Question about Proform Sport 1000 Folding Treadmill PFTL91205 - !
Treadmill incline off it's track
My treadmill is stuck in incline mode and continues to try to keep going higher. I have pulled the cover off and found that the track that the incline runs on has been pushed past the teeth/gears to the edge of the track. How to I get it back on the teeth without damaging it?
I have the same problem as it continues to go higher without reversing. First note that when it does go back down it will drop with the whole weight of the unit so keep your hands clear. Unplug of course and straddle over the motor housing, grab both outside corner of the belt/table and slightly pull up and wiggle the arm with the teeth and the arm with the motor pivit indpendantly so its just a matter of realigning it and it will drop at the way down, (carefull its heavy and will drop hard so may be a good idea to put a few books of something stuffed under the sides to block it from dropping and possibly smashing your finger). Youll need to recalibrate, on the back of the motor panel is a spec sheet for techs, it has the recalibrate procedure on it. I just went through all this I have a problem with mine now reading the photo switch I think.
Posted on Mar 19, 2014
  • 14 Answers
SOURCE: Pro-Form Sport 1000 treadmill does not stop inclining
Do a Calibration on the treadmill. Take out the safety key. With 2 fingers, hold down the stop button and the speed up or spped plus button. keep holding them down as you insert the safety key, then let go of both.
Press the stop button 1 time, you should see all 0's in the windows, or EP 2P or something weird like that.
Press the Incline up button and then wait. If the incline go up until it stalls then down until it stalls the stops at the bottom, the you are recalibrated, take out the safery key and put it back in to see if all is well. If the incline takes off up again without touching a button, the you have wiring problems or control problems. Call service company to get it repaired.
Posted on Apr 29, 2009
erpaalai
  • 999 Answers
SOURCE: My Proform treadmill will not incline. It is stuck
Under the hood there should be a tech sheet with calibration instructions. I have not worked on these for several years or I would rattle off the procedure. If the sheet is still there make sure you put it back in the plastic sleeve for next time..... Eric
Posted on Jun 17, 2009
SOURCE: Proform 740CS runs okay but the incline does not
ProForm Treadmills have a reset procedure for the incline function. With the key inserted in the console, activate the incline; while the incline is changing, remove the key. Wait 30 seconds, then replace the key. The incline should to maximum, then to minimum, resetting its limits. It worked for mine just 10 minutes ago; the procedure is in the manual if you have it. Good luck!
Posted on Apr 18, 2010
maxtreadmill
  • 832 Answers
SOURCE: The incline on my proform treadmill is not working
ICON CALIBRATION INSTRUCTIONS- INCLINE
1) Press the Stop and the Speed Up keys down while inserting the safety key.
2) Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
3) Press either incline key and the incline will calibrate automatically.
4) THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED.After completing calibration of incline, press the Stop key and then remove the safety key.
If the incline moves but you it will not operate normally nor calibrate, check the wiring from the incline sensor to the power board. If all looks normal, put it back in calibration and see if you see a blinking “- -” symbol in the incline window when you are calibrating. If not, the incline sensor is bad.
If the incline moves but only just a bit, it could be a problem as simple as the gearbox on the motor being jammed. We remove the motor from the treadmill, reconnect the wiring, and then try to run the incline motor outside the treadmill. Many times, this will unjam it if that is the problem and then reinstalling it in the treadmill will get it to work. If you have the same problem or it doesn’t run outside the machine and you can hear it try to work, you need to replace the incline motor.
If the incline motor does not move, we need to figure out if the motor is getting voltage. Use a simple multi-meter and set it to AC volts. When you put it into calibration, it tries to calibrate the directions one at a time. Measure across the white and black wires first, then measure across the white and red wires second. If the motor is getting voltage you will read 120VAC (or
thereabouts) one one of the measurements. If you have voltage but the motor won't move, you need to replace the motor.
4.
If the incline motor does not move and you have done the voltage test and you do not have any voltage present, there is a problem in the electronics board that supplies the power. If the console is powering the drive motor as normal, you can bet it is getting an incline signal and the power board needs to be replaced (some models have an integrated power board/controller) so if there is only a single board the whole board has to be replaced. It is possible the console is not giving the proper signal but we've never seen it happen in thousands of treadmills.
Posted on Jul 19, 2010
  • 34 Answers
SOURCE: my treadmill is stuck at the highest incline and
Although it is fairly rare the incline motor can jam up into the highest position and get stuck there. To fix this take off the plastic hood that covers the incline motor and depending on the motor you should be able to wind it with your hand out of the highest position. When it is out of the highest position run the calibration as described in the owner's manual and it should go all the way up and all the way down. If it is not this type of motor that can be wound by hand then the first and last thing to do is to try calibration of the incline as described in your manual. If this does not work then a new incline motor is needed.
