Question about Ruud UBHC Air Conditioner
My condenser fan wont stay running runs at first then quits
  • Anonymous Mar 17, 2014
    THE CONDENSER FAN RUNS SLOW AND DOES NOT STAY RUNING
  • 614 Answers
Bearings in fan going out. Or bad capacitor. Both causes motor to overheat. Rus
Posted on Jun 14, 2009
SAMSUNG REFRIGERATOR
Check to see if the condenser fan is working. Samsung has a notoriously bad condenser fan motor. This is the compartment in back. Check that forst before replacing the control board.
Mar 22, 2015 | Samsung Refrigerators
How do i get my condenser fan to stop running. it is cooling fine but won't shut off unless i shut it off.
Are you sure its the condenser fan? The fan is attached to the compressor power and wont run unless the compressor is running. On the other hand the fans inside the cooler will run 24/7 and are designed for continuous duty. If someone has worked on the compressor wiring you may have to re establish the wiring following the wiring diagram. I have seen condenser fans wired in hot areas to run continuously to attempt to cool down a hot compressor or compensate for a worn out or damaged condenser that doesn't get rid of the heat from the system. If that is the case a new condensing unit is probably in your future. Hope this helps good luck.
Oct 09, 2014 | True GDM-47 Refrigerator Merchandiser -...
The fan on my GT345 chest freezer runs constantly. Is this correct ?
Depends are you referring to the condenser fan or the evaporation fan? If it's the condenser fan you may have an issue with debris in the condenser coil not letting enough air flow to cool down so it will stay on to keep from burning up compressor.If it's inside the evaporator coil then it may be low on refrigerant possibly freezing up the evap coil making it run then kick into defrost run kick into defrost etc... hope this helps
Aug 12, 2014 | Freezers
Refrigerator wont get cold
If compressor is running check and make sure your cond. fan and evap fan are running. Also check in freezer and make sure evap. coil is not covered in ice. Also clean your condenser coil. You could be low on refrigerant. There are quite a few things to check.
Nov 01, 2012 | Frigidaire Refrigerators
The capacitor was bad and was replaced. now the system will work fine for about 30 min then the fan the outside unit will stop working. it sounds like the compressor is still on and cold air is will...
Yes, if you changed the three post capacitor that runs the fan and compressor, and the fan is still getting hot and shutting down until it cools off, you may have bushings out of the motor or an internal short. Sounds like you have a job ahead of you of changing your condenser motor. If you do this yourself just contact me I will step you through it . Mark
Jul 10, 2011 | Goodman CLJ36AR42 Air Conditioner
Just had the condenser fan motor replaced on my 550 sub zero refrigerator. I forgot to asked the serviceperson the following questions: Does the fan continously stay on and what is the normal sound of...
Good day,
On models with 2 compressors the condenser fan motor runs 24/7. It must since the compressors run randomly and that motor must be on since it handles both units.
Fan noise is subjective. It itself makes little noise but the blade does. If for example the blade was changed from the nylon style to a metal blade (good idea) then it would be somewhat louder.
If the noise is not objectionable then I would use it as is.
Oct 06, 2010 | Sub-Zero Bottom Freezer Refrigerator
I have 1996 Dodge caravan and the fan's come on and stay on
By chance are you saying the fans stay running when you turn off the engine, the problem is with the radiater fan relay, the points are probably sticking together, it's in the pdc box under the hood, power comes from fuse 4, 40 amp, through the relay, then to the fans, relay is controlled by the engine controller (pcm). just flip the cover and find the right relay, pull it out when they wont shut off, if it quits, swap it anouther relay from the pdc box, and test it again, fans come on at 212*F and shut off at 199-202*F. if the fans stay running while engine is running, you might have a coolant sensor issue, or cooling system issue. If you need more assistance, let me know. GOOD LUCK, RDJRP
Oct 01, 2009 | 1996 Dodge Caravan
COMPRESSOR RUNS, AND IS HOT TO TOUCH, FREEZER WONT STAY COLD IF O
either your evaporator and condenser coils are very dirty or your low on r22 freon
Jul 31, 2009 | Freezers
The condenser fan is not running and our ref. and freezer are not staying cold
If the condenser fan is not running then the compressor will overheat and go out on overload. Replace the fan motor and that should correct the problem
Jun 22, 2009 | GE GSH22JFR Side by Side Refrigerator
Compresser is not running
The condenser fan motor is most likely blown. A replacement fan motor and a run capacitor are most likely needed to get it back in working order.
Jun 01, 2009 | Bryant Heating & Cooling
Ruud UBHC Air Conditioner Logo
304 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
