Question about Grundfos Plumbing
Wired up my Grundfos Jetpaq JQ4 Pump and absolutely nothing is happening. purchased unused but second hand so no manual. Where can i find the manual for this?
Wired up exactly the same as our existing pump which is the same model but no life at all it seems. If its new should i need to do anything else to get it working?
  • 3 Answers
SOURCE: My Grundfos JPS4 1 HP Pressure Booster Pump keeps coming on for a
Definately sounds like a leak in the pipes from the pressure side of the pump onwards, even the smallest leak will cause it to turn on to regain adequate pressure.
Posted on Jul 09, 2009
  • 523 Answers
SOURCE: Grundfos UPS 25-50 180 - start up
Are you able to check for power to the pump with a mult-meter. If you have power you the know the pump has siezed (flat spot on the motor) if there is no power then you know there are issues with the controls.
I hope this may have helped,
Tom
Posted on Oct 14, 2009
peterrance19
  • 399 Answers
SOURCE: need to find a user manual for a Grundfos pump
y can download from net
Posted on Nov 14, 2009
  • 234 Answers
SOURCE: New grundig pump is now making a kind of clicking
I was ready to pass your question and go to the next person because you said it was making a clicking, and I could not relate or diagnose that type of sound for that kind of pump. Thank God I decided to read to the end where you said rattling sound. that is what you should have said in the beginning.
1st, did you replace the pump cartridge or the whole pump unit? 2nd, is the pump in a different oriented position than the original pump position? The inner cartridge floats inside the pump as it rotates and if it is in an oriented position that allows it to bounce (to & frow) it will make this rattle sound; not serious but can be annoying. It is was a replacement cartridge, perhaps the new gasket and the old gasket are in place, thus allowing too much space for the cartridge and it therfore moves too much and rattles. Or, if it was replaced as a whole new unit. there is a problem with it that you should not be responsible for, except for the positioning orientation. Finally, if there is still too much air in the system, the air bubbles will jossle the cartridge untill you get rid (bleed ou ) the remaining air. Goodluck<Macgivor
Posted on Jan 02, 2010
SOURCE: need manual or diagram for teel pump 2p110a
2P110A Pump won't prime
Posted on Jun 03, 2010
Grundfos MQ 35 won't run
Sounds like the discharge is plugged. You can get the manual at: http://rainwatercollection.com/download/Grundfos-Manual.pdf
Jan 24, 2014 | Plumbing
Grundfos jetpaq pumps
Sounds like a broken connection or a link in the over temp circuit.
Or the controll is knackered.
I would say it is unlikley the motor has failed, I have stripped water related dead seized grundfoss units and freed them back up and they have outlasted an economy replacement unit.
I am assuming your unit is single phase, if it is there should be an internal OL reset.
I am not sure where exactly on your unit but if you open the control box it should be evident.
If it has tripped I would check the capacitor as over time they diminish in capacity which would lead to overloading or not start at all which would trip the OL very quickly.
Dec 01, 2013 | Plumbing
Grundfos MQ pump starts every 15 seconds
Pressure is bleeding back through the pump or system to the tank or well or where ever the water is coming from. Should be some sort of one way valve to keep water from going back to the source, mounted somewhere so that once pressure is pumped up, it will hold that pressure in the part of the system that has the pressure switch that controls the pump.
That or you have a leak where you can't see it. (Actually you do, it is just internal and not leaking outside the pipes!)
Nov 04, 2012 | Grundfos Pumps Grundfos MQ 3-45 1 HP...
Problem with mq pump
MAKE SURE THE PUMP IS WIRED FOR 120/220. THE WIRE GAUGE
SHOULD BE #12 OR #10 IF 100 FEET.
Nov 17, 2011 | Grundfos MQ3-35 3/4 HP Pressure Booster...
My water heater needed to be restarted and my comfort recirculation system isn't working now.I"m hoping it is just the timer. I need to reset the timer and I don't know how. I can't find my manual....
Grundfos timer and pump operate by plugging into ordinary 120V outlet.
