Question about Fantom Vacums Lighting Canister Vacuum
Power head roller brush
I need the roller brush. Brussels are worn down very short
Go to guarantee vacuum and sewing center tell them the exact model number of the unit and the serial number and the brand tell them what parts you need need and they will be able to get them for you
Posted on Mar 21, 2014
Dyson animal ball, brush stops rotating often. Restart vacuum, brush head runs very short time, shuts off on flat tile floor.
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Jul 12, 2017 | Dyson Vacuums
Dc35 brush head spins and stops
Ava B.
Jan 17, 2017 | Dyson Vacuums
My 2 year old Dyson roller head keeps sticking and won't turn unless I bang it several times. Can the roller be worn and needs replacing?
Ava B.
Dec 14, 2016 | Dyson Vacuums
Have a Dyson v6 for several months. Roller brush stops turning a soon as I start to push forward after staring trigger. Examined & cleaned roller & surrounding head & find no objects interfering.
The Dyson V6 has an electric motor in the power head. The battery is in the handle unit. So power has to get from the battery head unit down to the motor at the floor roller brush. The way they do this is to send the power around the plastic debris cup that you empty, and then into the connector for the tube and out the bottom of the tube to the roller brush motor. Your problem is probably that there is a lost contact along the way. Try plugging the roller brush directly into the head unit leaving the tube out and see if it is intermittent or if it runs fine. In that case the problem is one of the contacts associated with the down tube. If the roller brush is intermittent even when plugged directly into the head unit, then the problem may be the connection associated with the debris cup. remove the cup and make sure the contacts are clean. Hope this helps. G
Oct 26, 2016 | Dyson Vacuums
Bissell power steamer brushes will not turn
There are a number of reasons why your brush roller is not turning. General maintenance to your vacuum is crucial and will help it work at peak performance.
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=bissell
Ava B.
Jun 25, 2016 | Bissell Power Steamer Shaft w/ Head Hose
Why won't the brush turn on my Dyson DC40 Animal?
https://www.thinkcrucial.com/search?type=product&q=dc40
Ava B.
Jun 19, 2014 | Dyson Vacuums
The ball bearings are stripped from the roller brush of the power head for my electrolux model N115M
you will most likely have to replace the roller brush wth bearings. i just recently had to replace my wifes on her electrolux. i was able to order the parts online at sears parts direct, but there are many places to get them online. you will need the model and serial number. hope this helps.
Apr 11, 2012 | Electrolux UltraLux 2000 Bagged Canister...
My broan cv30 purchased in 1996 carpet power head unit sucks up dirt and rocks but will not pick string or yarns up from carpeting. I find myself picking it up. It is sucking fine dirt and small...
It's possible you simply need a new belt or roller brush. Place the power nozzle upside-down turn the vacuum on. Ensure the brush turns. If it doesn't, the belt has broken or is too worn to turn it. Replace the belt. Make sure the tension is properly set prior to reassembling the power nozzle.
Next, with the power nozzle upside down, run the flat of your palm across the brush area. If you can barely feel the bristles, it needs replaced. A good brush will loosen the yarn and strings, but needs to be cleaned periodically.
As long as the powerhead motor is running, there is no need to replace it. If it's not running, look for a reset button and press it. There could also be a broken wire, loose connection, or bad switch causing a power head motor to not operate..
Dec 31, 2010 | Broan-NuTone Vacuums
THE ROLLER IS DRAGGING AND MAKING A NOISE
Your drive belt is probably streched and slipping on the motor shaft. However your bearings on the roller brush may be worn out.
Take roller brush out of power head and check the bearings at each end. If they are siezed buy a new brush.CHeck to see that your brush housing is not damaged due to heat caused by siezed bearings
Nov 16, 2009 | Vacuums
My purple and red Dyson has become hard to push. Could a belt have broken?
It's simple to tell if a belt has broken. Just switch the machine on and have a look (look, don't feel) to see if the brush roller is rotating. If it is, then the belt is not broken.
Depending on how much use your machine has had, it's quite likely that the brushes on the brush roller are worn to the point where you need a new brush roller.  Most vacuum cleaners rely on rotation of the brush roller to pull them along, so if the bristles are too short this doesn't happen.
I hope this helps. Please remember to rate this response.
Mar 11, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Fantom Vacums Lighting Canister Vacuum Logo
80 people viewed this question
Top Fantom Vacums Vacuums Experts
woodzowl307
ray gallant
Are you a Fantom Vacums Vacuum Expert? Answer questions, earn points and help others
