Question about Motorola XTS3000 Two Way Radio.
How to change a xts3000 from analog to digital
Radio has frequencies in it but i need it to work on digital
  • Official Brand Answer
  • 3,100 Answers
Manuel
Contact Get Support for assistance.
Mark
Motorola Mobility Support
Posted on May 07, 2015
DEWLP have moved over to digital. Where can I find the frequency for a chanel
if it has changed to digital you will need a set top box to make it work on analog tv
Jul 04, 2017 | Radio Communications
I bought a baofeng uv5r and want to link it to my work radio which is a vertex standard vx160u..I can transmit from the work radio to the baofeng but cant figure out how to transmit back to the vertex
First of all, technically, you can't use this radio to talk to anyone other than ham radio- that being said, if you want to proceed at your own risk. Ok, is your work radio an analog radio? Is it narrowband FM? Is it digital MOTOTRBO? Last two will make if difficult. Digital is impossible. Next, find out the exact transmit and receive frequencies for your radio. They may not be both the same if you have a radio 'repeater' your input frequency could be 5MHz higher than your receive frequency. And last- you need to know if your system has a "PL" tone (CTCSS, or DCS) subaudible tone that will break the squelch. So there are several variables that you will need your plant supervisor to relay to you. Good luck. You can probably get much of this info on line from radio reference.
Apr 30, 2017 | Vertex Radio Communications
Puxing px 777
I would check the mic hole in the face of the PMR_2 to verify if there is anything covering it IE. tape stickers debris wax paint anything of the like. Also if the radios are digital, they may use a DPL code. If you have the computer program to set the frequencies and associated programming cables, connect them to a computer with that same program and verify the frequency output they need to be the same frequency. Also, they may use a DPL code ( channel encryption code that keeps channels private on a common frequency) if so they need to be the same. If they are analog then you check the frequency and the TPL code if it has one. All codes/ frequencies must match for communication to happen between the radios.
Jan 25, 2014 | Radio Communications
Frequency guide
While looking up local listing will take a little leg work, These links below will give you some great starting points.
Just remember, agencies will change frequencies, Hardware, and radio types from analog, to digital, to trunked.
Also web sites may not have most up to date listings, Id also suggest local amateur radio aka Ham radio clubs. some of the guys there may be able to help you out as well.
Best of luck and SCAN ON! :) Enjoy
http://www.radioreference.com
http://www.interceptradio.com
http://www.nationalradiodata.com
Sep 05, 2013 | Uniden BC72XLT Handheld Scanner
Won't trunk track. Searches frequencies, but will not scan talk groups.
This radio will only work on analog trunked systems, if it is a digital or P25 system, you need to upgrade to a digital scanner like the PRO96, or newer.
Jul 13, 2010 | Radio Shack Pro-94 Scanner
POLICE SCANNER FREQEUNCIES
finding the frequencies is pretty straight forward...
here's one easy solution..The simplest way is to GOOGLE.
go to google.com
enter "radio frequencies" and your county name and state..
you'll get the links to posted municipal services' radio freq's.
Then simply enter them into your scanner memory...
If you need the "10 codel" definitions, you can get those too so that you'll fully understand what all their abbreviations mean...
Have fun..
Apr 12, 2010 | Radio Shack Pro-97 Handheld Scanner
I wanna hear phone conversations
Cell phones: forget it; most are digital, most scanners block out the frequencies, and they made it against the law. Only analog cellphones on radios made 10 years ago were receivable. That being said, IF you have an older cordless phone (analog), try searching the 46MHz and 49MHz bands; there were also some analog cordless phones in the 920MHz range, but of course, you wouldn't want to listen to any of those frequencies that I've mentioned.
Jan 16, 2010 | Uniden BCT8 Base Scanner
All we are getting is a pixilated screen and no sound. Dvd's play normally
OK. This should be simple. If you are using a TV with a built in digital tuner like all the HDMI ( High Defintition Media Interface) flatscreens then you probably need to go through your set up menu on your Digital TV and select Initial Setup / Channel Input / Cable / Satellite if coming directly from a dish on 75 Ohm Coax / or Cable if coming directly from the outside 75 Ohm coax with analog signal. ( When I say DIRECTLY, I mean you are not going through any boxes and changing or passing the signal). All satellite direct connects are digital and all satellite converter boxes have multiple out puts these days. There is an HDMI output for high def and low def analogl to digital (A/D) signals coverted within the TV, sometimes there is a DVI or even a USB out put connector...and there is a 75 Ohm coaxial RF cable connection for all the old schoolers who do not have a widescreen digital TV. RF means Radio Frequency and uses Radio Frequency Channels 3 and 4 at the bottom of the RF band around 56 MHz to which any TV with an Analog Tuner can use. In the old days this is what was used for the connection to the TV from the cable boxes because our TVs did not have the capability of decoding analog pay channel signals, hence the little black boxes sold and used ONLY by cable thieves and not any of us here on fixya. For starters, let's make sure you are using your high def, dvi. or some format of digital It sounds like your TV is set up to search and code digital signals but is looking for the wrong carrier frequencies, meaning it is either looking for decoded digital satellite box signals, digital broadcast ( New Digital TV received via an Antenna). Once your TV scans for channels in the cable mode they will be memorized and available on your channel up / down keys and Favorites. (FYI t will scan for both digital and analog channels on antenna mode). Repost if you have troubles or refer to your users manual.
Aug 17, 2009 | Televison & Video
Want to convert analog police scanner into digital
Some scanners are capable of digital (APCO25). The BC248 however is not. You'll have to buy newer equipment.
Apr 16, 2009 | Uniden BC248CLT Base Scanner
Locked police frequencies
Have you tryed to unlock the frequences? I know that not to long ago a lot of things went digital and some of my feqencies had changed. you may to get the new ones.
k.ditterline@yahoo.com
Sep 07, 2008 | Uniden BC60XLT-1 Handheld Scanner
Motorola XTS3000 Two Way Radio. Logo
124 people viewed this question
Top Motorola Cell Phones Experts
Computer Repairing
Computer Repairing
Trisha
Trisha
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
