Question about Audiovox Jensen JTFT-250 2.5 in. Handheld Television
How do I slide the Jenson VR187 out to be able to attach an aux cable?
How do I slide the Jenson VR187 out to be able to attach an aux cable in the back?
Hi my name is Gary trying to get phone Android to work on Bluetooth on Jensen 3020 vs have connection no sound coming through speakers in my F-150 Ford
The thing people often miss with setting up Bluetooth is pressing the button on the device you are connecting to. Most people think if they set their phone to search for the Device, it will find it, but you have to tell the device to send out a signal on the phone to pair it. On you Jenson 3020, you have to select Bluetooth. Start at page 15 of the manual.
The unit also has a Mute button.
Videos here
https://www.google.ca/search?biw=1366&bih=659&tbm=vid&q=set+up+Bluetooth+on+Jensen+3020&oq=set+up+Bluetooth+on+Jensen+3020&gs_l=psy-ab.3...356117.357977.0.360542.7.7.0.0.0.0.469.851.3-1j1.2.0....0...1.1.64.psy-ab..5.0.0.z7LrM-lRNdo
http://www.jensenmobile.com/docs/common/VX3020/VX3020_OM.pdf
Jul 30, 2017 | Android Cell Phones
I hooked up an aux cable to my KDC-MO4028 but the aux input option is not coming up as an option for one of the sources.
Hi David,
A decent info page for this radio and options is at Crutchfiled. They seems to provide good / very good information on all the products they sell. Service and pricing is up to you. To use Aux inputs, you need to purchase and connect the optional Aux Input Adapter (picture below).
Crutchfield sells these for about $20, and they plug into the jack on the rear of the radio. The jacks on the cables attached to the radio are preamp outputs - not inputs; and will not work as an input.
Here's a link to the manual (free download). Good luck!
Sep 30, 2011 | Kenwood KDC-MP4028 CD Player
I'm trying to plug an active speaker into aux 3 for a third monitor mix but it doesn't work (I do the same with aux 1 and 2). Am I missing something? Cheers,
I answered another post of this earlier. The AUX3 is strictly POST FADER... you MUST turn the channel sliding fader up to send signal to AUX 3. Also the AUX3 channel gain KNOB must be turned up. Also the AUX master gain KNOB must be turned up. Make sure your cablles are balanced TRS cables from the mixer to the powered speakers.
Sep 02, 2011 | Soundcraft FX16ii 16Channel Audio Mixer
How do i download of a i mac to a jenson mp3 player
According to the manufacturer's web-site:
http://www.spectraintl.com/jn/smp-xgbl.htm
Standard Accessories Included:
USB Cable, User Manual & PC Driver CD-ROM
Minimum System Requirements
Microsoft® Windows® 2000 or Higher, USB Port, CD-ROM Drive
It says nothing about their software working on a Mac. Sigh.
Apr 10, 2010 | Adobe Type Jenson MM Full Version for PC
Sony DHC-MD333- Is there AUX to attach to laptop??
the lines in for the tape deck would likely work. or look for any other inputs on the unit.
you will need a mini (headphone) jack to stereo RCA cable's. your local radio shack sells them. walmart also carries them.
you can also use an headphone extension cable and coupler then connect the coupler to the headphone to RCA cable.
picture of it here
http://budgetgamer.files.wordpress.com/2008/08/audio1-rca-to-headphone.jpg
Aug 06, 2009 | Sony DHC-MD333 Shelf System
No sound when playing DVD from Power Acoustik DVD to Jenson TV
My first question is on the main radio is there any aux, or any switch or if you plug headphones in to it do you get sound
Jul 19, 2009 | Power Acoustik PMD-100NT Car Video Player
Aux cable snapped of inside external Audio port (AUX). an ideas on how to get the piece out? or does anyone now how to take the AUX port out of the console? 2008 crv, center console unit.
I have a 2007 CRV which had the same issue. I fixed this by:
- first removing the AUX port cover by carefully prying it up from both the rear-facing and front-facing edges. Once done, this exposes the AUX port mechanism itself.
- Using some needlenose plyers, I pulled out the AUX port component. It simply slides out.
- The trick now is to PUSH the broken piece out of the inside of the port. To do this, I first removed the "cover" that is covering the end of the port (opposite from the opening to the port). Be very careful with this step as you don't want to break the cover. It's very thin plastic.
- Once this cover is removed, I used a pin to push the piece that was lodged inside back out of the opening.
Reassembly was the opposite of this and was quick.
Hope that helps.
- Dave
Nov 19, 2008 | 2007 Honda CR-V
Where is the AUX input on this player?
Sorry, but the RCA jacks for Aux input are only available in the back of the player. If possible, you could try to attach RCA jumpers to the jacks without removing the unit, but as I have no idea of the vehicle involved, I can't say if that would be possible. IF you have the "Release" keys, sliding the chassis out should not be a problem. Slide out, attach jumpers, and slide back in after routing the jumper cable(s). (This also assumes the unit was slid in using the standard slide in and lock mounting.)
Hope that isn't all bad news. Good Luck.
Nov 01, 2008 | Panasonic CQ-C7103U CD Player
Wiring with a sattelite receiver and new Samsung TV
Nope RamaTheMan - you are incorrect! No way to get an actual surroundsound from your TV on this turd - this came straight from the Samsung FAQ -
"You cannot get surround sound from your television. On the other hand, if your television has audio output jacks you can connect your TV or Set Top Box to your Home Theater System and get stereo sound (that is, sound from the left and right speakers of your Home Theater System only).
To connect your TV or STB audio output jacks to your Home Theater System and get stereo sound, follow these steps:
  1. Turn off your TV and Home Theater System.
  2. Connect the Audio Out jacks on your TV to the External Audio Input jacks on the back of your Home Theater System. The External Audio Input connectors are typically labeled AUX IN. Note: There are usually two pairs of Audio Input jacks, AUX 1 and AUX 2. Each pair has a jack for the left audio input and the right audio input. Often, there are two Video AUX IN jacks as well. You can plug the audio cables into either audio AUX 1 or AUX 2. See the following diagram.
  1. Turn on your TV and Home Theater System.
  2. Press the Function Button on the front panel of your Home Theater System until the display on your Home Theater System shows AUX 1 or AUX 2.
For advanced installation, if you are using a High Def STB, you can connect an OPTICAL connection from the STB to the HTS. This is a specified cable that must be purchased separately.
In either instance, you must then set the HTS to its auxiliary input. (i.e AUX 1, AUX 2, DIGITAL IN) in order to get the sound from the HTS.
Note: If your television does not have Audio Out jacks, you may be able to get stereo sound by attaching the Audio Out jacks on your VCR to either the AUX 1 or AUX 2 audio inputs on your Home Theater System. If you attach your VCR to AUX 1 or AUX 2, you will have to tune your television to channel 3 or 4, and then tune to the station you want to watch on your VCR."
Dec 26, 2007 | Samsung HT-X50 System
Audiovox Jensen JTFT-250 2.5 in. Handheld Television Logo
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
