Question about Onkyo TX-SR502 Receiver
No sound from speaker out let
I got sound from the rca jack but none from speaker jack
Connecting tv external speakers
If you connected R/W RCA cables to the AUDIO OUT RCA jacks on the rear of the TV and connected the other ends to the TV AUDIO IN jacks on the receiver, you should be able to select an input on the receiver that will deliver sound to the Bose speakers. If you went to TV setup and selected external speakers, you directed output from the TV amplifier to external speakers which is not what you want.
Jan 27, 2014 | Televison & Video
Power but no sound help plz....
well here we go how do you have your pioneer radio connected .
did you run the radio speaker wire out to the factory speaker or did you have an amp connected to the rca output jacks.
1 well if the radio connect by the speaker wire out the
output chip in the radio is fried and needs repair ....
2. if u have a amp connected to power your speakers for sound
check the amp to make sure you have power and no lose connection or speaker wires disconnected.
3. it also possible that the rca jacks are fried too
I no by experience that pioneer loses ground on the audio output jack (rca) well what we did to fix it is..
take and 18 gauge wire stripe back about 1/2" to 1" of the insulation to expose the copper wire and wrap this around the metal casing of the rca jacks and then ground the wire to a ground point do this for both left and right rca jacks...
radiorepair@windowtintingin239.com
Oct 30, 2013 | Pioneer DEH-P3500 CD Player
I want to set up external speakers. Which outlet do I use
if theres a built-in amp. and outlet for spkr wires so it possible, if there's none you have to provide another sound system, from your tv connect rca jacks in FL and RL OUT to FL and RL INPUT of your sound system. hope this wll help you..
Feb 26, 2011 | Televison & Video
5.1 speakers connected to a dvd player ?
You need an RCA - RCA cable,that means that you need a cable with RCA at both ends. At the back of the dvd player,look for sound section (RCA jack) In the sound section look for "right" and "left" connect the two RCA jacks in there and you`re done.
------- If you don`t know how an RCA jack looks like,see this image
Jul 18, 2010 | Logitech X-530 Computer Speakers
Sound is staticy for both internal speakers and external speakers through the headphone jack
Let verify first to narrow down to where the problem can be, attach the powered PC speakers to the Audio Line out RCA jacks to see if you can get the sound there, if you do, then the problem can be in the power amp circuits, if you do not get the sound at RCA jacks, then the problem can be in the sound processor circuit. Please post back what you find. You may be better off if the sound does work through the PC speakers, to get the TV repaired; it will be more than $100 and up.
Parts: www.shopjimmy.com
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Jul 07, 2010 | RCA L42WD22 42 in. LCD Television
No sound to speakers hooked to RCA jacks.
you have the wires mixed up. the positive wire is hooked into the negative, rechech your wiring
Apr 13, 2009 | Dual XDMR-7700 CD Player
Lost Owners Manual - Can't get Audio Out Jacks to Work
the manual is avild here http://www.manualsparadise.com/pages/P061220/P94561532.html
but look and see if there is a switch on the back of the tv that sayes external speakers, if so us that and you book self speaker will work, also check in the menu under audio for this same setting, if none of these are there look at the back again this might be a audio out jack that is made to go into a amplifier
hope this gets you on the right track
Feb 08, 2008 | Zenith Z27H41D 27" TV
Rca 2250
Sounds like your right side output is shot. And yes it can be fixed, but the cost factor would be higher than what you paid for the set itself. First see if your inputs are working correctly, this also could be your problem. Check all your connections.
Dec 29, 2007 | RCA RT2250 System
Connection to a portable tv
The RCA set on a tv [Red /White /Yellow] are INPUT[ VCR/DVD player] not out put. Hook the speakers up the the 3,5mm earphone jack though you will need a conveerter plug like this
Jun 30, 2007 | JBL CREATURE II Computer Speakers
Onkyo TX-SR502 Receiver Logo
22 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
