CAPS LIGHT WON'T COME ON
I CANT EVER TELL WHEN MY CAPS ARE ON AS THERE IS NO INDICATOR LIGHT
    Master:
  • 397 Answers
As you haven't provided the model I'm not certain your equipment has a caps lock light, as not all keyboard do.
Assuming it just doesn't have one this little piece of software(link below) could be the solution for you, it provides a little indicator in your system tray as to whether caps lock is enabled or not.
Caps Lock Indicator
Posted on Mar 19, 2014
How to know when caps lock is on.
There will be a little light top right corner of your keyboard. Over above the numbers on the right side you'll see two indicator lights there's a number lock light and a caps lock light
Dec 08, 2016 | Video Game Consoles & Games
Have a 42" Tv that won't power up. Power to
The electrolytic caps need change out on the power supply or you can purchase a new remote at www.partstore.com
Sep 14, 2011 | Westinghouse W4207 42 in. HD-Ready LCD TV
My 1998 jeep cheorkee engine turns but won't crank, could it be the computer or what?
it's highly unlikely, there are only two things that can make this happen, not getting fuel (fuel pump failure, fuel pump regulator) or not getting ignition (bad coils, ignition module failure, bad distributor, distributor cap, rotor)
Jun 24, 2011 | 1998 Jeep Cherokee
CANT TELL IF MY CAP LOCKS ARE ON OR OFF WHAT DO I NEED TO SELECT TO KEEP THIS FEATURE
if your caps light is on a light will/should show on your keyboard
hope this helps
http://download.cnet.com/%7Bvalue=http://www.download.com/numcapsscroll-indicator/3000-2072_4-10604212.html
On-screen real-time indicator showing the status of the Num, Caps and Scroll Lock buttons on the keyboard. NumCapsScroll Indicator monitors their status and indicates it in the System Tray with its icon, with a tool-tip when you mouse-over its System Tray icon, with a small On-screen Keyboard-like panel and a sound indicator. It's also an identical utility for laptops that are not supported with Num, Caps and Scroll Lock LEDs on their Keyboards.
What's new in this version: Version 7.0 is compatible with Windows 7.
Apr 06, 2011 | Computers & Internet
CANT FIND CAPS LOCK KEY ON MY AMILO LAPTOP
With the Amilo laptop, it is just the key beside "A" (left side key). Though it is not marked as "Caps Lock", try pressing that key. Once the key is pressed, observed at the light indicator on your lower left part of your laptop where other light indicators are shown.
Hope this helps. Thank you for using FixYa.
Jan 31, 2011 | Computers & Internet
I have a 2006 honda accord sedan.There is a orenge color engine shape sign on the left side (right under the head light sign) in the gauge. I need to know what does it mean?
Think this is your malfunction indicator light -indicates a problem with the emission control system. Generally caused by lose or missing gas cap. Make sure when putting gas cap back on that you turn it (tighten) so that it clicks three (3) times.
Oct 23, 2010 | 2006 Honda Accord
My fuel cap light indicator goes on, what could be the problem?
either the fuel cap is loose, or its not sealing well. try buying another gas cap from the dealer, as sometimes the aftermarket ones don't work as well. basically the light is telling you there is a gross leak in the EVAP system, and the gas cap is the most likely cause. if a new gas cap doesn't fix it, then there is a leak elsewhere in that system and will require special tools to pinpoint the cause
Feb 19, 2010 | 2001 Ford Escort ZX2
Fuel door indicator light remains on.
You may have one of the following.
A loose gas cap - remove cap and re-tighten again to see if light goes out (may take a while before light goes out)
A faulty gas cap - replace with a new one (shouldn't have failed yet if your car's only a year old)
A faulty fuel sensor only if your fuel level also shows as low (shouldn't have failed yet if your car's only a year old)
There's a vacuum leak somewhere (this would also trigger a check engine light)
Oct 06, 2009 | 2008 Hyundai Sonata
Unable to locate indication of caps lock on or off
On the keyboard, there should be an area to the right top that will light up when you click the caps lock button. Typically this key is found above the shift key on the left hand side of the keyboard.
http://www.cnet.com.au/acer-aspire-l3600_images-339286871.htm
Apr 12, 2009 | Acer Computers & Internet
Computers & Internet Logo
101 people viewed this question
David Payne
David Payne
