Question about DIGITECH JAM MAN Looper Phrase Sampler
Guitar single is cutting out when trying to record a loop
Guitar single & Inst. level are cutting out when trying to record loop
Peavey classic chorus 1991 -how do you connect a distortion pedal the power amp jacks at rear tried affects loop in front bid drop in power-do you connect same way as effects loop with send /return
Pedals operate at a different level then rack units that go in the effects loop.
It needs to go in front of the amp input. Guitar to pedal to amp input.
Nov 12, 2016 | Peavey Music
I have a Korg D3200. I want to make a rhythm loop
do you have the owner's manual if not download it-there are /were you tube videos for what your trying to do- they helped me alot - when you plug your guitar into the guitar jack on channel 1 you can't use the xlr input 1at the same time in addition be careful not to blow the audio system there are no replacement parts for this system
Oct 29, 2012 | Korg D3200 Studio Package
How To Use The effect Loop?
The effect loop is to use exteernal effect module... It is NOT to use guitar pedals !!!! The signals are line levels, NOT guitar type levels. An example of a device might be an Alesis Quadraverb. You take the effect send jack and run it into the inout of the effects module and the output of the effects module into the effects return jack. Many try to use guitar pedals and massive distortion results because levels are too high for the pedals.
May 12, 2011 | Peavey 6505+ 112 Combo Amp Combo
Guitar is very quiet
make sure its the guitar by trying in another amp, and if it is the guitar take it to a guitar shop, theyll figure it out
Mar 26, 2011 | Gibson 1957 Les Paul Jr Single Cut VOS...
Cannot record both mic and electric guitar in daw
Disagree with previous post. The GTrack is designed to record vocals and a mono insrtument at the same time. That's its main selling point. It should also allow monitoring of both the vocals and guitar alongside the playback from the computer. In your computer's Control Panel, go to sound preferences, select the usb microphone and click on advanced tab. It is likely yours is set up to record 1 channel at CD quality - this is how many ship for some reason. Set it to 2 Channels CD quality.
In Sonar, set your track input as USB Left for the vocals, and USB Right for your guitar.
Mar 31, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
Problems recording with Sony Acid mucic studio 7!
This probably has to do with the levels you have set for the sound card - take a look at your mix levels AND the volume input level 0 this is not the same control as output
Sep 30, 2008 | Sony ACID Loops - Ugly Remnants: Volume...
Can not record vocal and guitar at the same time
The monitoring switch should not affect the recording at all. Maybe you have a defective mic?
Does it record from the line input if you set it to Line In mode?
Mar 27, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
Low record level for guitar
first of all you want to have your guitar amp at a decent volume but too loud, just enough to be able to get a good signal. when you have done this turn up the gain on your mic channel so that your VU meter (level meter) on the recording software shows a reading of about half way up the meter. If you can not achieve this with the soundcard alone increase the gain on your channel in the software.
This sound guarantee a good signal but as with most recordings you will still have to boost the signal without it peaking. to do this use a compressor or a limiter and turn the gain up. if you use these dynamic effects correctly you will achieve the guitar level you want.
Jan 25, 2008 | M-Audio Fast Track USB (FASTTRACK) Audio...
DIGITECH JAM MAN Looper Phrase Sampler Logo
208 people viewed this question
Top DIGITECH Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a DIGITECH Audio Player and Recorder Expert? Answer questions, earn points and help others
