How to turn off alarm on nelsonic NLC 690
Do not want to use radio alarm and it wakes us during the night. How do I cancel radio completely?
SOURCE: can't set alarm
Push the center botton on the back until you see WAKE I and then by holding it dwon push the bottons on either the right ir left of that button to set the alarm.... same process for WAKE 2...just have to push the center botton again
Posted on Feb 13, 2009
SOURCE: Cannot turn off the alarm on my RCA clock radio rp5430
Look at the display. Look for a number 1 or a number 2 to determine which alarm is on. If you see a number 1, push the 1 button on the top right side of the alarm clock until the number light goes off (1 or 2 times, depending on whether it is set to beep or radio alarm). When the number is not lit up, the alarm is off.
Posted on Aug 05, 2009
SOURCE: Can't disable alarm feature on colock radio
Just press "Cancel" once and then press the "Wake Mode" button until the selector light cycles through the the music or tone modes...and then disappears.
Posted on Nov 17, 2009
micromatikal
  • 2777 Answers
SOURCE: The "wake-alarm-radio-off" switch on the
Unfortunately there is no work around... The button does sound like it is broken. It also sounds like the light functionality has some issues... You may want to just replace this alarm. How old is this unit?
Thanks, let me know if you have any questions or concerns, just reply to my answer here and I will be right back with you.
Tim
Posted on Nov 04, 2010
gopakumarg43
  • 74136 Answers
SOURCE: I need owners manual to program RCA RC140-A alarm clock
Hello
Send your Emai Address to me. I've the user manual for your RCA RC 140. I actually do not remember, from which site did I downloaded it. I can't send it to you by this window, as it does not allow me to upload PDF fiels by it. If you send your Email ID, I'll send a copy of it to you by return mail. OK.
Posted on Nov 27, 2011
How do i set the alarm on a t231
Setting The Alarm Time of T231
This Timex clock radio has dual alarms that can be set and used independently. The initial default alarm settings are 6:00 AM for Alarm 1 and 7:00 AM for Alarm 2. The procedure for
setting both alarms is the same.
NOTE: The alarm times can only be adjusted when the clock radio is in the OFF mode. If the radio is playing, press and hold the MODE/ALM RESET button until the display briefly shows
'OFF' and then reverts to the time.
1. Press and hold the ALM 1 button until the Alarm 1 time and the Alarm 1 Buzzer indicator begin flashing in the display, then release the button.
2. Press the HOUR / REV button to advance the display to the desired wake-up hour. Observe the PM indicator to confirm that you have set the wake-up hour correctly. If the PM indicator is
'On' the wake-up hour on the display is PM. If the PM indicator does not appear the wake-up hour on the display is AM.
3. Press the MIN / FF button to advance the display to the correct wake-up minute, and then release the button.
4. Press the ALM 1 button once more to confirm the wake-up time setting or after 10 seconds the display will stop flashing and the new wake-up time will be entered automatically. The
display will return to the correct time of day but the Buzzer indicator will remain 'on' in the display indicating that the Alarm 1 is now set to wake you to the buzzer.
5. To change the alarm mode from buzzer to radio, or to cancel the alarm, press the ALM 1 button again. Press the ALM 1 button once more to select the Radio alarm. Press the ALM 1 button once more to cancel the alarm function. The alarm indicators disappear and the display returns to the correct time.
6. Follow the same procedure to set the Alarm 2 wake-up time.
Sep 29, 2014 | Timex Audio Players & Recorders
Can't turn off alarm on rca rp4842a
I don't have the manual, but I figured it out. Setting is easy, just use the switch on the side to select what you want to set (clock, wake 1, wake 2). Then use the forward and reverse buttons on top of the radio to adjust your times. When you are finished, push the selection in the most forward position, looks kinda like a key.
To activate the alarms, click on the Wake 1 or Wake 2 button that are on top of the clock. You can switch between alarm and radio by pressing those buttons.
To deactivate the alarms, press the Wake 1 or Wake 2 button simultaneously with the Cancel button (all buttons on top of the radio.
Oct 09, 2011 | Audio Players & Recorders
How do i set my alarm and when do i know it is on or off....keeps coming on and i dont know how to shut off the alarm...thank you
This clock radio features a dual alarm system, with two separate alarms that can be operated independently. The alarms can be set to wake two people at different times, or to have a main alarm and a backup. One alarm features your choice of radio stations as an alarm wake sound, while the second features a buzzer wake sound. You can set the radio alarm, the buzzer alarm, or both alarms.
