Question about Panasonic 50 in. Plasma TV
My Panasonic model TC-P50S30 has just stopped displaying the picture - the audio is fine. The unit is just over 2 years old. The red light under the screen indicates power is there. I unplugged the
Is this worth taking in to a repair facility?
    Master:
  • 397 Answers
Of course it is always worth getting something checked out by a repair professional, sometimes it is surprising just how cheaply and easily a problem like this can be repaired. However make sure you take it to a company that offers free investigation and quotation, that way you will have nothing to lose.
Posted on Mar 19, 2014
  • 18 Answers
SOURCE: Power light flashing...TV won't turn on
Two flashes sugests that the power supply is faulty.It will have to be taken in to a service centre for repairs.
Posted on May 31, 2008
  • 31 Answers
SOURCE: Panasonic Model TC - 32LX60 will not come on...red flashing light
hello it sounds like a main board issue but try this number and explain exactly ur issues to them they may say they only give info on parts but trust me just keep working ur way up and ull get some answers 800-833-9626 pannys parts and service their service manuals are horrible and not very much info that is really valuable is included in their service manuals another way to make money imagine that.
c
ill keep researching ur problem let me know if u get anywhere
Posted on Oct 26, 2008
  • 718 Answers
SOURCE: Panasonic 32 inch LCD TV will not turn on-red light flashing
The number of flashes is an error code. Count the number of flash. It looks like one of the boards in your set is failing intermittently. Panasonic codes for a guide as a starting point. Exact board STILL has to be verified;
One Blink: One blink of the power LED indicates a problem in the inverter circuit located on the LCD panel. The inverter board is not to be repaired in the field. Therefore a replacement is required.
Three Blinks: Three blinks of the power LED indicates an over-current or over-voltage condition in one of the DC supplies of the AP board. The AP board is repairable. Therefore the use of an ohmmeter and peak-hold-voltmeter is required to determine the cause of the shutdown. An over-voltage condition is definitely a defect of the AP board. An over-current condition may be due to a short circuit located in the AP board, A board, or the LCD panel.
Five, Seven, or Eight Blinks: The A board is responsible for five, seven or eight blinks of the power LED. The MAIN +3.3V, MAIN +5V, and MAIN +9V sources are all produced on the A board. The detection input pins of the MPU, IC1100, monitor for their presence.
Four or Six Blinks: The AP board is responsible for four or six blinks of the power LED. The DTV9V, and SUB_5V sources are produced on the AP board. The MPU IC1100 monitors for their presence when the unit is connected to AC Power. A short or open circuit on the A board may also be responsible for their absence.
Nine Blinks: Nine blinks of the power LED is due a short circuit in the audio output circuit (s) of the unit. The audio output circuit is located on the A board. Confirm the status of the speakers. If defective, perform a replacement. If ok, replace the A board.
Ten Blinks: Ten blinks of the power LED indicates a malfunction of IC4200, the frame converter. This IC resides on the A board. Therefore ten blinks of the power LED requires the replacement of the A board.
Posted on Feb 11, 2009
ginko
  • 19396 Answers
SOURCE: Panasonic TH-42PD25 power problem
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
SOURCE: Panasonic Projection HDTV Made 9/2003
my problem is that when i turn on my t.v there is the sound that the t.v turns on but there is no picture on the sceen and everything is fully black....
Posted on Jun 25, 2009
Tip
No recompression Cut/Join Panasonic SD900 AVCHD to Plasma TV TC-P50S30 for...
No conversion Split/Join SD900 MTS and Stream and Play on TC-P50S30 1080p Plasma TV on Mac <br /><br />I have a <b>Panasonic HDC-SD900</b> camcorder, which is an excellent compact camera, offering features that few of its rivals can match. It features 1920 x 1080 60p MPEG-4 AVC/H.264 Full HD video. And I would like using my new TV - Panasonic VIERA TC-P50S30 50-Inch 1080p Plasma HDTV for displaying these recorded 1080P MTS videos. And the TV can directly stream/put or <b><a href="http://www.aunsoft.com/final-mate-mac/">display Raw Panasonic SD900 AVCHD MTS to Plasma TV</a></b> for enjoyment via HDMI. Because of rocking of the lens and some pause in the process of recording, some extra clips will come out, so before <b>enjoy Panasonic Videos with Panasonic TC-P50S30 Plasma TV</b>, I want to do simply editing like cutting off unwanted or unimportant parts and then merge or <b>join the cut several meaningful MTS files into One Big MTS file</b> with no re-encoding and without losing any quality. <br /><br />When I search <b>AVCHD MTS Cutter/Joiner</b>, I get batch of programs, like TSmuxer, TSsniper. But it is frustrated for Mac users because most of them can only work on Windows platform. Then one of my friend recommended to a new software for me named <b><a href="http://www.aunsoft.com/final-mate-mac/">Final