Question about Road Mice 2002 Ford Mustang GT RM-08FDMGSXK 2011 Mustang GT Wireless C
Took out a axle from my 02 mustang. While removing the c clip the pin fell out instead of staying halfway in. Now i cant get it back in and one of the gears fell off.
While removing the c clip to take the axle out the pin fell all the way out instead of staying halfway in. Now I cant get it back in and one of my gears fell out.
    Master:
  • 397 Answers
The first step to getting a solution would be to post it in the correct section. You have posted this in "Keyboards And Mice"
Posted on Mar 19, 2014
How do I change rear axle seal on 1991 dodge Dakota 4×4?
Remove the wheel and tire.
Remove the drum.
Drain the rear and remove the cover.
Locate the 8mm bolt locking in the center pin and remove it.
Slide the pin out 1/2 way. DO NOT SPIN EITHER AXLE WHILE THE PIN IS OUT.
Push the axle in from the outside. You will hear the "c" clip fall in the rear. Put the center pin back in the rear and thread the bolt a couple turns.
Slide the axle out.
Remove the outer seal and install the new one.
Reverse the procedure REMEMBERING to put the "C" clip back in.
(Slide the center pin 1/2 way out. Install the axle FULLY. install the "C" clip and pull the axle from the outside to insure the clip is in. DO NOT SPIN THE AXLE until the center pin is reinstalled and the retaining bolt is in.)
May 31, 2015 | Dodge Cars & Trucks
How to install a new rear axle in a 02 gmc sierra 1500
Jack it up ,pull the wheel on the bad axle side,remove the diff. cover,
remove the small pin holding the large pin in,slide the big pin out ,push the axle in from the wheel end,remove the c-clip in the axle and slide it out.
Would be wise to change the seal at the end af the axle tube at the same time. Slide the new axle in ,put the c-clip in the axle ,push it back in the carrier and reinstall the large pin and keeper pin,"Right Stuff" sealer makes a good cover gasket,3/8 drive for the fill plug,some gear iol and you're done,,not a bad job,no special tools required.
Feb 23, 2012 | 2002 GMC Sierra 1500
Rear axle 02 escalade need to remove to replace dust shield
-chalk the wheels so the vehicle can not roll.
-Place the transmission in nuetral.
-jack up the rear of the vehicle.
-remove the real wheels-
-remove the drums or calipers and rotors.
-remove the rear diff fill plug on the side of the differential.
-remove the center cover on the rear differential. Have a drain pan under it to catch the lube that will come out.
-rotate the drive shaft until the rear diff pin bolt is accessible and remove the bolt.
-remove the rear diff pin
-push the axles in
-remove the c clips from the axles
-pull the axles out
-replace the backing plate/dust shield.
They do make a two piece backing plate that can be installed without removing the axles. You will unbolt the old backing plate then cut it into two pieces to remove. The new two piece backing plate will slide over the axle and then bolt into place. I know for sure NAPA has them.
If you have any questions let me know!
Oct 05, 2011 | Cars & Trucks
How do you replace a rear end differential U-Washer on a 01 mustang?
Hi, welcome to FixYa.com my name is Shawn and I will be answering your question.
Remove the differential rear cover.
Remove the rear calipers and rotors.
Remove the 8mm bolt that holds the pin in and remove the differential pin.
Remove the ABS sensors push the axle in towards the center of the rear end.
Remove the c clip washers. You can now pull the axle out.
I hope my assistance helped you and resolved your concern, if you need further assistance please ask.
Aug 08, 2011 | 2001 Ford Mustang
Change rear whell seal 1997 f-150 gear oil comeing out of rear whell took tire off; took drum off; and saw gear oil all over brake shoes. Seal or bearing need to be replace? how?
replace the axle seal to replace pull the rear cover draining the gear oil then rotate the carrier around till the small bolt holding the carrier pin remove bolt pull pin out don"t turn carrier after pulling the pin push the axle in and remove the clip from the inside of the carrier that pin holds the axle clips in place after pulling out you can remove the axle then just pop the seal out and install new one use a socket or something that is the same size as the seal lube the axle and slide axle back in lift up when almost all the way in the tube putting it in the carrier once in replace clip and pullout on the axle thats it pretty much hope this helps you out
Mar 24, 2010 | 1991 Ford F250
Rear axle brake calipur broke and split my rim, i need to remove my axle shaft so i can replace my parking cable bracket, ive removed my bearing caps and pin from the center of my axle but my axle still...
Bearing caps? Put them back in. and retorque, I hope you didnt ruin anything. After you take the bolt and and the large pin out, you push the axle in towards the center of the axle housing and there is a large clip that you remove, sometimes it even falls out, then you can pull the axle out. The clip fits into a groove at the end of the axle. Inspect the axle bearing and seal while its apart ant replace them if anything looks like its worn, To install push the axle all the way in, and get the clip back in th egrrove, then pull axle out to seat the clip. then the large pin can go back in.
Nov 14, 2009 | 2002 Cadillac Escalade
How to put a window back on its track in a 02 mustang
On the inside trim, you can remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Then you'll need to manipulate the panel and disconnect the door handle linkage from the door handle and disconnect the wiring for your controls. Pull off the weather seal and you can readjust the window from there
Oct 13, 2009 | 2000 Ford Mustang
Rear Axel Seal
Wheel, brakes etc that are in way of pulling axle out have to come off. Drain rear end fluid, remove rear housing cover, remove bolt that holds pin in differential, remove differential pin, push in slightly on axle to remove "U" clip that holds shaft in, then slide shaft out. replace seal. Reverse procedure for re-install & fill with gear lube. If any questions, get back to us.
Apr 16, 2009 | 2002 Ford Mustang
Replace axle seal on 2003 lincoln town car
You have to remove the differential housing cover.
Then turn the center housing until you can see the 5/16 bolt that holds the center pin that goes thru the spider and axle gears.
Remove the bolt and center pin,be careful that the gears stay in place.
Then push in on the axles to expose the c-clips on the end of the axles and remove the c-clip.
Then remove the axle.
Mar 25, 2009 | 2003 Lincoln Town Car
Road Mice 2002 Ford Mustang GT RM-08FDMGSXK 2011 Mustang GT Wireless C Logo
55 people viewed this question
Top Road Mice Computers & Internet Experts
sonofspy
Level 1 Expert
Bill Boyd
John Mangan
John Mangan
Are you a Road Mice Computer and Internet Expert? Answer questions, earn points and help others
