five...
Check ur tv fan,if ur cooling fan are runnig,before all these LED lights are flashing.If not that ur tv problems.All these LED lights are flashing the tv making alots of clinking noises too like it trying turn itself on?Yes,than the tv board that called the Ballast board it is dead too,must be replace also.This tv Ballast board only job are to help to ignite the tv projection lamp only and keeping it on and running.
Aug 29, 2011 | Panasonic PT-50LC13 50" Rear Projection...
I turn the power buttin on....after about five
When was the projection lamp last change?If the tv,projection lamp inside the tv at last change was 1/ 1/2 or 2 years ago,and the tv is on,an in use at lest 4 or 5 hours day.The projection lamp life,it over should be change the projection lamp.Now tv turn on LED light "LAMP" indication light up or flashes?Yes,the projection is dead,hear alot of clicking too?The Ballast board it also dead,should be change too.The Ballast board,this board job,it help to ignite the projection lamp.
Jul 23, 2010 | Toshiba TP61H60 61" Rear Projection...
Samsung LN-T2632H won't turn on.
Follow these steps to figure out what problem is.
When you turn on TV, look at the back and see if the back light on. If it is on, the power supply and inverter work fine. The suspection now is main board and T-con board (the small board on the middle-top of the panel)
To find the problem from the main board or not. Look at the power supply and measure Vs on - turn on the TV, this approx 5 vlt DC needs constant once you turn on the TV. If it is drop or unstable - main board problem - replace it.
If Vs on is good - disconnect the T-con cable from the power sup. If power sup stop clicking - T-con need replacing. Hope it help.
Aug 12, 2009 | Samsung Televison & Video
Another problem with my 52725
It may very well be a connection issue with one of the wire connections as its not giving you a error code. I would double check the wire plug connections
Jul 28, 2008 | Mitsubishi WD-52725 52". Rear Projection...
WORKS 3 MIN AND SHUTS OFF
If it is the power LED that is flashing orange 2times every five seconds , it suggests that the Lamp Cover was not reinstalled correctly. Remove and reinstall it
Jul 13, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Power up Problem
my hitachi model number:55fx48b suddenly just stopped. I can unplug the tv, then turn it back on and red led light will come on for 2 seconds and shuts back off! Can you please help me
Jun 28, 2008 | Hitachi 55FX48B 55" Rear Projection...
Insignia NS-P42Q10A Plasma TV Logo
52 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
