Question about Canon Office Equipment & Supplies
No power to Canon pixma870
No power
Enable usb ports
use this procedure to reset the printer
Hold down the "Resume" button on your Canon printer for one to two minutes, and then release the button. In some instances, this may reset the printer automatically.
  • 2 Unplug the power cable from the back of the Canon printer if the printer did not reset when you held down the "Resume" button. Hold the power button down and plug the power cable back into the Canon printer. Do not release the power button.
  • 3 Press the "Resume" button on the Canon printer two times and release the Canon's power button. The Canon printer resets to the factory settings a
  • Jan 22, 2014 | Canon Office Equipment & Supplies
    How to reset canon ix 6560
    RESET CANON PRINTER
    1, Power off the printer
    2, Unplug the printer's power cord, wait 5 seconds then plug the power cord back in.
    3, Hold the Power button for 6 Beeps
    4, Release the Power Button
    This will reset the printer and should resolve incorrect cartridge detection problems
    Mar 01, 2013 | Canon Office Equipment & Supplies
    My canon MF4412 is power on but display is coming turn the main power on E202-0002
    my mf4412 printer displaying a problem e202-0002 and red button continue burning
    Jun 24, 2012 | Canon Office Equipment & Supplies
    Canon mx860 no power
    We have a Canon MX860 Wireless Printer, Scanner, Copier and Fax in our office. It worked for about a year, and was so simple to setup
    Dial 1-800-243-0019 Canon Printer 24/7 find here Canon Printer Customer Service number 24 hour and booming path to get instant technical support for technical problems.
    May 02, 2012 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
    Fixes for error code B200 on canon bjc 620
    Chances are, the Canon BJC-620 have waste ink full error.
    Solution
    Manual reset for Canon BJC-620
    1. Unplug Power Cable from Power Cord
    2. Hold POWER and FF and Print Mode buttons
    3. While the third hold buttons, plug the power to Power Cord
    4. Release after Heard the sound Beeps icon
    Nov 27, 2011 | Canon BJC 620 InkJet Printer
    CANON ERROR E27
    Canon MP140 Error Code injet printer reset procedure:
    Canon waste ink tank problem.
    1. Change the waste ink absorber
    2. Reset waste ink tank counter
    Go to the service menu;
    1. With the printer power OFF , press the Power button while pressing and holding the Stop/ Reset button.
    NEXT
    2. When the Power is ON, hit the Stop/Reset button 2 times while pressing and holding the Power button.
    NEXT
    3. When releasing the Power button and the Stop / Reset button , the printer will go into a service mode.
    NEXT
    4 When the ON-OFF lights in Green, hit the Stop/Reset button the specified number of times according to the function listed in below.
    NEXT
    Each time the Stop/Reset button is pressed, the LED lights in orange and green, starting with orange.
    NEXT
    Hit 4 times for waste ink counter reset.
    The number of the Reset button pressing LED
    0 time ... Green Power off
    1 time ... Orange Service pattern print
    2 times ... Green EEPROM print
    3 times ... Orange EEPROM reset (EEPROM reset)
    4 times ... Green Waste ink counter reset
    On the end press POWER button to exit .
    FOR USE IN : Canon PIXMA iP1200, Canon PIXMA iP1600, Canon PIXMA iP1700, Canon iP1800, Canon PIXMA iP2600, iP6210D, PIXMA iP6220D, iP6310D, Canon PIXMA MP140, Canon PIXMA MP150, Canon PIXMA MP160, PIXMA MP170, Canon PIXMA MP180, MP210, Canon PIXMA MP450, MP460, MP470, Canon PIXMA MX300, Canon PIXMA MX310, Canon PIXMA MX470
    Jul 31, 2010 | Acer Office Equipment & Supplies
    How to reset error e4
    The reset method work for canon printers that using PG-40 and CL-41 cartridge. After doing this reset method canon printer will not display low ink notification anymore and will not show error code “E4′ or “E5′.
    Here How to Disabling Low Ink Level Notification for Canon IP and MP, the method to reset ink level notification:
    1. Push “resume” for 5 seconds for canon IPXXXX. For canon MPXXX you must enter to service mode.
    2. Push Power switch then remove power cord.
    3. Insert plug power cord while pressing “power switch” at the same time.
    4. Push Start/reset by step 2 continue Wait display shown “0′
    5. Push + change display from “0′ to “1′
    6. Push color button 2 times
    7. Push Power switch again , Printer will print 1 page
    8. Open cover
    9. Unplug power cord
    10. Take out ink cartridge #40 and #41
    11. Insert plug again
    12. Push power switch
    13. Open cover (scan cover)
    14. Insert ink cartridge #40 and #41 again
    Enter to service mode for canon MPXXX
    • With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
    • When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
    • When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
    Apr 15, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
    Would not print, oraqnge light blinks 5 times then one green flash. Open the door to ink and the head does not move to center as it used to.
    This is a waste ink code and needs to be reset. follow instructions below.
    Canon pixma iP90 released almost at the same time with canon Pixma iP 1880. Canon iP90 is printer with single function. Cartidges which used in canon Pixma iP90 is BCI-15BK, BCI-115C dan BCI-16C. Resetting procedure canon iP90 almost the same as manual reset canon iP1880. You can use combination of button in the printer to reset the printer.
    Following step by step resetting canon Pixma iP90 :
    • Before resetting printer canon iP90, start with printer power off .
    • Press resume button coincide with power button.
    • While pressing power button, release resume button.
    • Press resume button 2 times and then release both button
    • Green LED indocator will blinking and then stopped blinking.
    • When the Power LED lights in green, press resume button 4 times.
    • Press power button and the printer power will off. otherwise off, depress again power button.
    • And the turn on the printer again, your printer canon iP90 should be response as normal.
    Please rate my help++++Thanks for using FIXYA
    google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad); google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
    Nov 24, 2009 | Canon PIXMA iP90 Mobile Printer
    29 people viewed this question
    old marine
    old marine