Setting Radio Alarm
1. Press the "Alarm Set" Button. The display will flash and the Radio Alarm Indicator will appear. If you do not begin setting the time within ten seconds of pressing the it, the display will stop flashing andd you will need to press the "alarm Set Button again. 2. While the display flashes, press the "Tuning/Set" Buttons to set the wake time. Hold a button for a few seconds to advance the time rapidly. Be sure to set the correct AM/PM time, as shown by the PM Indicator. 3. After setting the radio alarm time, you will need to select the station to wake up to. First, press the "AM/FM" Button to select a radio frequency. Next, select a station using the "Radio Preset Buttons". Rotate the Volume Thumbwheel to set a wake sound volume level. 4. After setting the radio alarm wake time and sound, you will need to select your 7-5-2 setting. The 7-5-2 setting lets you set the alarm for a full week, weekdays only, or the weekend. Before setting the alarm, be sure that the correct date is set. 5. After you have set the radio alarm wake time, wake sound, and 7-5-2 setting, press the "Alarm Set" Button twice so that the display shows the standard, non-flashing display.
Setting Buzzer Alarm
1. Press the "Alarm Set" Button twice. The display will flash and the Buzzer Alarm Indicator will appear. 2. While the display flashes, press the "Tuning/Set" Buttons to set the wake time, as described above. 3. After setting the buzzer wake time, use the "Date/7-5-2" Button to select the buzzer. 4. After you have set the buzzer wake time and 7-5-2 setting, press the "Alarm Set" Button once so that the display shows the standard, non- flashing display.
Activating the Alarms
1. To activate the radio alarm, press the "Radio Alarm" Button so that the Radio Alarm Indicator appears on the display. As long as this indicator appears, the alarm will sound at the set time and days. 2. To activate the buzzer alarm, press the "Buzzer Alarm" Button so that the Buzzer Alarm Indicator appears on the display. As long as this indicator appears, the alarm will sound at the set time and days. 3. When the alarm sounds, press the " Off/Reset" Button to turn off the alarm while still maintaining the programmed 7-5-2 alarm settings. To turn off an alarm and cancel its 7-5-2 settings, press its "Alarm Button" so that its Alarm Indicator no longer appears on the display. 4. To activate the snooze feature, press the "Snooze/Night-Light" Bar when the alarm sounds. The alarm will shut off for approximately nine minutes before sounding again. The feature can be repeated several times during the one-hour snooze cycle. 5. If it is not turned off, the alarm will sound for an hour before stopping. As long as an Alarm Indicator appears on the display, the alarm will sound at the set time, according to the 7-5-2 settings.
Mar 23, 2011 | Timex Auto-Set Dual Alarm Digital Clock...
Cannot shut the alarm function off all together.
Disable the alarm permanently 1. Press CANCEL button. 2. The WAKE indicator will be flashing. 3. Press WAKE MODE button within 3 sec- onds to deactivate the alarm function per- manently.
Mar 23, 2009 | GE 7-4837 Clock Radio
How to set alarm and how to turn it off so that it is not used.
To turn on alarm, switch the selector lever to "Wake" and adjust the time shown. Then, switch the lever back to "Lock" and push the "Wake Mode" button until you see the selector dot (located on the bottom right of the time display) change to either the music or bell symbol; depending on how you'd like to be awaken.
To cancel the alarm, simply hit the "Cancel" button once, then press the "Wake Mode" button until the selector dot disappears.
Mar 10, 2009 | GE 7-4837 Clock Radio
Mar 07, 2009 | GE 7-4837 Clock Radio
Canceling the alarm
Disable the alarm permanently 1. Press CANCEL button. 2. The corresponding WAKE indicator will be flashing. 3. Press WAKE 1 or WAKE 2 button within 3 seconds to deactivate the corresponding alarm function permanently.
Jun 22, 2008 | GE 7-4809 Clock Radio
GE Model 7-4837B
press the Cancel button located on the top of the alarm clock (the light next to the wake mode indicator on the front of the clock should start flashing). Then press the WAKE Mode button on the top of the device. The wake mode indicator on the front should now be off and the alarm deactivated.
To turn the alarm back on, simply press the WAKE Mode button on the top of the device.
Mar 27, 2008 | GE 74801 Clock Radio
RCA RP3750 - set up for No alarms at all?
1. Press "Off"
2. Press "Cancel" then press "WK1"
3. Press "Cancel" then press "WK2"
Dec 04, 2007 | RCA RP3750 Clock Radio
Alarm
SLIDE THE SWITCH TO TIME DO NOT PUT ON WAKE 1 OR WAKE 2 THOSE ARE LIKE TWO SEPEATE ALARM TIMES YOU COULD SET PUT ON CANCEL OR JUST TIME.
May 28, 2007 | GE RP4842 Clock Radio
318 people viewed this question
 Grubhead
Grubhead
