Question about Epson L200 All-in-One Inkjet Printer 27 PPM Black, 15 PPM Color, 5760x1440 DPI, Color, PC
The printers ink pads are end of their service life.
My printer is no working
    Sergeant:
    Champion:
  • 266 Answers
Cant understand your problem..since you know the problem call 1-800-425 0011 and they will give you the answer
Posted on Mar 19, 2014
Lonewolf1038
  • 6 Answers
SOURCE: epson stylus photo r320 ink pad relacement
Here's 3 things you can do to get around this...depending if your printer is new and still under warranty or not (do NOT void your warranty!).
I have used all 3, but the third one was a lifesaver (AND money-saver!). About once a year I have to reset the printer using #2, but other than that....#3 is the greatest!!!
1. Try resetting it by, unplugging the power cord then while holding down the POWER STOP and MAINTENANCE buttons simultaneously while replugging the power cord caused a reset to zero on the counter. You will still have to replace the pads or redirect the waste ink tube to a receptacle on the outside of the printer, hope this helps?
2. If you go to inkjetprinterhelp.us there you will find the ssc service utility. Once you open the page click on the service utility and then choose the english version unless you can spk russian.If you then scroll to the bottom of the page and install the prog. Once you have installed the prog you will get the ssc utility logo in your bottom tray. Right click the icon and then select reset protection counter from the protection counter drop down. Once you have done this restart your computer and this should reset the system.
3. INSTALL AN EXTERNAL WASTE TANK and forget all about those gunky ink pads forever!
On the left rear of these printers is a small trapdoor held by a single screw.
Remove it, look inside (down and to your left) and you'll see the waste ink tube.
The tube is free at one end, and with a suitably curved piece of wire you can hook it and wangle the end out through the opening (you may dislodge a small piece of plastic in the process -- just put it back where it was, it's only a vibration damper.) I found the tube to be rather short....so I added an extension since I do not have room directly behind my printer for a container. I used the tubing you use with oxygen tanks or fish tank bubblers. They also make a little plastic connector so you can join the two together.
At this point, you're almost there.
All you need now is a suitable container for the waste ink, and I drilled a small hole in the trapdoor cover so you can put it back on without pinching the tube (or you could just leave it off.)
The container is a small square one with a snap-on lid, approx. 60mm square and holding about 150ml -- they're sold in sets of three for a few cents and are for making ice-blocks etc. in your freezer. Any small container will work.
Make a hole in the lid (slightly larger than the tube to let air escape) insert the tube and forget about the internal pads forever.
I've had mine in place for almost 2 yrs now and it works like a charm. If you need photos, let me know and I have a couple I can send you.
Posted on Jul 01, 2008
rioglen
  • 95 Answers
SOURCE: Epson R220 parts near end of life error
its a tweak with epson.... they have a counter there that intentionally stops it from working even through your printer is still in good condition.
there is an available driver that could correct that depending on the operating system you are using. i think if i maybe correct it only works with and o/s that is winxp.
the drivers name is inkpad reset utilty.
try to check the website www.epson.com/ipr for the inkpad reset utility
Posted on Sep 10, 2009
SOURCE: The printer's ink pads are
The Printer's ink Pads are at end of their Service life
Posted on Feb 25, 2011
SOURCE: EPSON STYLUS T13 printer's ink
EPSON STYLUS T13 printer's ink pads are at the end of their service life HOW TO RESET FREE
Posted on Dec 19, 2012
masudkaysar
SOURCE: The printer's ink pads are at the end of their service life. Please contact Epson support.
Posted on Jan 12, 2013
Epson pm 245 ink pads
The printer's ink pads are at the end of their service life.please contact Epson support.
Jun 28, 2013 | Office Equipment & Supplies
Printer's ink pads are nearing the end of their service life.
The printer's ink pads are nearing the end of their service life. Please contact Epson support.
Dec 04, 2012 | Epson Stylus Photo RX700 All-In-One InkJet...
Epson stylus TX121 printer's ink pads are at the end of their service life
My printer name
Epson tx121
it's show "The printer's ink pads are nearing the end of their service life. Please contact Epson support".
