Question about Maytag Neptune MDE6800 Electric Dryer
Wont heat and light is out
The light is out when you first open the door. Yet when the dryer is on and you open the door it comes on for a moment. Also the heat is irregular and not constant.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 33 Answers
Dryers either heat or they don't. If you have heat but clothes take a long time to dry, it will always be an issue with your venting system. That could be anything from a clog in the hose or at the outside exit, a smashed vent hose or a very long run of hose which will cut down on effective evacuation of the moist air, to name a few.
Posted on May 19, 2014
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: the light comes on when you open the door but the
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Posted on Dec 17, 2010
Eaton Viking 5 Dryer wont turn on
The door switch is a 3 way switch. Though the light comes on when the door is open the other part of the switch may be out for the dryer to start.
Feb 19, 2015 | Dryers
Gas dryer wont light with door closed
Check the exhaust to make sure that it is not clogged.
Jul 07, 2013 | Maytag Atlantis MDE7400AY Electric Dryer
Wont start when button is pushed
could be a bad door switch, wen door switch goes bad it wont start the dryer thinks the door is still open.
Dec 17, 2012 | GE GTDP300EMWS Dryer
Dryer wont turne on but inside light comes on
check the door switch as this switch has 2 positions one for the light on/door open and the other door closed light off and dryer can operate,depending the make & model will determine how to access this door switch
Feb 12, 2012 | Dryers
Led light panel inop.Dryer won't come on but the light in the drum comes on when opening the dryer door.
my guess the door switch. here is a website that will explain how to test it. if you do not know how to open the dryer then scroll down an click open a cabinet. Hope this helped Tim
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Apr 19, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Will tumble but not heat. The light comes on when u first open the door then shuts off. What can I do to fix this.
Hi,<br /> If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.<br /> <br /> Check out this tip that will give more details&hellip;<br /> <br /> Gas dryer not working gas dryer not heating<br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN"><a href="http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not" target="_blank">http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not</a></span><br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN"> </span><br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN"> </span><br /> If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat. <br /> Check out this tip to see the things that can fail to cause your electric dryer not to work.<br /> <br /> Dryer Troubleshooting Electric dryer wont heat<br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN"><a href="http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won" target="_blank">http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won</a></span><br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN"> </span><br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN"> </span><br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">heatman101</span>
Aug 25, 2010 | Maytag Neptune MDE5500AY Electric Dryer
My general electric dryer DDE5300 is no longer warm so clothes don't dry, though it runs. How can I tell if its the heating element or the thermostat?
You Will have to use an ohm meter and the tub has to be taken out. You can on a GE open the door and push in on the door switch and starte it with the door open and look straight in and see the heater come on but if either the heat element of thermostat is out the element wont come on. If you live in ahouse with fuses instead of circuit breakes or a fuse box between the dryer and main circut box check the fuses an electric dryer will run on one fuse but not heat if this is the case switch the fuses and see if it runs if not one fuse is bad.
Apr 21, 2010 | Hotpoint NVL333EY Electric Dryer
The light will not turn off and dryer wont run
CK,
There's a switch behind the dryer door. Push it in and out with your finger, you should here it "click, click, click" and the light should go on and off. If it doesn't, you'll need to replace the door switch.
If that's the case, I'll need the full model number. It's on a sticker on the front panel behind the door. (it should be like three digits, decimal point and about 7 more numbers... 110.*******) With that number, I'll be able to look up parts for you and guide you through this easy repair.
SG
Apr 08, 2009 | Kenmore 64952 Electric Dryer
Dryer not heating
is this a gas or electric
Mar 27, 2008 | Dryers
Gas Dryer does not run, light comes on in drum, everything else is dead.
do you mean it doesn't heat or does not run at all. i would check the door switch, if its not running at all. try opening the door and push the door switch closed by hand, if the light doesn't go out replace the switch
Nov 11, 2007 | Maytag MDG7600AW Gas Dryer
Maytag Neptune MDE6800 Electric Dryer Logo
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
