Question about Brother HL 2270DW Laser Printer
Wireless link status failed to associate
My printer will not print wireless link status: failed to associate
  • 3 Answers
Try running the Brother Network Diagnostic Tool....search it on www.brother.com.....
Or you may follow the link I've provided below to Dropbox.... https://dl.dropboxusercontent.com/u/98190725/Brother%20Network%20Diagnostic%20Tool.exe
Posted on Mar 20, 2014
DPR-1040 does not connet wirelessly
Wireless router must not use WPA2. Change to WEP or WPA or buy a more modern printer server,
Jan 05, 2014 | D-Link DPR-1040 wireless print server,...
I have a HP Officejet printer model 6500 E709n (USB connected) and I have just changed the black print cartridge and now the printer only ptints blank ppages. I check of the printer status reveals that...
What about print head?.. perform print head cleaning process through tool box, check any back print out? no remove black/yellow print head clean nozzles manually, try it if not resolved replace print head..browse the link how to clean the print head..http://www.ehow.com/video_4974250_manually-clean-hp-inkjet-cartridge.html
Oct 27, 2011 | HP Officejet 6500 Wireless All-in-One...
I have just installed a Canon MX870 and it won't print - it keeps on saying the printer is offline... I have successfully established a wireless connection and when I go to printer and fax preferences (on...
I had the same problem and just fixed it by opening the Canon IJ Network Utilities and using the tool menu. It turned out that the printer had changed ports and the port was not compatible. That meant that the port it was using didn't have a printer driver associated with it so it couldn't work. As soon as I went into the configure menu and had it try the next IP port, it immediately printed. It's a matter of finding the correct port again or associate the driver the port you are now using.
Jan 04, 2011 | Canon PIXMA MX870 Wireless Office...
I am running Windows 7 upgrade from vista and office 2010, I had problems associated with the upgrade which were resolved. I now have the same problems since I installed office 2010. The Lexmark status bar...
Uninstall the Lexmark software from your computer by following the steps in this link: http://bit.ly/cu3xvM. After restarting pc, check if your Windows 7 is running on 32-bit or 64-bit operating system by going to the Start menu > right click on Computer > Properties. To reinstall, download the driver using this link: http://bit.ly/cVGxkh (for 32-bit) or this link: http://bit.ly/b6TXD2 (for 64-bit). Thank you for choosing Lexmark.
Aug 25, 2010 | Lexmark X4550 InkJet Printer
Failed to associate
This instruction is to setup Brother Laser printer 2170W in windows 7
Turn off Windows Firewall
To reset the printer:
Turn off the printer.
Press and hold the Go Button in front, at the same time turn on the printer from the right side. You will see three lights(Error, Drum, Toner) turn on. Release the Go button. The light is not blue and is off.
Now, Press the Go button 7 times. Wait for some seconds.
The three lights will turn on and off by themselves. The printer warms up and then stops.
Connect the ethernet cable to the wireless router and the printer
in the browser type:
http://192.168.1.1
It shows the device connected and its ip address.
Close the browser and open new browser
on your internet browser type in http://(ip address that you see as device)
click on "Network configuration"
user: admin
Password: access
click on "configure interface". Change it to "Auto Switching" Click OK
You are back in "Network configuration"
click on Configure wireless
Make sure it is "Infrastructure" and the "channel" is correct.
Also "Authentization Method" should be "open system"
Choose your encryption method
type in your password in "hexadecimal format" and click "submit".
If your password is ascii change it to hexadecimal with an online converter
Follow the instructions.
Wait until it prints the papers.
When it tells you to remove the ethernet cable, Do not remove.
Wait until printing is done. Turn off the printer and remove the cable. Turn on printer.
Now Print the printer status:
click on the Go button once to wake up the printer.
Now click on the Go button 3 times. Wait! it will print 4 pages.
Look at the last page
you will see the IP address of the printer.
go to your browser and type in http://( new ip address that you see on last page)
The last step is again in the "configure wireless" to "configure TCP/IP"
choose something like 192.168.1.198 the last 3 digits should be a high number. Close browser.
Now put in the CD and install the wireless Driver only. All Done!
Turn ON Windows Firewall
Jun 06, 2010 | Brother HL-2170W Mono Laser Printer
Cannot print and fax using Lexmark x2470 All-inOne Center
Make sure your printer is set up correctly, check port it's set to be using, is it usb or lpt port. Try switching to a different port and see if it will help you.
If all fails, try deleting the printer and associated devices from device manager. Reconnect the printer, if a new hardware found message dons't come up, try a different USB port. I think, in order to successfuly install a PNP printer, it must first come up a message saying NEW HARDWARE FOUND. Then the rest will follow.
Aug 21, 2009 | Lexmark X2470 All-In-One InkJet Printer
Dpr-1260 onkly works when connected by ethernet cable
dpr-1260 searching for ap and connected keeps changing back and forth when I refresh.On dpr-1260 if status of wireless keeps changing from searching and connected, change wireless to WPA, instead of WPA2. even if you have WPA2 setup (as I did), if you choose WPA it will stay connected.
Jan 23, 2009 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Connect d-link print server with linksys router
you might need to set the Gateway on the router to match your ip on the print server.
Oct 07, 2007 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Brother HL 2270DW Laser Printer Logo
194 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
