Question about Vehicle Parts & Accessories
1989 ford ranger running lights dont work headlamps work fine brakelights work fine How do i replace the switch?
Fuses are fine just the running lights and the inst panel lights dont come on
    Master:
  • 755 Answers
Are you getting 12 volts to the headlights themselves ck with a test light , if so then ck your ground alot of times this is the case , I did see both bulbs go bad at the same time ,
Posted on Jan 13, 2015
Whereis thefuseneeddigramlostbook
    Sergeant:
  • 361 Answers
You need to ck to see if you are getting 12 volts to the lights themselves first before you change parts , could have bad wire or fuse ck them first
Posted on Mar 19, 2014
Testimonial: "Fuses and voltage are both where they should be. Don't know what else it could be"
  • jack of all trades ,
    jack of all trades , Mar 21, 2014
    do u have a good ground do a continuity ck on that on the light and body could be a bad wire since you have good voltage to them that is the only thing left ,
    jack of all trades , Mar 22, 2014
    did you just look at the fuses , I had a issues with some lights in the past and did a eye ck on the fuses and they looked good not blown however one was no good I took a test light to the both sides of the fuse and low and behold it was bad , I would switch it out if it is not the ground , they are the only 2 things that is could be ,
82 f250 taillights not coming on. Brakelights and all other lights working...checked fuses..checked wiring.replaced light switch just for good measure nothing.
For your tail lamps, the brown wire shows to be voltage, should go hot when you turn on headlamp switch. The black wire is ground. Use a test light, if you haven't already, check voltage and ground.
The tag lamps use the same voltage as tail lamps.
Nov 05, 2017 | Cars & Trucks
2008 ford ranger headlight relay bad? Lamps do not light up, checked BULBS..OK no left highbeam Left and right lamp fuses ok and hi/lo 30a fuse ok
Did you check the fuse circuit for voltage, use a testlite or something.
I posted part of headlamp wiring. You understand your dimmer switch is involved in the circuits.
Oct 22, 2016 | 2008 Ford Ranger
1979 gmc truck van no brakelights
Check your blinker switch in the steering column. I had an old Ford Galaxy that the brake lights quit working on and it turned out to be that.
Jul 13, 2014 | E92 Halogen Brakelight/Stoplight Kit for...
88 ranger has no head lights or running lights. or dash lights
https://s26.postimg.org/gukptsw7d/headlamps.jpg
Click on the link.
Usually on older vehicles, the headlamps don't use a fuse, but, fusible link, as shown in the diagram. Usually the park lamps and instrument cluster illumination are fuse protected, like the diagram shows, Not only check the fuses, use a test lite to check for voltage at fuse and at fusible link. The wires on top of switch in the diagram are voltage to headlamp switch, the wires on the bottom is voltage from head lamp switch to component.
Usually one of the wires from Battery positive goes to fusible links, at the moment, I don't have location.
Hope this helps, a little. I just want to add voltage and ground both are important.
Sep 14, 2017 | 1988 Ford Ranger
Ok, today I replaced/removed several exterior lights: 1) I replaced the left headlight 2) I removed a burned out bulb from the high mount brakelight (local part store was out of stock, coming in...
I can help you out with the left turn signal not blinking. Maybe it's a flasher or the light bulbs aren't getting current through the wiring.
I can't help you out with the interior gauge lights not turning on when you turn the headlamps on. It may have to do with the headlamp switch, though.
I've never seen the lights on the radio not dim when the headlamp switch is turned on. hm.
Good luck on this repair.
Nov 03, 2010 | 1990 Pontiac Firebird
98 ford lariat. Headlights stopped working. running lights come on and brake lights and turn signals. checked all fuses under dash and under hood, pulled out headlight switch and it looks fine. note only...
Is this both the high beams and low beams that do not work ?
If you checked all 3 fuses with a meter ( with the headlamp in Low position for both low beam fuses or in high for the high beam fuse ), the next items to test are the MFS ( MultiFunction Switch ) and the main headlamp switch ( test not look at it ).
The main headlamp test chart
The test chart for the MFS
Oct 25, 2010 | 1998 Ford F150 Regular Cab
Diagram of where headlamp relay is found on an 88 ford ranger. my headlights won't come on. all other lights work inside and out. i have replaced my headlight switch, but that didn't work. i have replaced...
Your ranger'nt have a relay,you need to check the grounds to each light or you simply need two lights,or a dimmer switch.Check for power with a test light and if you hahe power replace the light,if you don't replace the dimmer switch.
Dec 07, 2009 | 1988 Ford Ranger
Headlights do not turn on at the light switch.
manual headlamps
Visual Inspection Chart
Mechanical Electrical
  • Headlamp switch
  • Multifunction switch
  • Central junction box (CJB) fuse:
    • 7 (30A)
    • 30 (15A)
    • 46 (10A)
    • 47 (10A)
  • Circuitry
  • Headlamp bulbs
  • Daytime running lamp (DRL) relay No.1
Autolamps
Visual Inspection Chart Mechanical Electrical
  • Headlamp switch
  • Central junction box (CJB) fuses:
    • 19 (5A)
    • 56 (30A)
  • Circuitry
  • Headlamp bulb
  • Daytime running lamps (DRL) full relay No.1 (if equipped)
  • Vehicle security module
  • Photocell
If autolamp system, Vehicle security module has a headlamp rela inside of it. under left side of dash.
May 26, 2009 | 2002 Ford F250 Super Duty SuperCab
89 Crown Vic brake lights work when park, not when moving.
Replace, or adjust your brakelight switch located on the brake pedal arm.
Sep 16, 2008 | 1989 Ford Crown Victoria
Vehicle Parts & Accessories Logo
55 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
