Question about Samsung B550 Series S23B550V ToC 23" 2ms GTG Widescreen LED Monitor
Samsung s23b550 monitor doesn't work with right resolution
I'm trying to connect a samsung s23b550 monitor to a macbook air (running mavericks). The monitor only displays an image when I have it set (in my computer settings) to 720p, which is not the native resolution. When I try any other setting, like "best for display" or 1600x900, the "correct" image will show up briefly before the screen blacks out. I've tried every combination of settings I can think of in my computer and the monitor with no luck. I've tried Samsung's recommended self-test which indicates the monitor is fine. Any ideas what could be wrong?
    Top Expert:
  • Samsung Master
  • 22,133 Answers
Your monitor does not support the resolution capabilities of your superior Mac.
Posted on Mar 19, 2014
  • Creed Thots
    Creed Thots Mar 19, 2014
    That doesn't sound right at all. The optimal resolution for the monitor is 1920x1080. The only resolution that actually displays an image is the lower 1280x720 resolution.
frankzjm
  • 191 Answers
SOURCE: Samsung 244t Monitor display issue
if the monitor will match well with Nvidia GTS8800 graphic card, you need to consider two issue:
1) resolution match from windows display property and moniter manu same one.
2) refresh frequency match from windows display property-->advance-->monitor and monitor manu--> refresh frequency
if two side setting could be all matched that you can use normally
if two side setting could not be matched any above step that you can not use some resolution normally possible.
hope help you something fixed, please take a rating let me know how much helped you thanks! keep in touch your question
Posted on May 29, 2009
ruwidperd372
  • 279 Answers
SOURCE: Samsung T220HD will not work with Dell Latitude
Change the Screen refresh rate to 60Hz. Go to Control Panel> Display> setting> advance> Monitor, change to 60 Hz.
Posted on Apr 10, 2010
samuelseno
  • 103 Answers
SOURCE: Cant detect 1600 x 900 on control panel - display
You need to install the driver for your samsung sync master 2033, so the the graphics will improve or updated.
Posted on Jun 04, 2010
  • 80 Answers
SOURCE: Samsung 204T no longer displays
Often problems with LCD monitors can be traced to bad capacitors. The following sites will help you identify if your monitor has bad capacitors, and how to replace them.
www.fixyourmonitor.com and http://www.youtube.com/watch?v=9Q6_TgNJvQw
Good Luck!
Posted on Jun 13, 2010
  • 3 Answers
SOURCE: I have a samsung 2033SW
- You can test the monitor by using another CPU, if still the same then the problem is monitor, but if it's working well then the problem is your CPU, to make it sure then you can try another monitor on your CPU. - check if the hardware connection is well attach, you can pull & re- plug the hardware just to make sure. - the monitor is need a DVI connection (white or gray) to run properly, if you use AGP connection ( blue ) on your VGA card that might the problem, so you can also try upgrade your VGA card. - other ways is to install the latest driver for your VGA card.
Posted on Jan 14, 2011
Visco LCD TV VSC-32V3 32
Did you check the cabling correctly
May 20, 2008 | Televison & Video
Transfer music to i Tunes
mavericks is finicky. what machine can you connect it to? try reinstalling iTunes. be sure to back up your music and files first.
Mar 07, 2014 | Archos Vision Audio Players & Recorders
How to install an usb2.0 fast ethernet adapter
I couldn't find the manufacturer with the part number you listed. I'm thinking it's probably not yet supported in Maverick. I"m assuming since you have a MacBook Air you had to download the drivers from the manufacturer's website. Does it list that Mac OSX 10.9 is supported?
Feb 15, 2014 | Apple Air Computers & Internet
Error 20 on Paint it
I just tried the latest version on My MacBook Air running 10.9 Mavericks and it crashed on launch. Will have to wait for an update from Corel!
Dec 01, 2013 | Corel Paint it
When I plug in my MacBook Pro (Mid 2012) via Mini-display to HDMI or even VGA the color of the Samsung TV changes color (Super Saturated). Oddly enough when I BootCamp into Windows 7 via same connection,...
There are issues with OSX on some monitors. On Lion and older OSX, you may get better results by playing with your Macbook screen settings and resolution. OR I found many of these issues were addressed when I upgraded to OSX Mavericks (free) it now handles external displays and resolutions much better. But you might simply have inadvertanly set the wrong color profile. Go to Finder: then System preferences then Displays. Choose the Color tab/button and select one of the color profiles or choose calibrate and follow the prompts
Nov 05, 2013 | Samsung LN-T1954H 19 in. LCD HDTV
I am running OS X 10.4.11 and would like to upgrade my operating system?
Please provide more information.
To what would you like to upgrade it?
Since OSX Mavericks was just announced, I'm going to assume that's what you're wanting to upgrade to.
Not all Macs can run Mavericks.
Mavericks Capable Macs
Mavericks, like its predecessor Mountain Lion, requires one of the following Macs with at least 2 GB of RAM and 8 GB of available hard drive space:
  • iMac (Mid 2007 or newer)
  • MacBook (Late 2008 Aluminum, or Early 2009 or newer)
  • MacBook Air (Late 2008 or newer)
  • MacBook Pro (Mid/Late 2007 or newer)
  • Mac mini (Early 2009 or newer)
  • Mac Pro (Early 2008 or newer)
  • Xserve (Early 2009)
If your Mac isn't one of the ones listed above, you won't be able to upgrade.
If you have an iMac, MacBook, MacBook Pro, or Mac mini model that was originally released in Early/Mid 2006, the latest version of Mac OS X your system supports is Snow Leopard.
http://store.apple.com/us/product/MC573/mac-os-x-106-snow-leopard
Oct 23, 2013 | Computers & Internet
HELP! bought a BX2450 Samsung monitor and it`s not showing full resolution, i need a driver for my macbook pro 13` (mid 2010) anyone????
I have a very strong suspicion that you are connecting your Macbook Pro to the VGA input on the monitor instead of the HDMI.
Your Macbook Pro uses the Mini Displayport connection type. Are you using a Mini Displayport to HDMI adapter? If not, purchase one and that will resolve your issue.
If you are already using a Mini Displayport to HDMI adapter, make sure your resolution is set to the maximum (1920x1080 according to Samsung's website) in Apple Menu > System Preferences > Displays > Display.
If available, select the 'Best for Display' option which should automatically set the maximum resolution for the display. If not, select 'Scaled' and choose 1920x1080.
Sep 04, 2013 | Samsung BX2450 LCD Monitor
Monitor rotation from MacBook Pro
Go to system preferences > displays, then there's an option to rotate the display. You'll also need the corresponding cable to connect it. Enjoy the mac!
Dec 11, 2012 | Samsung SyncMaster 2493HM Monitor
Change the resolution on my Samsung B2030 LCD Monitor
1600X900 is a higher resolution than that of 1280X1024. Therefore 1600X900 is a better resolution. If you would like to run at the lower resolution simply right click your desktop screen and click properties. Then on the settings tab use the slider bar to adjust the resolution. Lower to the left and higher to the right. If the desired resolution is unavailable then you could try downloading and installing the latest drivers for your graphics card installed in your computer.
Your card will either be AMD/ATI Radeon or Nvidia. You will need the model number of the graphics card, the latest drivers may increase resolution support for your card.
Also look on the bottom right hand side of your screen for an Nvidia Control Panel logo in green. Right click it and select the option to "change screen resolution" This may provide you with additional resolution options.
Take care!
damnor01
Nov 02, 2011 | Samsung B2030 LCD Monitor
Samsung B550 Series S23B550V ToC 23" 2ms GTG Widescreen LED Monitor Logo
157 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
