Question about Whirlpool RBS305PDS Electric Single Oven
Changing hinges on cooker door
Are the lower hinges supposed to be springloaded? At the moment, they just collapse into the slot in the door.
    Director Badge:
    Uploaded 100 video answers.
  • Whirlpool Master
  • 488 Answers
I HOPE THIS HELPS
Posted on Apr 27, 2014
I am getting an F64 error message. what is this trying to tell me?
Welcome to FixYa.
The "F64" code on your model of Thermador double oven indicates the control has detected an error with the airflow for the lower oven ( all lower codes start with "6", upper start with "3" )
This could indicate a faulty blower motor, not coming on at all, or if it does come on and still initiates an F64 error it is likely the sail switch is sticking. It can be removed and cleaned as they do become contaminated with dirt, grease and dust over time.
The sail switch is located at the very bottom of the ovens where the grill is, under the lower door.
( F64 can also be initiated by a failed "K4" relay on the control board, but that is less likely )
It can be accessed by way of removing that grill, however it is something usually best left to an authorized B/S/H/ service provider as it can be quiet involved and is better to pull the unit from the wall.
**Turn off the 40 amp breaker to the oven before attempting any service...safety first**
B/S/H/ is the parent company for Bosch, Thermador, Gaggenau, Siemens.
Let me know if I can assist you further regarding this issue and I`ll try to be available asap.
Good luck.
Thank you for choosing FixYa today, please take a moment to rate the info provided here for you.
macmarkus :)
Aug 03, 2010 | Thermador SEC302 Electric Double Oven
Door came off the hinge
These Videos will help with your cooker problem.
If you need more video help on appliance repairs visit our Video Tutorial Library at our website
1 how to remove your oven door for cleaning or repairs and how to reseat the door when finished.
2 How to change and fit oven door hinges.
We can not allways cover Every model but hope this helps. Remember to send us an email if you can’t find the part you need.
We also supply all the Parts you need for Repairing your cooker oven Door.
Oven Door Hinge Spare Parts
Oven Door Glass panels
Cooker Door Handels ETC
Cooker Door Catches ETC
Cooker & Oven Door Seal / Gaskets
Remember to Leave feed Back and pass our site on to your Friends:
Our Shop http://www.apart4u.co.uk
Our Video Help Section http://www.apart4u.co.uk/video-tutorials.html
Mar 04, 2010 | Whirlpool RBS305PDS Electric Single Oven
Can I get replacement door for my top oven, and new door seals for Creda Cachet Solarplus Model 48182, serial 60.1.00082
we should be able to help if you contact the office
Mar 04, 2010 | Ovens
My oven door won't open and its not locked or on clean. what do i do
Mar 03, 2010 | Ovens
I removed the range door to clean oven. Now I
NOTE: The door removal pins you inserted must still
be in both sides of the door.
1.
Grasp the door on the sides with your fingers on
the front of the door and your thumbs on the
inside surface.
2.
Rest the hinge hanger so that it is flat (at the
bottom of the hinge hanger on the bottom of the
front frame slot).
3.
Position the door with the hinge hanger slots
almost parallel to the front frame.
4.
Push up and in until the hinge hanger slots
become fastened to the range. Lower the door
and rotate it slightly from the front to the back
until the slots are fully fastened. The hinge
hanger will be close to the bottom of the front
frame slot.
5.
Pull door open about halfway and remove the
door removal pins. Save door removal pins for
future use.
6.
Close the door.
Dec 25, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Loose beko oven door ??
CHECK FOR A SLOT WHERE THE HINGE GOES INTO IT MABE YOU CANT SEE IT BECAUSE IT MIGHT BE CLOGED WITH FAT CLEAN WITH SOAPY WATER AND FIT THE PIN INTO THE SLOT AND IT SHOULD BE FIXED,
Nov 29, 2009 | Ovens
Top oven door glass has smashed
Usually, u open the door as far as possible and at the lower end of the hinges you shoud find what look like 2 small catches, pull these up and latch them on to a hook or something similar on the main part of the hinges, this compresses the springs, and then lft up the door and pull towards u, this should release the door, and then change the glass, then offer the hinges into the slots, and pull the door back down, then release the catches.
Plz rate my solution.
Thanks.
Jan 01, 2009 | Fagor Ovens
Hotpoint BS 21 fan oven Broken door hinge
Pull the door down as far as it will go, and at the lower end of the hinges, there you should see what looks like 2 round discs, with a step cut out, rotate the discs with a scewdriver as far as they will go,then close the door and pull it towards you, the door should then pull off.
Replace both hinges, not just the one ,or it will close unevenly.
Slot the hinges back into the hinge slots, pull the door down, rotate the disc back to their original setting, and that should be it.
Plz rate this solution. Thanks.
Dec 27, 2008 | Ovens
Can't get the door back on the oven
Yes, take a pair of pliers to pullout the hinges. They are springloaded and it seems hard but they are designed to keep the door shut tight.
Nov 30, 2008 | Kenmore 47783 Electric Single Oven
Whirlpool RBS305PDS Electric Single Oven Logo
41 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
