Question about PYLE Audio Pylepro Pt8000ch Amplifier - 1000 W Rms - 8 Channel. 19in Rack Mount 8000 Watt 8 Channel Stereo/mono Amplifier Proamp. 8000 W Pmpo
Amplifier fuse ?
How do i change a fuse in the Pyle PT8000CH Amplifier
Blowing fuses
because Pyle... Fuses only blow when the current draw is too high. more than likely you are trying to get too much power from this inferior amp. Thus causing it to distort and damage parts.
Oct 29, 2013 | Pyle PLA2200 Car Audio Amplifier
I need to know how to hook up my pyle pla4278 4 ch 2000watt bridgeable mosfet amplifier
Hi, I assume you are powering regular speakers in the car, right?
The amp needs a power cable from the fuse box or battery.
This cable should be about 6 gage and should have a fuse of about 150 amps.
You will need a ground cable, also 6 gage and connect it tightly to the chassis under the dash.
Disconnect all speaker wires from the head unit, and use a pair of RCA cables to connect the head unit preamp outputs to the amplifier.
Also from the head unit, connect the blue wire to the "turn on" terminal of the amplifier.
Finally, connect your speaker wires to the amplifier.
Your speakers should be rated for at least 500 Watts, or you will blow them with this amp.
Please let me know if you have questions and thanks for using FixYa.
Jan 12, 2011 | Pyle PLA4278 Car Amp
It is getting power to the amp but the light is not coming on. is it blown or is it just a fuse blown inside?
The amp itself has a fuse. Thats the first thing I would check, if not it could be a bad or loose ground.
Good Luck!
Jan 03, 2011 | Pyle Chopper Series 2-Channel Bridgeable...
I've purchased a Pyle amplifier... It doesn't work!
your first mistake is buying anything pyle..... check your remote wire that should do the trick
Apr 01, 2010 | Pyle 1800-Watt 2-Channel Bridgeable MOSFET...
Power fuse on amplifier blows as soon as the power cable is connected
you should check the fuses your using may be too small and make sure you connect the positive first then the ground cable and there are no shorts when you ground the amp.
the most common will be the fuse ampage is too low thats why its blowing when you power the amp
Sep 18, 2009 | Pyle PLA600 Car Audio Amplifier
Im looking for the reset button on my pyle chopper series pla2200 amplifier...i was requested to look on the back of the amp or by the 'plug in fuse' near the input sockets and i still cant find it, what...
Dude, there is no breaker button, there are two 15amp fuses on the speaker connect end of the unit. Here is the link to Pyle: http://www.pyleaudio.com/manuals/PLA2200-2210-2220-4200.pdf
If it's not a blown fuse then you will need service.
Jul 05, 2009 | Pyle PLA2200 Car Audio Amplifier
Can not get power to my pyle amplifier
Usually On Car Amplifiers, there is a Connector/Wire called "Remote On".
This is where Headunit supplies 12V to trigger the Power on the Amplifier.
(Of course, head unit usually has Remote Wire also in order to turn the Amplifier on).
If this wire is properly connected and still does not turn on, then try to supply 12V directly from the battery. If it turns on then your head unit has problem, If it does not turn on then your Amplifier has problem.
Jan 27, 2009 | Pyle Audio Players & Recorders
Help please
Check your power cable, for bad connections.
Make sure voltage dont drop below 10.8v.
Nov 30, 2007 | Kicker IX404 Car Audio Amplifier
PYLE Audio Pylepro Pt8000ch Amplifier - 1000 W Rms - 8 Channel. 19in Rack Mount 8000 Watt 8 Channel Stereo/mono Amplifier Proamp. 8000 W Pmpo Logo
46 people viewed this question
Top PYLE Audio Car Audio & Video Experts
xxxxxx xxx
Are you a PYLE Audio Car Audio and Video Expert? Answer questions, earn points and help others
