Question about Honda 98 99 00 01 02 Accord Ac Compressor 4 Cyl
Transamission p0700 p0780 transmission problems
2 Suggested Answers
futrueneuman
  • 75 Answers
SOURCE: no reverse. What are the probable causes of DTCs P0700 and P0780?
I own a 2003 ODY & frequent ODYCLUB.com forums for answers.
General opinion is when these trannys go out, it happens quickly.
But, it never hurts to know your issues and options before taking a dealer mechanic's word.
1. Codes for Low transmission fluid: P0730 & P0780
2. P0700: Sorry, but a dealer has the HONDA diagnostic tool to find the real problem code. P0700 is a generic "transmission error" code used by after-market diagnostics.
3. Check if your "D" is lighting up on the shift indicator.
Here are some helpful links from the ODYCLUB Forum:
Note: Always check for healthy orange colored tranny fluid before re-filling. Black is BURNED and needs replace & might indicate clogged screens or worse.
Posted on Dec 16, 2015
I get code p0700 on 2004 dodge ram 1500 4.7 lt.
transmission system malfunction can be a few things the following links give some examples of different problems associated with p0700 code but more than likely if their is a noticeable problem than may have to have it diagnosed by a transmission shop
P0700 Transmission Control System Malfunction P0700 Dogge Ram Yahoo Video Search Results 2005 Dodge Ram 1500 transmission codes p0700 p0841 Transmission Automatic...
Aug 05, 2016 | 2004 Dodge Ram 1500
No reverse. What are the probable causes of DTCs P0700 and P0780?
Dec 16, 2015 | 2002 Honda Odyssey
What is the cost of overhauling transmission?
with a fault of "problem in transmission control " this is a very general fault , but a good transmission shop that deals with Honda's might have access to a borrowed control module to test it out , who knows you might have to only buy one of these not an entire transmission , accord to transmission's dot com a 2ooo Honda transmission lists for 1253.00 dollars rebuilt ones go for about 2/3 that price
Dec 01, 2015 | 2000 Honda Accord
How to fix the automatic transaxle malfunction
Possible causes of OBD code P0780
- Low transmission fluid level - Dirty transmission fluid - Faulty shifting solenoid valve - Shifting solenoid valve harness or connectors - Shifting solenoid valve circuit is open or shorted The Error code is generally activated on detection of the following conditions: The P0780 codes is detected when no rotation change occurs between input (turbine revolution sensor) and output (revolution sensor) and shifting time is long or when shifting ends immediately or when engine revs up unusually during shifting.So check out these points and see if any are all help keep me posted
Sep 20, 2014 | 2002 Honda Accord
Code p0700 & p0780
need to have your tranny rebuilt.
Apr 16, 2014 | 2005 Volvo S40 T5
Need help on p0730,p0780. I have a 00 Acura TL 3.2
code p0730 refers to incorrect gear ratio.==causes --wiring--TR sensors/switch--shift solenoids--transmission mechanical fault
code p0780 refers to gear selection--shift malfunction====causes--wiring--TR sensor---shift solenoids--transmission mechanical fault.. have the shift solenoid checked out. Have a pressure test done on the transmission to check for internal damage.
Nov 12, 2013 | 1999 Acura TL
Poor connection
code P0730 TCM A/T SHIFT CONTROL SYSTEM.possible cause PCM detected the lockup clutch did not lock or unlock correctly. code P0780 automatic transaxle malfunction.
Nov 04, 2013 | Honda Accord Cars & Trucks
P0780 Shift Malfunction five hundred
Here's a link to code P0780,it doesn't pin point what is causing the problem,will have to troubleshoot as it says. P0780 OBD II Trouble Code
Sep 07, 2013 | Ford Cars & Trucks
I have a 2002 honda accord, V6 with 42,000 miles,,,yes,,,42,000 miles The check engine light went on, the dealer checked the code "p0780" Replace transmission. Can this be right?
The code you have P0780 is an internal hydraulic problem in the transmission. I did some research on this trouble code and the repair manual Say's to replace the torque converter clutch solenoid valve/shift solenoid valve A, and the A/T clutch pressure control solenoid valves A and B.
In plain English these are the shift solenoids and torque converter solenoids. These solenoids control the fluid flow to the transmission and if they are not working properly then p0780 will set.
The bad news is the repair manual Say's to replace these solenoids and if the problem is still present then replace or overhaul the transmission because the problem is internal.
Most repair shops are not going to take the risk and just replace the solenoids, they will replace or overhaul the transmission.
Feb 15, 2011 | Honda Accord Cars & Trucks
Honda 98 99 00 01 02 Accord Ac Compressor 4 Cyl Logo
29 people viewed this question
Top Honda Air Tools & Compressors Experts
John Trevino
Renee Knafel-Bullock
Are you a Honda Air Tool and Compressor Expert? Answer questions, earn points and help others
