Question about Samsung Tablets & eReaders
Times battery wont take a charge
Put on charger and overnight it is still not fully charged
  • 133 Answers
Try to restore the factory settings after you back up all important datas... if the problems still occur, you should go to the authorized service center to have your battery changed
Posted on Jun 09, 2014
  • 84 Answers
SOURCE: Wont charge or keep a charge
First off, a google search will show you several companies out there that will replace the cells in your existing battery for around $70. Not bad. However, you mentioned that positioning of the plug can get it to work. The solder joints can become broken from the board, and the small plug in jack will get loose after a year or two of plugging in to it.
You can get a replacement plug at fry's electronics, or many online stores. If you need a service manual, or driver disk set, you can get them at mpcdrivers.com
Posted on Apr 10, 2010
  • 178 Answers
SOURCE: I need to know why my battery is not working
This is about Gateway M275 battery not chargering problem.
Posted on Jun 23, 2010
duane_wong
  • 6826 Answers
SOURCE: laptop wont charge
Orange means it's charging or connected vs. green means fully charged.
At least that's the way my battery charger is on my kodak camera.
Posted on Jul 28, 2010
  • 84 Answers
SOURCE: I purchased a nexus 7 tablet yesterday and I want to now if it is bad for the battery to keep it on the charger after it is fully charged?
The owner's manual that came with it should have the answer to your question.
Posted on Nov 28, 2012
SOURCE: fujitsu siemens stylistic M532 tablet not charging battery
I have just had same problem. Battery on M532 absolutely refused to charge from flat.Tablet worked when plugged in so I downloaded an app killer from android market and killed all but the essential apps then tried again and it seemed top work! Maybe background apps draining battery at faster rate than could be charged?
Posted on Feb 20, 2013
I have a Icraig wireless touch screen tablet model number cmp773-GD , and it won't turn on or charge. Why?
If u just got it return it. your battery is died need new one.tip to make battery last longer. when u get a new battery by itself or it is part of something like a cell phone. do not charge most have half power right out of the box. use battery until it is 100% died.then charge it until full don't over charge. it is a trick to make your battery last long when it has a full charge. never leave battery charging overnight if done to much it makes the battery weak and wont hold charge for long. never leave charging cord plugged in when its not in use. when it is power from the socket is still flowing in the charger which is slowly frying it. that why most people go though up to 4 chargers for each device. i hope this helps have a sweet one!!
Aug 12, 2015 | Tablets & eReaders
Wont turn on even holding power button for 20 seconds
You could have a bad battery, a bad charger, or more probably, a bad charging connector. Try leaving the unit on 'charge' overnight, then remove the charger and try to start the unit. Check the charger with a voltmeter and see if it is putting out the required voltage. You could try taking the unit, if it is not under warranty, to a battery place like Batteries Plus and they may be able to open it and check the battery. If it is under warranty, contact Amazon Customer Service.
Jun 17, 2015 | Amazon Kindle Fire HD
Are there battery recharging problems with Galaxy Note 10.1?
Possible both try charging unit using a friends 10.1 charger if same results in battery been partly charged. The answer is yes its the battery
Oct 11, 2014 | Samsung Galaxy Note 10.1"
My rca tablet wont charge
Either the power converter (wall Pack) has no output of voltage....Or the battery has run its cycle of life. Symptoms of bad battery are,will take no charge,or not hold a charge for very long, or will not charge fully.I have an IPOD that I charged fully,and then put it away for a long time, when I got it back out....it wouldn't take a charge at all. These kind of issues are common with batterys . Hope this is helpful.
Jun 05, 2014 | Tablets & eReaders
Why will my ipad not charge and what do I need to do?
try resetting it, power it off completely. If still not working check charger on another device to make sure charger is OK. If it is you will need to have it repaired, new battery or charging circuit or new socket
May 21, 2014 | Tablets & eReaders
I have had my zeepad on the charger for a few days now and it is not fully charged. What do I need to do for it to recharge?
Probably, the ac charger unit isn't good anymore. Output charge voltage& current isn't sufficient to drive your battery charge beyond 80% threshold.
Change or replace this with a new one (same ac charger specs please) and charge your tab again.
Oct 09, 2017 | Tablets & eReaders
Kindle wont charge
Not all computer USB ports put out enough current to charge batteries. Try another port on the computer, if there is one. If you're going through a USB hub, remove it and connect the Kindle directly to the computer. If you have access to an AC-USB charger (one that plugs into a wall outlet instead of a computer), try using that.
Dec 24, 2013 | Amazon Kindle Fire HD
My machine will not charge and is very slow
It ispossible that sometimes the battery takes a longer time to charge if the voltage of the adapter is low. So after the battery is fully discharged , you must allow the charger to be connected overnight. If the battery does not charge fully then the battery and the adaptor must be cross checked in another unit.
If under warranty you must claim for replacement.
Sep 20, 2011 | Archos 101 Internet Tablet 501590
Laptop wont charge
Jul 28, 2010 | Compaq Tablets & eReaders
Tablets & eReaders Logo
174 people viewed this question
Top Samsung Tablets & eReaders Experts
Jaime Hernandez
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
