Question about Refrigerators
My double door bar style true gdm33cpt54 isnt cooling below fifty and there is ice all over the copper lines and the motor runs constantly?
  • 60 Answers
Thats normally caused bye either too much or too litle gas
Posted on Mar 20, 2014
  • 213 Answers
SOURCE: refrigerator stopped cooling
the back panel inside the freezer has screws in it. take out the screws to remove that panel. the coils are behind that. melt all the frost. youll see one or 2 heating elements in there also. replace the elements. its a common ge problem. this will fix the problem
Posted on Nov 28, 2007
DOREEN1
  • 51 Answers
SOURCE: cooler wont cool below 48 degrees.
Keep a thermometer handy. (adjust temperature control knob accordingly)
Periodically monitor temperatures inside your cooler. (adjust as necessary)
Keep the refrigerator door closed as much as possible to avoid temperature fluctuations
The temperature of the refrigerator compartment is
controlled by adjusting/setting the thermostat control
knob, located on the ceiling of the refrigerator
cabinet.
To start the refrigerator, and achieve maximum
cooling quickly;
• Turn the temperature control knob (using a coin
or screwdriver) clockwise to the furthest
(maximum) setting on the darker blue section of
the graduated control dial.
• Allow the refrigerator to run at this setting for 3~4
hours.
• When maximum cooling is achieved, turn back
the temperature control knob setting to the 2:00
o'clock position on the graduated blue control
dial.
• Correct cooling temperature is a key factor to
consider in storing and dispensing draught beer.
• Optimum temperature for serving draught beer is
between 34ºF ~ 38ºF.(1ºC ~ 3ºC)
• To maintain temperatures ranging between
34ºF ~ 38ºF.(1ºC ~ 3ºC) We recommend the
thermostat knob be positioned at the "2:00
o'clock" setting on the graduated blue control dial.
• To turn off the refrigerator, (no cooling) rotate the
control knob to the "0" position.
Posted on Jan 31, 2008
aborcass
  • 2651 Answers
SOURCE: Amana double door freezer side is not working
you can visit the local applaince dealer. frost on onle the top few coils is an indcation of a low charge, restriction of freon, or inneffceint compressor, after 10 years wouldnt image that would be a worth while repair, way expensive here where i am lookna t 500 or so.
Posted on Mar 16, 2008
SOURCE: HOOK UP OF ICE MAKER TO THE WATER LINE
The ice maker is not making any ice, or water or crush ice. The wheel that crushes the ice will not spin. Please help
Posted on Aug 19, 2008
  • 274 Answers
SOURCE: True GDM-12 - Unit runs, but won't cool below 60 degrees,
Is it very hot out side the unit.recharging may not hurt is it cleaned the lint could be trapping the radiator were the coolan goes through to cool down try cleanning underneath before recharging
Posted on Jul 26, 2010
No ice refrigerator freezes runs constantly
SOME OF THIS NEW REF THE FAN WILL RUN CONSTANTLY IS NORMAN THEY USE VERY LITTLE ELECTRICYTY TO KEEP THE COPRESER FROM RUNING TO LONG.PART OF THR ENERGY STAR. THE ICE MAKER MAY BE BROKEN OR NOT GETING WATER. OTHER TINK CK THE ICE CREAM OR FROSEN JUCES TO SEE IF THERY ARE FROZEN HARD IF THE ARE SOFT THE MEENS THE FREZER IS NOT COOLING GOOD AND I/M WILL NOT MAKE ANY ICE IF IT NOT BELOW 10 DEGREES
Feb 21, 2012 | Maytag MFI2266AES Stainless Steel Bottom...
I have a true 2 door freezer with bun rack rails...it is runninig between 7 degrees up to 59 degrees...we vacumed the vents...do we need more coolant or what do you think...it is about 4 years old and...
Vacuuming the coil is not usually sufficient to clean them properly. Hold a flashlight behind the radiator on top of the freezer to see if you can see freely through the coils. If not, the best way to clean the coil is to spray coil cleaner on there and flush with plenty of water. It is a mess but it will get the grease off the coild. If you do not have gauges to check the pressures of the refrigerant (lets call it freon), you can get a good guess by doing the following: Get a ladder, climb up so you can see in the top of the cabinet where the compressor is located. It looks kind of like a bowling ball. There will be one small copper line and one large copper line running from the compressor. The small line is the high pressure line. It should be hot enough to burn your finger. It then goes through a small pan where it evaporates excess water, then to a "radiator" which has a fan running behind it. If the machine is running this fan should be on. The small line then runs into the freezer box. At this point the line should be warm, not hot to the touch. If this is not happening you are probably low on freon. The other copper line on the compressor is returning from the freezer box to the compressor. It should be very cold to the touch. It should have moisture collection on it. If this is not happening you are probably low on freon. Other factors can effect your freezer. Make sure the fan near the compressor is running. Make sure the fan or fans inside the freezer are running. They will stop running when you open the door, so hold the door button in when you check the inside fans. Check also to see if there is a build up of ice on the inside coil. Your freezer should run a defrost cycle 4 times a day to remove the ice. If it has ice it will not run properly. If you can remove your product for 24 hours and shut the freezer down, prop the door open and the ice will melt. On restart if the freezer goes down to 0 quickly (30 minutes) it was probably frozen over. This may indicate a bad defrost timer or heater. Try these things.
Sep 08, 2010 | True Freezer TG2F-2S
My true back bar cooler dosent cool it is not iceing over
If you can gain access to the compressor, you will see 2 copper lines going to the compressor. One is smaller than the other. VERY CAREFULLY lightly touch the smaller line while the unit is running. If the compressor is running, that line will be extremely hot.
Start there.
Let me know if I can be of further help.
May 27, 2010 | True TD-65-24 Commercial Refrigerator
Refrigerator door
ice door won't close ge #pss26msrbss
Dec 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Heat runs constantly. Feels cool unless emergency
make sure out door unit is running not just the fan out side should hear compressor and in heating mode the large copper line should be hot fan should be in auto position on stat hope this helps
Dec 06, 2009 | Heating & Cooling
Ice maker doesn't keep up with the demand of two people. It still makes ice but has slowed below replacement time.
The fill line may be freezing up. Only solution is to unplug the fridge for about 8 hrs.
Also, check to see that the line behind the fridge isn't kinked. If you moved the fridge for any reason the line may have gotten a kink in it, especially if it's the older copper style line.
Jul 30, 2009 | Refrigerators
Freezer runs constantly
not necessarily, is it maintaining temp? all food staying frozen? especially ice creams if stored in there. most newer freezers displace the heat generated while cooling the food through copper lines running through sides of unit, helps to cut down on air temp differences between the inside (0 degrees) and outside temp to prevent moisture and possible condensation causing premature rusting of unit
Mar 02, 2008 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Freezing water line
Yes this freezer is built by woods corp. They had a myriad of drain icing problems. There is a kit to resolve this although sometimes it doesnt always work make sure that the plastic liner in the drain trough isnt cracked or it will let water in the liner, icing the drain. Seal any cracks with epoxy. Try running a piece of 14 guage copper wire strand (no insulation) from def heater and extend into drain hole. This will help it drain. All this is axcessed though back cover in freezer.
Oct 05, 2007 | Freezers
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