Mate for Mac</a></b> - an efficient Panasonic HDCam software. It offers the one fastest way to join MTS files into big one for further playing on Panasonic TC-P50S30 Plasma HDTV. Then I download and try it. And I had succeed with the solit and stitch the .mts files and the output one big .mts files without recompression. <br /><br />Now I will show you a fast way to cut off native Panasonic HDC-SD900 1080p MTS clips, and then join them into one file without conversion for streaming and playing on Panasonic VIERA TC-P50S30 50-Inch 1080p Plasma HDTV on Mac OS X Snow Leopard. <br /><br />Step 1. <b>Capture native MTS from Panasonic HDC-SD900 to Aunsoft Final Mate for Mac</b>. <br />Run Aunsoft Final Mate for Mac as the fast <b>Mac SD900 AVCHD cutter/joiner without recompression</b>, and drag the .mts files already backup all mts recordings from Panasonic SD900 to your computer, and can browse the .mts video path and the software will automatically show your AVCHD clips in "Resource Tab". <br /><br />Step 2. Create a Movie for <b>combine SD900 AVCHD MTS 1080p footage lossless output</b>. <br />Click the drop-down button for the Add movie icon and choose lossless output, please drag and drop camcorder .mts clips you would like to merge to this Movie. You can select all files by clicking Ctrl +A, and then drag them to the timeline to join all these MTS files into one movie easily.Thus, one lossless output Movie is ready for <b><a href="http://www.aunsoft.com/final-mate-mac/">merging SD900 MTS files without conversion</a></b>. <br /><br />Step 3. <b>Cut off unwanted parts from 1080p MTS for Panasonic TC-P50S30 1080p Plasma HDTV</b>. <br />From the timeline, you may notice the vernier, which is used as time pointer. Click on the Vernier, and move to the timeline you want to cut, and click the Split button to cut the video. Then select the unwanted or unimportant parts and click Delete. And the Previous Frame and Next Frame buttons can help you locate each frame of the videos and cut with frame accuracy. <br /><br />Step 4. <b>Join and export SD900 MTS with no loss of quality for Panasonic TC-P50S30 Plasma HDTV on Mac</b>. <br />Click the Export button and you click the OK button, the Mac MTS/M2TS cutter/joiner for Panasonic Plasma HDTV will start lossless mts output - merging large .mts files into one mts without conversion at the fast speed. The non-conversion process will prevent loss of quality when <b><a href="http://sony-mts-converter.com/2011/06/no-conversion-splitjoin-sd900-mts-to-play-on-tc-p50s30-1080p-plasma-tv/">Mac joining SD900 1080P MTS files for Plasma HDTV</a></b>. <br /> <br />Hope you enjoy the simple merging Panasonic SD900 1080P MTS process with Aunsoft Final Mate for Mac to <b>stream re-encoding 1080p mts for Panasonic TC-P50S30 1080P Plasma HDTV</b>. <br /><br />Tips: With this Panasonic HDCam Manage Software - Final Mate for Mac, also can convert SD900 1080P MTS to AIC MOV or ProRes MOV and edit on iMovie,Final Cut Expres s and Final Cut Pro.
on Jun 08, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Panasonic TC-P50S30 has no picture was working fine then picture went out solid red power light no blinking doesn't turn off w remote no more for a while whites would have purple specs before warm
If you wish to get some details; check the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jun 29, 2016 | Panasonic Televison & Video
Panasonic 50 inch plasma th 50px80ua tv won't turn on and red light flashes seven times
Hi Steve, The link below is a YouTube video showing a panasonic television with 7 red flashes, Also there's videos down the right side of the link that may help as well... I hope this helps............CHEERS..
Panasonic TC P50S30 review seven led flash
May 01, 2016 | Panasonic Televison & Video
Why does my Panasonic Viera VT50 have no picture and red led blinks 3 times
First thing, check the HDMI input and make sure it is firmly connected, same for the power cable, obviously. My Samsung goes similarly nuts if it detects no signal from the currently selected input but after 1-2 minutes it eventually stops and I can change the input source.
Aug 13, 2014 | Panasonic Smart VIERA TC-P55VT50 55" Class...
No picture on my Panasonic TV
Please unplug all HDMI cables from the TV and test a different electrical outlet. If the problem persists, please use the below link to locate an authorized service center in your area.
Where to Service Panasonic Products
Mar 13, 2014 | Panasonic TC-P50S30 VIERA 50 Class 49.9...
Panasonic DVD-S35S is playing DVD's heavy green tint on Panasonic Plasma HDTV TC-P50S30
The DVD should be checked on a different set to make sure that it is the problem.
Mar 11, 2012 | Panasonic DVD-S35S DVD Player
TV code for Panasonic TC-P50S30
Check the dish network website or panasonic web,,support,,,,they should have or website of the brand of remote u programing ,,,goodluck
Dec 23, 2011 | Panasonic Televison & Video
I purchased a Panasonic TC-P50s30 50" Plasma TV
You did a good thing; really!! Keep that TV aside you always.
Jul 11, 2017 | Panasonic 50 in. Plasma TV
Panasonic 50 in. Plasma TV Logo
74 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