1) If outlet has power, then dial on timer should rotate.
If dial is not rotating, then check power to outlet.
2) If outlet has power, but timer is not rotating then timer has gone bad > if grundfos pump is working but timer is not working, you can buy cheap plug-in timer and use that as the timer.
3) If outlet has power and pump is not working, then manually rotate timer dial to see if pump will start.
If pump will not start, then you need a new grundfos.
There are no repair parts for these pumps, and nobody at Fixya has reported taking Grundfos apart and repairing it.
My Grundfos pump will not come apart.
4) Following link has links to Grundfos installation manual, website, product manuals, and contact.
http://waterheatertimer.org/Water-heater-recirculation-system.html#Grundfos
5) To set timer: Grundfos timer dial has movable pins that are used to set on-off times.
When pins are pushed out, timer turns pump ON.
6) Rotate timer dial clockwise until current time lines up with arrowhead located on inner dial.
Dial rotates as time passes, and pins move a lever that turns pump on-off.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on Grundfos or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 09, 2011 | Grundfos Comfort System Recirculator ...
Need to find a link to the owner's manual/ repair manual for the Grundfos up10-16 b5/atlc......
Following link shows links to grundfos and grundfos manuals.
1) My grundfos stopped working because sediment clogged the pump, and the motor slowed.
When motors slow, they get hot and burn up.
I ask my friend who rewinds motors how to fix it, he said in the old days, they rewound every motor, but today they throw valuable scrap into landfill, and then buy new motors from China.
I told him not to retire, but go to school and teach kids how to rewind motors, and then took apart the grundfos line and cleaned it out with CLR, but it never worked again.
2) If timer stops working, but pump still works, you can buy cheap plug-in timer and connect grundfos to the cheap timer
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 23, 2011 | Grundfos UP10-16B5/ATLC Comfort Series...
Timer gets off by hours
I have circulation system on my water heater.
First system gave out.
When taken apart, it was clogged with sediment and couldn't be cleaned.
Put sediment filter on line, and second circulation system works fine, and timer works fine too.
I haven't had timer problem, but have investigated timer motors running fast and slow.
My friend who re-winds big pump motors says homeowner timer motors are engineered for 60Hz.
As long as electric power is 60Hz (60 cycle AC), then motor will keep exact time.
Since your household current is 60Hz and other electro-mechanical timers run correctly, then it's likely timer motor has a flaw or has gone bad.
Grundfos water heater re-circulation pump and timer are sealed unit.
Grundfos manuals do not show parts list or repair steps:
It's aggravating when expensive household timers like Malibu power packs and Grundfos pumps are not made to be repaired.
Nov 24, 2010 | Grundfos The UP1510B5ATLC 125th HP 1...
Just bought a house and it has a grundfos timer/pump attached at the hot water tank. I have no hot water and the timer doesn't turn (as I've seen other timers do). Is it supposed to turn so that the...
Grundfos is a sealed unit and not a repairable item.
The timer dial should turn.
And pins located around dial control ON-OFF functions as timer dial rotates.
Does the receptacle have power?
If receptacle has power, and Grundfos is not working, then it is broken.
Grundfos manuals for UP series pumps do not show breakdown or parts list of any kind.
http://www.us.grundfos.com/web/download.nsf/Pages
Bigger question:
Why don't you have hot water?
Is water heater functioning?
Water heater is a separate appliance from Grundfos pump.
Grundfos pump circulates hot water from tank into the lines so there is no waiting for hot water ... but hot water heater should still make hot water.
Add a comment about water heater if that is also a problem.
You could have 2 problems, and water heater is main issue.
For do-it-yourself electric water heater repairs:
http://waterheatertimer.org/6DIY.html
Nov 20, 2010 | Grundfos The UP1510B5ATLC 125th HP 1...
Plumbing Logo
406 people viewed this question
Top Grundfos Plumbing Experts
john h
Andrew Bugbee
Are you a Grundfos Plumbing Expert? Answer questions, earn points and help others
