Question about Vito Technology Star Walk for iPad - interactive astronomy guide
Black screen I downloaded Starwalk to my iPhone 4, but when I tap in the icon, it just comes up as a black screen that says Vito Technology. Did I download wrong or miss a step?
Hi my iphone screen has enlarged icons and i can't
I think that the standard icon size on my iPhone is too big. However, people with poor vision will benefit from larger icons instead. If you iOS device is jailbroken, the icon size can be customized.
It is unbelievable how apple restricts users on the customization front. Many users would strongly appreciate at least some freedom regarding personalization and customization. By their nature, jailbroken devices have many of these limitations removed.
1.Open up the Cydia app from your springboard.
2.In the Cydia application, tap on Search at the bottom right corner.
3.Now search for Bigify. Two options should come up: one in blue and one in black. Tap the black one as the blue links in Cydia are for paid tweaks.
4.One on the Bigify screen, tap Install.
5.On the next screen, tap Confirm.
6.Once the package finished installing, tap on Restart SpringBoard.
7.After your SpringBoard restarted, open up the Settings application.
8.In the Settings app, scroll down until you find the newly installed Bigify application. Tap on it.
9.You should see a slider under Scale Size. Adjust it however you want. Sliding it to the left will shrink your icons, and sliding it to the right will make them larger. You will also have the option to change the icons back to default size by moving the switch into the ON position.
10.After adjusting your slider, scroll down and tap Apply Changes, your phone will reload. After a few seconds you will be able to see the changes on your home screen.
Below are two possible home screens after you have resprung. Continue to tweak until you find a size that suits you best.
25274504-xxg23bqogrpujztq43hjzuo2-1-0.png 25274504-xxg23bqogrpujztq43hjzuo2-1-0.png
Nov 07, 2014 | Apple iPhone Cell Phones
My iphone screen is black and doesn't light up ,i can hear it work .also while charging the icon comes on .why is this
could be a bad digitizer (the screen) may be a matter of resetting the device. Go to apple store. Check ifixit.com
Nov 23, 2013 | Apple iPhone 4 Black Smartphone
How do you turn off the apps with the latest software. I was able to do it before I installed the new one but now can't. TIA Tom
In iOS7 you double tap the home button then flick the preview screen UP not the icon. You no longer hold the icon until it shakes.
Sep 19, 2013 | Apple iPhone 4 Black Smartphone
How do I block incoming unknown calls
You can't block incoming unknown calls, but if you don't accept the call, you will not pay for it.
Aug 08, 2011 | Apple iPhone 4 Black Smartphone
Can't pair to iphone 3g
Hi, the iPhone 3G definitely does work with bluetooth. In fact, I'm talking on a bluetooth headset with my iPhone 3G right now.
You have to put both your Southern Telecom Emerson Bluetooth Headsetand the iPhone in "pairing mode".
On your iPhone, click the Menu button, tap the Settings icon, tap the General icon, and then tap the Bluetooth icon. Make sure that 'Bluetooth' is set to "ON" and not "OFF". As long as you have this screen up, your iPhone is in pairing mode.
Turn your Southern Telecom Emerson Bluetooth Headset off and wait a few seconds. On your Southern Telecom Emerson Bluetooth Headset, press and hold and Answer/End button for Five Seconds, until a solid blue light comes on, which places the device in Bluetooth discoverable mode.
Now that both devices are 'discoverable', the Southern Telecom Emerson Bluetooth Headset will show up on that Bluetooth screen on your iPhone. Be patient as it might take a minute to appear. Tap on the Southern Telecom Emerson Bluetooth Headsetin the list on your iPhone, and then it will ask you for a passkey. The passkey is "0000" (without the quotes). After you enter the passkey, the Southern Telecom Emerson Bluetooth Headset will show up on the list with the word "Paired" next to it.
Now you're paired! Incoming calls will automatically be passed to your headset as long as your iPhone can find it nearby.
Good luck.
Feb 23, 2011 | Southern Telecom Emerson Bluetooth Headset...
My iphone icons are to big for the screen. How do
From the home screen, tap Settings (yeah, if you can find it — but at least they can’t delete that or any built-in application).
From Settings, hit General, then choose Reset.
From the Reset menu, choose Reset Home Screen Layout. When it asks you to confirm, tap the big red Reset Home Screen button.
And you’re done. Your iPhone’s icons will be back to the way Apple ships them
Jun 25, 2010 | Apple iPhone 3GS Black (16 GB)
IPhone 3G S Black Smartphone: Iphone 3gs the icons are very big and i cannot cha...
You just need to tap three fingers on your iphone at the same time. What happened was that you might accidentally placed three fingers on your iphone's screen when you grab it from your pocket or purse.
Hope this helps.
May 16, 2010 | Apple iPhone 3GS Black (16 GB)
Big icons on my iphone 3gs home screen.plz solve this problem
You must have zoomed-in the screen accidentally. It's easy to zoom-out, just double-tap anywhere on the screen using 3 of your fingers (simultaneously) and everything will go back to normal.
And in case you want to zoom-in again, just do the same thing.
For more iPhone / iPod touch tips, click here.
Also visit my blog for app recommendations.
May 09, 2010 | Apple iPhone 3GS Black (16 GB)
Iphone 3gs the icons are very big and i cannot change them back
I ve had the same issue today and freaked out thinking the phone was crasing. How ever after spending 3 hours trying every thing and aking on the web.
when you double tap the screen it normaly zooms?? yes
use 3 fingure tips to do a double tap!
this will take a sort off large zoom screen lock off and bring the main screen fuctions back inline for you.
please let me know or leave a reply
:0
Jul 28, 2009 | Apple iPhone 3GS Black (16 GB)
Vito Technology Star Walk for iPad - interactive astronomy guide Logo
76 people viewed this question
Top Vito Technology Apps Experts
Erin Wood
Erin Wood
Are you a Vito Technology App Expert? Answer questions, earn points and help others
