Question about Panasonic DMR-ES35VS
TV recording shows snowy picture
When we record a TV program, and then play it back, it recorded a snowy picture rather than the TV show. We are missing something, but don't know what. PLEASE HELP!
SOURCE: remote control not working
I had the problem where when i would try to use my remote, it would say "check remote2". I've got a DMR-E55. I called panasonic and they told me to hold down the "enter" and "2" button for about 10 seconds. then it worked. hope it works for you too.
Posted on Jul 25, 2007
SOURCE: Won't format and or won't read disc
I have a similar problem in that it will not record at all or not record very well.  It has a drive inside like a PC DVD drive called the DVD RAM drive. The horrible clunking (grinding) sound is the disc slipping in the spindle. Unfortunately here in Australia the fix is to replace the whole drive (AU$350)!!
I have opened it up and tried to adjust the force of the spindle and it works for a while.
Hope somebody has a better solution.
Posted on Dec 05, 2007
  • 9 Answers
Look into your manual that came with your dvd recorder for DMR-E80H, Page 46, Changing the Remote Control Code. My child played with a remote control as well and reconfigured it as well. In the manual, you have explanation how to configure your remote control again to work.
Posted on Dec 17, 2007
SOURCE: Panasonic DVD player shows EXT-L in its display.
You have switched machine onto external link mode
Either press external link on remote or find it under the flap.
Has a small child been playing with the remote?
Posted on May 28, 2009
jasman_92627
SOURCE: My DMR-E85H has been showing
I just repaired this unit with the replacement filtering capacitors. This is a widely known problem. Hope this helps.
There is an article that addresses this very error and it has to do with the power supply filtering capacitors. I just repaired a unit and the fellow that brought into me said this a widely known problem. I replaced three of the capacitors ... two had leaked and the last one was bulging. Works fine now.
http://vassfamily.net/projects/DMRE85H/dmre85h.html
If you have questions or would like your unit repaired send me a note.
jasman_92627@yahoo.com
Posted on Oct 06, 2009
I'm using a coax cable from symphonic vr-701 to tv and trying to record. it acts like it is recording but just shows snowy image on playback
Coax from wall to coax in on VCR and Vcr Coax out to in on set.
Whatever channel vcr is on this way it will record and pass to set.
Check first you have playback from VCR to TV alone, could have dirty or blocked video heads which in record will just record no watchable picture. Hookup or blocked video heads are most likely.
Dec 13, 2012 | Symphonic Televison & Video
How do i fix a fuzzy picture on dvd recorder play back
What is the resolution of the recorder? If it isn't Hi definition, then you'll never get a really clear picture. OK for older TV's but not Hi Def. You can get a 2 position A/B switch and connect the audio and video OUTputs of the cable box to one side of the switch and the other side to the AV out on the TV.
Aug 09, 2017 | Televison & Video
Recording very snowy and blurred.
If recordings are only blurry and snowy on playback on camcorder, but are OK on a different camcorder or on computer, then the problem is a dirty magnetic head. Use a mini-dv head cleaner tape. If recordings are blurred even on pc or on a different camera, then there is a fault. Faulty CCD sensor, faulty digital board, problem with internal ribbon connector, and dirty or defective lens assembly can cause this kind of problem.
Jun 16, 2009 | Samsung VP-D103i Mini DV Digital Camcorder
Can't get to recorded programs
Check and make sure you have the DVD Recorder hooked up to the TV. I think you have the Cable box or Satellite hooked up or else you could not record. So there is a second set of outputs on the back of your DVD Recorder, Buy a set of RCA jacks and plug them into the Yellow,White, Red Plugs of your DVD Recorder, Then plug the other end into your TV in either L1 or L2 inputs, whichever ones are free.
May 12, 2009 | Panasonic DMR-E85H DVD Recorder
I have 2 DTV converter boxes - one for TV and one for VCR. The wiring is exactly as prescribed by manuals and FCC. VCR does NOT record programs from TV - altho it plays back pre-recorded tapes OK. I have...
Use only one box.
Connection should be:::Video Source(cable, antenne) connected to converter box:::::Converter box connected to VCR:::VCR connected to TV.
Try this connection and let me know how it goes.
Please rate this solution.
Lone99star
Mar 10, 2009 | Sony Televison & Video
Picture not clear when playing a recorded program from dvd
I had a similar problem with an Insignia converter box. This is confusing but . . . I was told by an Insignia person that you can only program the channel that you have on and cannot record a different channel. My output channel is 3. My roof antenna is attached to my converter box "From Antenna" jack. Attach the converter's "To TV (RF)" jack to your VCR's "Antenna Input" jack. Attach "Antenna Output" jack to TV "Antenna Input". You will see your programs on your output channel, but if your VCR is like mine, your VCR may not recognize anything but your output channel, no matter which station is actually showing on the TV. If I want to record a show on channel 7 while I'm gone, I have to make sure the converter station is on 7 and that I choose channel 3 as my channel to record. You cannot program shows to be taped on different stations unless you physically change it on the converter box. I put my VCR on "Record" and flipped the stations from one to the next from my converter remote control and I taped exactly what was on the screen from one station to the next. You cannot tape one thing and watch another. Clear as mud??? Hopefully, not.
Jan 02, 2009 | Insignia Digital-to-Analog Converter for...
Direct TV DVR sound/no picture or pict. no sound
My Direct TV has no sound or picture but does show channel info at the top. Any help is appreciated.
Dec 13, 2008 | Directv (R10) DTV Receiver / 70-Hours...
Direct TV DVR "skipping" like a dvd
You have an internal hard drive error. You will need a new box.
Jan 22, 2008 | Directv Plus DVR DTV Receiver / 100-Hours...
Can't set this thing up
I have the same model and it works wonderful, but you need the remote control to record.  connect cable from video out on recorder to video in on you tv. at least you'll be able to play the dvd.  If this doesn't work it's because you need the remote to set the date and time features.
Aug 26, 2007 | GoVideo R6640 DVD Recorder
Panasonic DMR-ES35VS Logo
16 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
