Question about Cell Phones
My handset is karbonnk55 and i forgot my password need help
Karbonnk55 forgot my password
Go here, and listen!
https://www.youtube.com/watch?v=4zTqum0oIHU
Mar 19, 2014 | Computers & Internet
Break security code
Passwords are either set within the SIM card by their owner, or within handsets.
If the password is within the handset, that's because the original owner set one which would seem to highlight one of 3 problems. Either you set the password and forgot you set it, or you bought it from someone who forgot to remove the lock (inwhich case call them and get the password), or you have acquired the phone from a dubious source.
Nov 24, 2013 | Nokia Asha 201 Blue Unlocked Dual-Band GSM...
I forgot the pattern of my cellphone and i also forgot the answer to the security question
If you forgot the pattern and the security question answer, you can also override it with the google account that the lock pattern requests.
The Google account that the pattern lock requests will be the same Google account you have used to access the Android Market and other Google apps on the handset. If you cannot remember these details, you would need to reset the handset using the Update Service program.
This program resets the handset while the phone is completely powered off so there will be no need to use the touchscreen or access the phone at any stage. You can download the Update Service here:
www.sonyericsson.com/cws/support/softwaredownloads/detailed/updateservice/xperiax8
Jun 06, 2011 | Sony Ericsson X8 Cell Phone
Forgot Micro sd card password
which handset? There is a password recovery software avilable buit i need to know the handset of yours
Aug 05, 2009 | Cell Phones
Says enter password dont know password
If you dont know the password. Enter incorrect password ten times after this your handset will be wiped completely and then you can use your phone (*note exsisting data will get deleted if you do this)
May 27, 2009 | RIM BlackBerry 7290 Smartphone
I forgot my personal code.
contact ur carrier and u would be provided with the PUK code ...
If PUK code doesnt work use the pin code of the sim card
if u hace forgot ur password nothing can be done neither u can take backup nor u can retain data in handset. U will have 10 chances at the max to enter correct password, if done with it the handset will be wiped out.
May 27, 2009 | RIM BlackBerry Storm 9530 Smartphone
Forgotten Password - help to reset.
if u hace forgot ur password nothing can be done neither u can take backup nor u can retain data in handset. U will have 10 chances at the max to enter correct password, if done with it, the handset will be wiped out.
May 22, 2009 | RIM BlackBerry Bold 9000 Smartphone
Forgot privacy password
try doing master clear master reset on ur mobile that will do
May 01, 2009 | Cell Phones
Password
Hi
Only way to solve your problem is -
Contact a skilled mechanic having set-up of unlocking mobile handsets.
Need not to worry, very simple problem, your handset will remain same as earlier.
If you are putting password to lock your phone again, then please....please write it down carefully so that you can collect easily.
Supriyo DG
Jun 20, 2008 | Sony Ericsson M600i Cellular Phone
Cell Phones Logo
14 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
