Question about Cameras
He laid it down on the table, went to walk away and it shattered. Glass and all
2 andrids 1) WEB CAMERA STOPPED WORKING AFTER 9 WEEKS, 2) SECOND ONE (BOUGHT THE SAME TIME) was put on the table after using and shattered in pieces, including the glass screen ??? HE SAID IT WAS LIKE SOMETHING FROM, 'RIPLEYS' BELIEVE IT OR NOT". He had to believe it and he is beyond shocked. He is 9 yrs, old. He was doing a school project. What recourse do I have ??? They, Zeepad, offered no warranty. Theses things should not have happened at all. There must have been a problem before I bought them. Please help, I am losing my mind and money $120+tax and shipping. Thank you, Jenn nanajjk3@msn.com
    Top Expert:
  • 22,788 Answers
There must be a warranty as that was not cheap to buy. T bet if you quoted your statuary rights as a consumer, they will make good.It is bad practice to sell faulty goods.
Posted on Mar 19, 2014
Testimonial: "I bought it from nomerack, they is no warranty ."
sonyspares
  • 89 Answers
SOURCE: Power button stuck in down position
You may have to change to switch portion and if you need assistance in blow up diagrom or spares, contact me.May take 3 to 4 weeks to get from Sony service.
Posted on Mar 29, 2007
  • 3 Answers
SOURCE: Digital camera
I had almost similar problems with my A10 from day one. The camera shuts down before the battery is depleted, most of the time while I was operating the zoomlens. I bought a new battery, but that didn't solve it. Later I decided to take it apart as a last option. As my suspicion was the zoomlens I took out two crews of the motor that operates it. Now the motor has a bit more space to move. It seemed to be too tight against the gears so it could cause an overload. After that it worked perfectly. I made pictures for hours without having the same fault again. Be carefull too make notes where all the tiny screws belong of the casing. And maybe it will be enough to just loosen the motorscrews, but leaving them out will not make it fall out of it's place. I hope someone can use this information.
Greetings, Ron Timmermans.
Posted on Jul 25, 2008
  • 3 Answers
SOURCE: my camera won't work at all it just says batteries depleted even with new batteries
try taking the camera to ur local hp dealer and smash it to the ground jump up and down shouting i feel better now ha ha ha ur all nuts michael
Posted on Aug 06, 2008
t00nz
  • 4738 Answers
SOURCE: Canon power shot sx100is LENS ERROR
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Don't want to get your hopes up too high, but here are some things that you can do to try to correct it. They only seem to work for about 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Posted on Nov 15, 2009
  • 320 Answers
SOURCE: digital sport head camera e-at18g
I've the same cam, without any problems... Clean the battery contacts in the batterycap and down in the batterycase... Should help!
Posted on Jan 06, 2010
I've got a rattan Outsunny cube patio set. My glass on the table shattered in the hot weather and I've been trying to get in touch with Outsunny to complain about it. Can you help me please.
Armoured glass is used for table tops, oven tops etc. To get the glass to break/shatter, it requires temperatures exceeding 200 degrees Centigrade and then cooled quickly in one spot or something has been dropped on it.
Jul 12, 2017 | Ovens
Hello. I just received a new Glass Touch ASM (WB27T10875) for my GE stove. My previous one cracked and needed to be replaced. Problem: While installing/ connecting the ASM to the stove, once I connect the...
Funniest thing. I was having the very same problem on Monday. Every time I laid the glass touch panel down on the stove, it stopped working but worked when I held it up. After failing to install the panel so it would work for 30 minutes, I walked away from it and ate dinner. Coming back later, I decided my problem was the connections on the back side were coming into contact with the metal so I placed a tightening knob in the center of each of the outside holes making sure the underside of the knob went exactly into the middle of the hole. I then lowered the left side of the panel down to where the threads started and very carefully partially tightened the left knob so none of the panel back touched the stove. I then lowered the right side until the knob touched the knob and tightened that side finger tight. I keep testing the buttons to make sure they were still working. When the out side knobs were finger tight, I finger tightened the 2 inside knobs. Success. My oven is now working.
Aug 03, 2013 | GE GLASS TOUCH ASM WH - WB27T10873
My urban beatz tempo over ear headphones won't work they play no sound at all connected to my I pod or computer it just happened out of nowhere?
I have that same problem and I need a answer but I walked in m class and the chord hit the table and it just stopped mine is about a week old also
Sep 08, 2012 | Audio Players & Recorders
Amana oven model ACF4225AC the big oven power ...
have and Amana oven/stove model ACF4225AC that is 8 yrs old. Middle glass (thick tempered) part # 32028101 completely shattered. Oven was not on for at least a week, noone was near it,was not hit,and at 9 AM while I was in other room it just shattered into a million pieces. Went to dealer- looked up part and found it was no longer available. I have been checking internet appliance part companies, and e-bay to no avail. Cannot find replacement glass. Any suggestions? Thanks, Jim
May 21, 2010 | Ovens
I need help writing a complaint letter to art van
I would also contact the Better business bureau in your area. I have had a lot of luck going through them.
Jan 31, 2010 | Computers & Internet
Tenant dropped a shot glass down the drain and it shattered. Will the Badger 5 chew up the glass, or do I need to get it out?
Yes it will. Turn it off and onn a few seconds until the thickest part is broken up and then run it with the cold water on several minutes to flush it out.
Nov 02, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Glass is shattered to to replace
To replace the door glass do the following:
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Remove the inner screws. Keep all set of screws ordered, and take noteof the order you remove them. You will follow reverse order inreassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
See diagram below , click on picture to enlarge:
dd5ebd3.gifclick here
Inner Door Glass
May 15, 2009 | Maytag MER5765RAW / MER5765RAQ /...
2006 toyota solara, alarm keeps going off
Those cars have a frequency sensor that is attuned to the exact sound frequency of breaking glass. Are there any noises nearby that resemble glass shattering? Wind chimes? Any type of extraneous noise at the freq of glass breakage will set off the alarm.
Feb 27, 2009 | 2006 Toyota Solara
Canon 430 flash
the best will be to take the flash to a canon repair center
you can try to repair it yourself, you will need a peace like this:
http://cgi.ebay.com/CANON-420EX-430EX-580EX-HOT-SHOE-FOOT-LOWEST-INTL-SHIP_W0QQitemZ370071354531QQcmdZViewItem?_trksid=p3286.m20.l1116
Sep 09, 2008 | Canon Speedlite 430EX TTL Flash
Cameras Logo
49 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
