Question about Panasonic Televison & Video
Mildew has entered the inside of the plasma tv
Mildew can be seen inside on wires cannot see more
    Master:
  • 397 Answers
Let me get this correct, you can see mildew/mould inside your TV? If it's inside the LCD panel (obscuring the picture etc) then I'd get the panel or TV replaced. If it's just on some of the other internal wiring and the TV still works ok I would give it a good clean with some alcohol (such as isopropanol) , perhaps put a sachet of silicon moisture absorption crystals inside the TV somewhere, seal the TV back up and hope it doesn't occur again.
Posted on Mar 19, 2014
Verticle lines on plasma tv
hi,
As you mentioned the problem can be realted to the plasma display panel. If you can open the tv then try on thing. When you open the tv you can see there will be ribbon wires going to the panel in the top and bottom side of the tv . You have to remove these connections from its sockets. now you will see some commponnets in the ribbon cabe. You have to resolder the SMD resistor in the board. Dry soldering in these resistors will lead to this problem. Also you have to check is there is any cooling fan inside your tv. Normally all plasma tvs have cooling fans inside. If the cooling fan dosen't work it will lead to overheating of components and this problem can occur. If all thses didnt help then the pannel is faulty. Have added a video which will help you its a different plasma tv
ok
Aug 26, 2011 | Panasonic Televison & Video
Model: Hitachi P50a402 plasma TV blinking blue light upfront but no TV signal or boot screen. Openned the unit and tried to get readings on power supply board, it seems I do have 3 and 5V but not able...
Did your already check your H- out section. This happen when your TV at protection mode. Its mean it detect defective parts inside the unit. Isolate the H- out power and open the TV Then check voltage if there's power reading meaning that the H- out section have problem.
Aug 12, 2011 | Hitachi P50A402 50 in. Plasma TV
Cannot seem to find Power supply (310432842861) for Philips Plasma TV 42PF9967D
the power supply is very easy to find. Just trace the wire that passes from the wall (or that passes electric current to the TV) to the TV.
The spot where the wire enters on the TV is the power supply of the TV.
Take care.
Jan 12, 2011 | Philips Televison & Video
I have a LG42PG20 plasma tv that the sound works, but the tv has no picture. The screen is blank, dark in color.
cleanning inside,,,,check the red wire that to the screen inside moved it around,,,,plug in,,,try on...works....or not.so on..broken....not around shocks
Aug 27, 2010 | LG 42PG20 42 in. Plasma HDTV
Poor sound on my plasma bad speakers
It could be the speakers or the main board. The audio circuit is comprised of the main board, speakers and wiring. That's it. I have seen pinched wires cause problems as well as the other components listed above. You can call 1-800-samsung or go to samsung.com to find the nearest authorized service center.
Mar 11, 2010 | Samsung 50 in. Plasma TV
Cracked on Inside glass on 42in Plasma-Panasonic
This sounds like the panel itself is cracked. If this is the case, the set wil not completely power up as youi have seen. The panel can not be repaired as such, it must be replaced. I can rpovide you with the part number and cost if you can post the model number. Be aware however, that the cost of the panel may come close to the cost of a replacement set.
Dan
Dec 10, 2009 | Panasonic Televison & Video
My sharp plasma tv (about 1 1/2 old) works but one day the remote just stopped working, i even changed the battery in it.....any suggestions?
Hello
I've seen this. This is a warranty issue. It's not the transmitter that's bad but the receiver inside the TV. Find someone in your area who does Sharp warranty.
Jul 28, 2009 | Sharp Televison & Video
My plasma tv keeps cutting off after about 1 hour and it does not come back on until i unplug it and then turn it back on and press enter
It sounds like your tv is failing. Similar problems have been seen with Philips tv's. tv needs servicing.
May 03, 2009 | LG 42LC2D 42 in. LCD HDTV
Maytag Nepture washer Model MAH 5500 boot mildew
The new boot replacements are anti-microbial have a smoother surface and are designed to be more resistant to mold issues with proper care. Unfortunately, there are still a lot of the old boot replacements out there. The part number for the upgraded boot is 12002533..., This part number supercedes all prior part numbers for the Neptune boot assy...Hope this helps
Jul 08, 2008 | Maytag Neptune MAH5500B Front Load Washer
Philips plasma
I had this problem. If you are saying it happened on your plasma screen rather than the receiver box, then the problem can be that the power source inside the plasma needs to be replaced.But Philips will charge a fortune for just looking at the TV. So you might as well take it to your local repair shop.
Jan 15, 2008 | Philips FTR-9964 Tuner/Receiver for Plasma
Televison & Video Logo
26 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