Posted on Aug 18, 2010
Proform 590Qs treadmill stuck on incline
You've to check the incline and decline limit switches also the incline motor
If you wish to get some details about treadmill repair and service ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Sep 01, 2016 | Proform Exercise & Fitness
C2250 treadmill incline recalibration - incline goes up, not down
Plug the power out and plug it back in after a count of 50 could be that it needs to be reset .then plug back in the power and see what its doing if no luck go to manual and look for reset
Jan 06, 2014 | Nordic Track Exercise & Fitness
Incline reads 0.0 but is not all the way down
Renee, Here is how to recalibrate the incline motor. Read all of it It will be good to keep.
Plug in your treadmill, do not stand on the walking belt. Hold down the "Stop" and "Speed +" key and insert the safety key or magnet, let go of the two keys. Now press "Stop" key once. This puts you into the level 2 of calibration. Press the "Speed +" key slowly until you see 85 on the console, (at this point the display is going to show the percentage of motor usage and also the actual walking belt speed) at 85% motor usage your top speed should be between 10 and 10.5 MPH or (of 12 and 12.5) depending on the treadmill. You must know your treadmills top speed. (Important the motor may be damaged if you set the maximum speed higher than the maximum speed that your treadmill is made for). If the speed is higher than 10.5 or 12.5 then you need to turn the potentiometer down to the correct level. If the speed it to low you need to turn the potentiometer higher. Once the speed is correct you are done calibrating the speed. Press the (-) speed key to lower the percentage to (0). Next press the incline (+) button, this will make the incline motor go all the way to the maximum incline and come all the way down to the level position. Then remove the safety key and the treadmill will reset into the normal manual mode, when you re-insert the safety key. Matt
Dec 04, 2011 | Nordic Track NordicTrack Treadmill, A2550
Nordictrack COmmercial 1500 console buttons don't work
http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitnes
11_17_2011_8_43_24_pm.gifsincerely. Please keep me in touch.
Nov 17, 2011 | Nordic Track NordicTrack Commercial 1500...
The treadmill is stuck on "incline." Any time we put the red key on it to turn it on, it just keeps moving up and down from 0 incline to 10. It does this over and over again without stopping. No...
I can't solve this, but my Nordic Track T5 zi occasionally does the same thing. The previous two times, I waited until the unit "bottomed out", and then pulled the mag switch (key) off. I unplugged the unit, then plugged it back in, attached the key, and all was well. This worked twice before, but today (3/8/2011)the unit's incline is cycling again, and the old fix isn't working. Maybe it will need to go back to Sears! Unit was purchased in October of 2010. Frustrating.
Jan 30, 2011 | Nordic Track NordicTrack T5 zi Treadmill
Nordic Track A2250 Pro stuck inclined
My Nordic Track Treadmill A2250 is stuck on the 12% incline position and it wont go back down and I have tried to reset it by turning it off, switching the reset button to off and then on or even unplugging it several times. What would be my next move?
Apr 05, 2010 | Nordic Track NordicTrack Treadmill, A2550
Hello I have a Nordic Track A2050 treadmill and it has worked flawlessly till today, The unit was open (unfolded) and I wanted to close it because I nearly killed myself tripping over it, so I turned it on...
Hello there, The machine is attempting to do an incline calibration. Keep the unit lowered as you have it, reinstall the safety key, allow the unit to go all the way to the top and then all the way to the bottom. The machine will stop when at the bottom and the screen will go back to normal. The machine will not overtravel the incline motor and damage it. Just let the calibration finish the procedure and you will be fine.
Good Luck! Tim
FYI this will happen anytime the safety key is removed while the incline is moving on nordictrack brand machines.
Jan 11, 2010 | Nordic Track NordicTrack Treadmill, A2550
I have a Nordic Track EXP1000i Treadmill. The
I know it's been months, but, if you still have this problem try this: 1. remove the philips screws holding the motor/belt/electronics cover on: you can lay the whole thing on it's side and remove them from the bottom. there's two in the front and two on the sides.
2. Obviously, unplug the unit! before doing anything. lay the unit back on it's feet (normal position)
3. Find the incline motor assembly. it will be int he middle of everything. black tube thingy.
4. take a cordless drill with a flat head screw driver bit, and turn the incline motor CCW. until the bed is flat.
5. what what I have read, you should shop for a new incline sensor. these fail before the motor does.
Oct 22, 2009 | Nordic Track Exercise & Fitness
Incline stuck- keep going up and dopwn. Treadmill
I had the SAME problem, several times, with my NordicTrack A2250 Treadmill.
Allow it to go fully up and then fully down several times, without turning it off. IT seems to "cycle" that way 3 times and then "reboots" itself and starts working normally, again.
I had to figure this out myself... none of the suggestions I read worked.
Oct 05, 2009 | Nordic Track NordicTrack Treadmill, A2550
The Incline is stuck at an angle
Check the motor and the gears that run the unit up and down. If is located on the front of the unit under the face plate. make sure everything is power everything. Also check the gears to make sure they did not break and check the tracks to make sure it did not fall off the track causing it to stay up
Feb 21, 2009 | Epic View 550 Treadmill
Proform Sport 1000 Folding Treadmill PFTL91205 - ! Logo
95 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
