Question about Dryers
Replacing broken belt on beko drcs68s tumble drier
I have to replace a broken belt on my Beko tumble drier. I'm really nervous that i might actually cause more damage. After taking off the top and the back do i have to disconnect any wires or anything? Or is it a case of pulling the drum back and slipping the belt over the drum? then putting everything back? I am aware that putting the belt on the motor bit at the bottom is going to be difficult but im struggling with how to get the belt over the drum?? my model is beko drcs68s condensor dryer. Any help would be most gratefully appreciated.
SOURCE: Unsure how to access drier to put on new drive belt
Here is my own solution...
Disconnect from mains (of course) remove top (2 screws at back near top) Unplug electric connectors (on back panel, top RHS). Make sure note what goes where! Lie unit down on front remove screws (2) holding the drum spindle cover (centre of back) and remove cover pop off the circlip holding drum spindle, and washer unscrew back panel - hex headed screws round outside of back Remove screws at bottom of back panel which screw into the plastic vent housing (3 I think) Lift whole back off. (there's a plastic lip at bottom - need to pull away from this a bit) The drum spindle will be unsupported now, so don't move unit Full access now to drum and motor beneath Get and put on new belt reassemble.
Actually, having got into unit, found could not get belt from local spares shop (it had closed down), so bought new drier!
Posted on Dec 18, 2008
SOURCE: Beko tumble dryer not drying.
is there a reset button on a beko tumble dryer drvs 62 w pls
Posted on May 14, 2009
  • 3513 Answers
SOURCE: how do i replace a
Thank you for contacting
Unplug the unit. Take the top off. The rear panel has to come off of the appliance. Remove the top panel and loosen all screws on complete back panel having removed circlip holding the drum spindle on to the back panel. You will also need to disconnect wires/leads on top right inside panel. Take all the screws holding the panel on out. Take the parts the drum spindle comes through off.Take the rear panel out of the way. Fit the belt to the drum and stretch it over the motor shaft.Fit the rear panel to the drum first and fit the parts removed from the spindle. Lift the rear panel into place and screw it back on. Ensure the drum is located into the front panel of the appliance.
Please get back to us if you have any further query.
Have a nice day.
Posted on Nov 30, 2010
SOURCE: i have a beko drcs68s
Take the back cover off. The thermostat is located next to the heating coil, usually held on by two wires.
Your local parts supplier will also be able to test it for you to see if that the problem before you buy it
Posted on Feb 16, 2011
  • 842 Answers
SOURCE: Beko Tumble Dryier - Model DRVS 73 W the Belt 9PHW
Very easy on all tumble dryers.
This is simply a case of:
Take the top off the machine (Usually a couple of screws holding the lid on at the back).
Or - Rempove the inspection panel from the back
Drop the new belt over the drive motor spindle
On some machines you may need to thread the belt around a tensioning wheel
Now take the belt and place it on the side main wheel that drives the drum and simply spin the drum wheel with your hand, guiding the new belt into place as you spin the wheel.
It should simply stretch a little and work its way onto the wheel as it is hand turned.
Note, once it is on, take a look at the drive motor and make sure that the belt is sitting in the same place as the old one. Most of these motors have a slotted spindle and you can see from the clean and shiny surface where on the spindle the belt used to sit. If it is a little out of place, once again just take hold of the belt and pull it toward you or push it away as you spin the main drum wheel in order to move it into the correct slot.
Posted on Jun 23, 2011
Take your pick :>)
  • Beko DRCT70W Tumble Dryer Spares ' eSpares Beko DRCT70W Tumble Dryer Spares. 11 to 20 of 110 items. 1; 2; 3; ... Genuine Beko spare part for select tumble dryers More information . In Stock . Stock Number ...
  • Freestanding 7kg Condenser Tumble Dryer DRCT70 ' Beko UK
    • 8.9/10
    • 16 RATINGS
    Freestanding 7kg Condenser Tumble Dryer DRCT70. Toggle navigation. ... Beko freestanding products are guaranteed against the cost of ... please visit our spare parts ...
