Reset calcuator How do I reset the calculator because whenever I want to calculate something, it always answers as a fraction. I know you can press the S<>D button to change the answer to normal, but with more complex calculations it only gives answers in standard form or a fraction
    Sergeant:
  • 322 Answers
Try this, press shift mode, then line 10. It will make it permanent. the answer will always be in decimals. if you are using a casio with ES models.
Posted on Jun 14, 2009
I had the same issue with my Ti-89 and I found that simply putting a decimal somewhere in the fraction makes it automatically convert to a decimal. for instance: type 2./3 instead of 2/3 and you'll get .666667
Posted on Aug 15, 2010
How can i factory reset
Press the [S<=>D] key to convert from fraction to decimal and back. Any information you need is in the manual.
Aug 14, 2014 | Casio FX82ES Scientific Calculator
Tip
Sharp ELW516: Changing the default display to decimal
<span><b>Getting Decimal Answers by Disabling WriteView<img src="elw516.gif" /> on the Sharp EL-W516 Calculator<br /><br /></b>The Sharp EL-W516's WriteView display uses multiple lines to display mathematics as it is seen on a page. Fractions are shown as fractions, exponents as exponents, integrals as integrals, and so on. This makes entering calculations easier, and reduces the chance of errors. <br /><br />At the same time, calculation results are displayed as fractions (or with roots or pi) whenever possible. Pressing the CHANGE button repeatedly will change these to decimal answers. <br />If you prefer to always get decimal results you need to <b>disable</b> <b>the WriteView display mode</b>. Doing this will make the calculator display like the Sharp EL-546W when in NORMAL mode. Answers will be given as decimals, but fractions will no longer look like fractions. In general, you will still need to follow the EL-W516 instructions.<br /><b>Disabling WriteView<br /></b><br />Press 2ndF and MATH to enter SET UP. Now press 2 for EDITOR.<br /><br />There are now two options: 0: W-VIEW, and 1: LINE<br /><br />Press 1 for Linear display mode to disable the WriteView display, and to get decimals as your answers.<br /><br />To return to the WriteView display, go through the steps above but press 0 for W-VIEW.<br /><br /><b>NOTE</b>: It is not possible to have decimals as the default answer form when in WriteView mode. <br /></span>
on Mar 04, 2011 | Sharp ELW516 Scientific Calculator
Casio-fx300 ES if i enter 2.5+2 it answers as a fraction of 9/2 how do i reset this to calculate correctly
There is a misconception that fraction are less correct than decimal result. Quite the contrary. Calculations with fractions and/or with radicals are exact while decimal calculations are approximate.
Anyway, you want decimals and so decimals you will have.
When a result is displayed in fraction or radical (root form), just press the [SD] key and it will give you the so desired decimal representation.
If somehow you cannot stand the sight of a fraction or a radical, just tell your calculator so.
Press [SHIFT] [MODE] to open (SetUp) screen and press [2:LineIO]
Feb 15, 2011 | Casio fx-300ES Calculator
My calculator will show fractions instead of decimals when doing division. How do I change that? There is a N1 displayed in the lower left corner also...I think that may be the problem
Getting Decimal Answers by Disabling WriteViewelw516.gif on the Sharp EL-W516 Calculator
If you prefer to always get decimal results you need to disable the WriteView display mode. Doing this will make the calculator display like the Sharp EL-546W when in NORMAL mode. Answers will be given as decimals, but fractions will no longer look like fractions. In general, you will still need to follow the EL-W516 instructions.
Disabling WriteView
NOTE: It is not possible to have decimals as the default answer form when in WriteView mode.
Feb 07, 2011 | Sharp ELW516 Scientific Calculator
How do i get out of fraction form? -Whenever i try to do division, the answer is always in fraction form and i want it in decimal form
To convert a single value from fraction to decimal, press SD. To have all results come out in decimal, press SHIFT MODE 2 to select LineIO mode.
Sep 15, 2010 | Casio FX-115ES Scientific Calculator
Why does the answers goes to fractions
In MathIO mode the calculator tries to display answers as fractions whenever possible. You can convert a single result to decimal by pressing the SD key just above DEL. To have all results come out in decimal format, press SHIFT MODE 2 to select LineIO mode.
Sep 12, 2010 | Casio FX-115ES Scientific Calculator
Whenever i do a large sum, for example 102795/600,...
Let us first set the record straight: Your calculation is a division not an addition. Be it as it may, the result you obtain is correct the fraction is equivalent to the one you entered, the difference lie in the fact that the calculator reduces the (entered) fraction to its simplest form.
Both the numerator and the denomonator have been divided by 15.
If the result is already calculated and displayed, press the [S<=>D] key It will convert a fraction or radical to decimal. This is always possible. If the result is decimal it may be converted to a fraction or a radical (Not always possible).
If the expression to be evaluated is still in the command line and you have not pressed the [=] key, you can force the result to be displayed in decimal format by pressing [SHIFT][=] instead of just [=].
More permanently. If you do n o care for fractions and radicals, set the Input/Outpout mode to LineIO. To do do press [SHIFT][MODE] to access the (SETUP) screen and select [2:LineIO]
May 21, 2010 | Casio fx-300ES Calculator
TI-89 decimal to fraction
Here is what you do:
1) Press the Mode button.
2) Scroll down the list that appears until you find "Exact/Approx".
3) Change the setting for "Exact/Approx" to Exact.
4) Press enter to save the settings change.
You have three possible settings for "Exact/Approx":
1) Auto - The calculator will try to determine the best format.
2) Exact - The calculator will always give the answer in fraction form.
3) Approximate - The calculator will always give the answer in decimal form.
Nov 15, 2009 | Texas Instruments TI-89 Calculator
When I divide answers are always given in Fractions. Can I change it to come out in decimals?
To change from Fraction display to Decimal display on the Casio fx-300ES (and probably other calculators)
1) Press the "SHIFT" button
2) Press the "MODE/SETUP" button
3) Press the "2" button
This Changes it to LINEIO (Decimal)
Doing all of the above but pressing the "1" button instead of the "2" puts it back into MATHIO mode (Fraction)
Hope this Helps
(SHIFT)(MODE/SETUP)(2) to change to decimal
Nov 07, 2008 | Casio fx-300ES Calculator
Casio Classpad 300 plus
I bought a classpad 300 plus but I dont know how to operate it. I saw some books for classpad 300 and I really want to buy some. However everytime I try to buy, there is always a classpad that goes with the books . Can I buy books for classpad with out buying a calculator anymore?
Sep 13, 2007 | Casio ClassPad 300 Calculator
1,057 people viewed this question
jasbo
jasbo
