Question about Vizio VA22LFHDTV10T LCD TV
Looking for a technical/repair/service manual or schematic for a VA22LFHDTV10T to replace a burnt out resistor on the power board: PWTV8K42ASA1
Vizio model# VA22LFHDTV10T power board part# PWTV8K42ASA1
    Master:
  • 397 Answers
Have you tried contacting Vizio? Perhaps they will be willing to send you one via e-mail or something.
I have contacted a few companies in the past when I've struggled to find service manual, it can be surprising how forth coming they can be.
Here's there websites support section, if you scroll to the bottom of the page there is some contact information there and live chat.
VIZIO Product Support and Services VIZIO
Posted on Mar 19, 2014
Testimonial: "Thank you for the tip. I tried calling Vizio support and they didn't have access to this type of information and referred me to 2 of their repair companies. Neither would give me any information. They would send a technician out or I could mail in the parts for a hefty charge. I'll keep searching. Thanks!"
What is the value of R617
In order to answer that, one would need to know the manufacturer's name and model number to the CRT you're trying to repair- in order to look up the schematic for that particular unit...and the printed circuit board number that the resistor 617 is positioned on...
Try an online search engine to locate the service/repair manual for your t.v, or go to a local t.v. / electronics repair shop; they'll be able to ID the resistor you'll need.
Apr 08, 2015 | Televison & Video
My wife's Viking 6690 smoked this last weekend. I opened up the end where the power switches are and the board had a 0.01 ufd capacitor the blew up. That would be easy enough to repair. However when the...
According to you your machine's resistor burnt out. This resistor is located above the 240 volt capacitor which white base. change the resistor soon. For color code of the resistor you can follow the manual. You can visit also the product website for tech assistance.
Mar 10, 2011 | Vacuums
I hve dynex lcd 26-09 and there is 2 surfce mount resistors and 8 pin chip burnt up inside and the #s on the resistors were destroyed there is # on th board beside them but i dont know where to get the...
I think in the long run you will be better off to just replace the Board or Ship board to PTS for rebuilt
1-800-844-7871
Encompass Parts Distribution 1-800-638-3328 they might have Service Manual
Feb 17, 2011 | Dinex DX-LCD26-09 26 in. HD-Ready LCD TV
Resistors burnt on power supply board on L1975NW lcd monitor looking for that power supply board
This monitor has common problem with caps went bad and it will take out the fure and MOSFET in the inverter circuit. Do you know which resistor is burnt out? I usually only have to replace the caps, MOSFET, and the fuse.
http://www.instructables.com/id/How-to-repair-a-Westinghouse-L1975NW-19quot-LCD-/
Jan 07, 2010 | Computers & Internet
Fried microkorg
A diode or two could need replaced. I can't find a schematic. A microkorg would not be a fun project to take on yourself. Check this page and put your zip code in and check for a repair center (if you are in the US..I don't know if there is a repair center in Japan.
http://www.korg.com/SupportResults.aspx?productid=128
Mar 10, 2009 | Polk Audio Music
Samsung HCL5515w
Usually if some parts on the board burnt on that model it can be caused by leaky tubes. Meaning the coolant from the crt's has dripped out. If burnt components are beneath any of the tubes, inspect very closely for liquid substance having leaked down from coolant chambers above. If this has happened you must seal leaky gaskets before going through any trouble of pcb repair.If burnt parts are not below tubes, most common cause is bad convergence ic's. At any rate, service info avail online or at samsung.com or 1800samsung. Hope this helps.
May 29, 2008 | Samsung HCL5515W 55" Rear Projection...
DBX 100 Boombox
I don't recommend this, but the resistor you speak of is probably a small fuse. Try jumping out the fuse, then turn on unit for brief moment. If it powers up, fine. Replace jumper wire with 1 amp fuse. If not, take to prof. tech.
Apr 12, 2008 | Audio Players & Recorders
Motherboard Dead
Hi Tom,
there are plenty of basic component overviews in the D500 Service Manual, but I don't believe you're looking for that specifically. What you're looking for is a circuit board schematic, to see the exact paths.
Unfortunately, Dell uses a strictly proprietary wiring scheme, so you'd have to call them directly. Although personally, I'd advise against repairing the board yourself, even with your experience. I think It's quite obvious from the burnt out components you've found that the board was subject to abnormal voltage levels, most likely from a power surge. There's no telling what path the electricity took, and how many components it's damaged. replacing those two inductors (if they are, in fact inductors) could fix the problem, or it couldn't... it's hit or miss at best. It's for this reason that most techs just replace the board instead, soldering it only if the problem is a leaky capacitor or two.
Dec 29, 2007 | Dell (04U621) for Latitude D600, Inspiron...
Burnt resistors
Researching resistors---
What caused the resistors to burn?? Have you already fixed
that? If so, what exactly was it ???   let me know...T.
Oct 18, 2007 | Philips 60PP9352 60" Rear Projection...
Vizio VA22LFHDTV10T LCD TV Logo
133 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
