Question about Danze Plumbing
I have a danze d4042-cp. I need to seperate the main body from the veritcal section to replqace #13. I can't get it apart. Help
Have tried liquid wrench and a rubber loop wrench to try to get it apart -no luck
  • 3,368 Answers
I use a mild acid such as vinigar. I soaked a cloth in it and wraped it around the area. Kept this up for about a week and it came apart. I always put it on hot as I tolerate with my hands.
Posted on Apr 29, 2014
2 Suggested Answers
Dplumber
  • 119 Answers
SOURCE: I have a Danze model
2.5mm is the correct size, but you can use a 3/32nd inch if have to.
Posted on Sep 06, 2010
The Danze touchdown stopper can be pushed down and it does not leak. It also will not pop back up no matter what, unless you can thumb-screw it backwards to get the stopper lid off. The rubber gasket seems...
This happened to mine too. I took it apart ( removed the whole part, then removed the cap ) clicked it a few times, stuck it back in, and it's worked fine ever since.
I'm going to say that it may be either a manufacturer thing, or perhaps there's some sort of build up going on.
Either way, you could try doing what I did, or contact Danze and ask for a refund. Maybe a different brand would be in order?
Oct 20, 2013 | Danze 1 1/2'' Touch Down Drain DANZE...
My Danze showerhead runs even when turned off
try cleaning the inside of the valve with 1500 grit wet sandpaper. and then put a lot of waterproof plumbing grease in there and also on the cartridge. sometimes you can get a build up of hard water inside the valve body and that will cause leaks. just dont over do it with the sandpaper and dont anything more abrasive than 1500 grit.
Nov 26, 2012 | Danze D135300BT Single Handle 3/4 Volume...
What do i use for a roundup wedd killer spill?
From MSDS:
      SMALL SPILL: Soak up spilled material with paper towels and discard in trash.
      LARGE SPILL: Liquid spills on floor or other impervious surfaces should be contained or diked, and should be absorbed with attapulgite, bentonite or other absorbent clays. Collect contaminated absorbent, place in plastic-lined metal drum and dispose of in accordance with instructions provided under Section 13. "DISPOSAL". Thoroughly scrub floor or other impervious surface with a strong industrial type detergent solution and rinse with water.For liquid spills that soak into the ground, contact the applicable Federal, State and or County Health Dept. for disposal recommendations. If disposal is required then refer to Section 13 "DISPOSAL" for instructions.
      Leaking containers should be separated from non-leakers and either the container or its contents transferred to a drum or other non-leaking container and disposed of in accordance with instructions provided under Section 13 "Disposal". Any recovered spilled liquid should be similarly collected and disposed of.
      Do not contaminate water, foodstuffs or feed by storage or disposal.
      GENERAL PROCEDURES: Observe all protection and safety precautions when cleaning up spills -- see Section 8. "EXPOSURE CONTROLS/PERSONAL PROTECTION". For help with any spill, leak, fire or exposure involving this material, call day or night (800) 225-2883.
Dec 31, 2009 | Home
Looking for parts breakdown picture for DANZE NSF 61 Kitchen Faucet Any Links?
NSF 61(-9) is a standard rather than the model number (it's often very difficult to identify the model number. If you are able to find the model number, the link attached has all the technical specs for Danze products (even discontinued ones). http://www.danze.com/tech_specs.asp
Otherwise, I suggest browsing their faucet section until you find yours.
Good luck.
Sep 13, 2009 | Plumbing
What is the height of britannia omaggio 90 cooker hood?
Here are the dimensions that relate to your cooker hood. The measurements are in mm.
Width 980 front 578 rear
Depth 480
Minimum height 1015
Maximum height 1170
Main canopy height 750
(excl chimney)
Chimney section width 436 main body/340 sliding section
Chimney section depth 170
Mounting height 650 - 750
Regards
Alan Hood
ami-man
Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750
Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750 Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750 Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750
Jun 16, 2009 | Kitchen Ranges
My danze D455612 is leaking and i think it might be an o ring problem. How do i pull it apart. I have taken off the top part but i am up to go any further
I have never taken apart that model before but they are all relatively similar.
The first step is to close the water supply.
Remove the handle.
Either a set screw or nut around the valve stem (packing nut) will be holding the cartride in place.
Once the valve stem/cartridge has been removed then all of the o-rings are evident....replace all of them and the large flat washer at the end of the stem (if there is one0.
Apr 11, 2009 | Danze Plumbing
My Danze Anu Kitchen Faucet
Sounds like you have hard water.  You need to change the inside of the facet.  before doing anything make sure you CAN get the parts for you facet.   Danze are not very expencive you might just get a new facet.  If this is a hard water problem you might want to buy a moen facet with a life time warrinty.  More money but free replacement parts.
Apr 04, 2009 | Plumbing
Water leaking from tap when turned off
In order to remove the Danze handle from this particular model grasp the handle of the valve and then the body of the valve and turn the body counter clockwise in order to remove.
Hope this helps.
If you don't have a supply house near you that carries parts for the Danze products you can go to danze.com and order them there.
sanray
Jan 02, 2009 | Danze D500058BNT Parma Shower Trim Kit w/...
Plumbing Logo
79 people viewed this question
Top Danze Plumbing Experts
Donni Steen
john h
Andrew Bugbee
Are you a Danze Plumbing Expert? Answer questions, earn points and help others