May 14, 2012 | Epson Stylus TX120 Inkjet Multifunction...
Nov 30, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Apr 26, 2011 | Epson Printer
Parts inside your printer are near the end of their service life. See your printer documentation. _ Epson R200 printer.
Regarding the Epson Artisan 800, I must thank FixYa and ask that the search for a solution be discontinued.Yesterday, I had an unfortunate accident while trying to unclog the print head which had been printing poorly over the last three months. I used a syringe to force a solvent solution through the clogged head. To my utter surprise the supply line exploded with a loud "POP" meanwhile spraying ink all over the place. At this point it was clear that it was pointless trying to redeem the old Artisan 800. Thank you FixYa. Henry.
Feb 27, 2011 | Epson Stylus Photo R200 InkJet Printer
Service reqired The printer's ink pads are at the end of their service life. Please contact Epson support.
Not all the ink pulled from the ink-cartridges gets sprayed onto the paper.
Some of it ends-up in an absorbative pad.
Eventually, those pads get saturated with ink, and need to be "serviced".
Take the printer to any qualified computer-technician, for that servicing.
Feb 26, 2011 | Office Equipment & Supplies
Parts inside your printer are at the end of their service life. See your printer documentation.
Q: What should I do if my printer driver displays the message parts inside my printer are reaching their end of service life?
A: See the Epson Ink Pad Reset Utility page.
Epson Ink Pads Reset Utility
If your product is displaying an end of life service message, please view and complete the required information below to proceed.
Please explain the message I am getting in my printer driver that says parts inside my printer are reaching their end of service life.
Like so many other products, all Epson consumer ink jet products have a finite life span due to component wear during normal use. At some point, the product will reach a condition where either satisfactory print quality cannot be maintained or components have reached the end of their usable life. This is the normal product life cycle for highly mechanical devices like printers. This message is a warning that certain parts have reached the end of their usable life and that your printer will no longer work until it is serviced.
What parts are we talking about?
The message refers to the ink pads, which are actually a number of porous pads in the printer that collect, distribute, and very importantly contain the ink that is not used on printed pages. Ink is collected by these pads during the initial setup of the product, during cleaning cycles and when printing borderless photographs. Most users will not receive this message before the printer is replaced for other reasons. Some high volume users or those who use the printer for many years may receive this message about ink pads before other components reach the end of their usable life.
Why does my printer stop functioning when I get the message?
Epson is committed to ensuring the proper operation of all our devices to minimize the risks of property damage or personal injury during the lifespan of the product. The printers are designed to stop operating at the point where further use without replacing the ink pads could create risks of property damage from ink spills or safety issues related to excess ink contacting an electrical component.
Is there anything I can do to continue using my printer?
Epson recommends replacing the printer, but if you want to continue using it, Epson recommends having the printer serviced at an Epson Customer Care Center. You may also be able to have the ink pads replaced by an independent service provider and use the Ink Pad Reset Utility to reset the Ink Pad Counter to continue using the printer. Please note that replacement of ink pads is relatively expensive and may not be a good investment for lower cost printers because the printers' other components also may be near the end of usable life. Epson does not recommend ink pad replacement by users without technical training or resetting the Ink Pad Counter without replacing the ink pads.
Note: This utility is for Windows XP and Vista operating systems only. We hope to develop an option for Mac users as well; however, we do not have an ETA or the OS requirement at this time.
To download this utility, please complete all fields below, select the agreement check-box and click Download. Required fields are noted with an asterisk(*). Some models may require you to be redirected to another website to finalize the process.
Go here to complete the agreement and download the utility:
http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp
Dec 09, 2010 | Epson Stylus 1400 InkJet Photo Printer
Parts inside end life
Go to this link to complete the agreement to recieve the Epson Ink Pad Reset Utility.
Trust this is helpful. :)
Dec 09, 2010 | Epson Stylus Photo 1400 Printer
Epson L200 All-in-One Inkjet Printer 27 PPM Black, 15 PPM Color, 5760x1440 DPI, Color, PC Logo
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