  • Beko DRCT70W Tumble Dryer Spares ' BuySpares Buy your Beko DRCT70W Tumble Dryer Spares at BuySpares ... Beko DRCT70W Vent Kit Condenser Box (2m / 4" Hose) BuySpares Approved part. Suitable for: Beko DRCT70W.
  • Beko DRCT70W Tumble Dryer Spares Buy Genuine Beko Tumble Dryer Spares with confidence at 4Beko ... Beko DRCT70W. If your tumble dryer is showing that the tank is full but it is infact empty, ...
  • Beko DRCT70W Tumble Dryer Parts ' Partmaster Get the Beko Tumble Dryer parts you need at Partmaster. Our Beko Tumble Dryer parts range is available for delivery worldwide and for UK customers there is the option ...
  • Beko DRCS76W Condenser Tumble Dryer - Parts/spares ' eBay Beko DRCS76W Condenser Tumble Dryer - Parts/spares 0 ... BEKO Tumble Dryer DRCS68W DRCS76W DRCT70W DRVS62W DRVS73W ... Beko Condenser Tumble Dryer ...
  • Beko DRCT70W Condenser Process Fan Assy. ' Buy Beko spares for your cooker, dishwasher, fridge, freezer, tumble dryer and washing machine. Authorised Beko Dealer & Next Day Delivery available
  • BEKO DRCT70W MANUAL - time dryer beko pdf '' download beko drct70w tumble dryer spares espares pdf ' ... how to mend it com beko condenser dryer drct70w free pdf '' download beko drcs68s
  • beko tumble dryer spares > Search > beko tumble dryer spares beko tumble dryer spares. ... Universal White Knight Beko Tumble Dryer Indoor Condenser Vent Kit Box With Hose. by Lazer Electrics. £6.22. More ...
  • Beko DRCT70W Tumble Dryer Spares Buy Genuine Beko Tumble Dryer Spares with confidence at 4Beko - Beko Approved Dealer and Next Day Delivery available!
  • wa+cwowlplelaaaaaasuvork5cyii=
  • Jul 21, 2016 | Dryers
    Hi I'm getting no heat from my beko drvt 61 w tumble dryer, have replaced the front thermostat, heating element and cleaned filter at front but still no luck is there any more I can do?
    Did you check fuse that might be near mains entry into the machine ? Why did you replace the heating element ?
    is rest of machine working ?like fan motor running ?
    sens more details so that I can pin point the trouble.
    Oct 03, 2015 | Beko Official Drvs62w Belt Poly V - 1967...
    How can i change the small belt 4-PHE-285 for Beko tumble drier DCU 9330W ?
    Hi Victor - I have the same issue I have exposed the motor and removed the larger belt and the spring but I can not see a way to get the smaller belt over the back spindle (The part the actual motor is attached too) - did you manage to do this? did you have to take the machine apart completely to fit this?
    Jun 29, 2014 | Dryers
    Clean filter light comes on after every drying cycle.Any ideas.thanks
    Hi, this may just be the manufacturers way of reminding you to clean filter after every use ( comes up on my Samsung machine), not a fault. All the best.
    May 04, 2014 | Beko Drcs68s/w Tumble Dryer Fluff Filter...
    My beko condensor dryer is not turning anymore, the heat is fine but it doesn't tumble
    Drum will not turn or rotate
    1.broken or slipping belt---replace belt
    2.jammed or bearings frozen ----check for foreign article between drum & shroud
    Replace defective bearing or bearing support which allows drum to sag or hit
    3.loose pulley----tighten pulley set screw
    Sep 22, 2011 | Dryers
    I have a beko drcs68s tumble dryer spinning but no heat how do you change the thermostat
    Feb 16, 2011 | Dryers
    How do i change my tumble dryer belt on a beko thanks
    Just changed the belt on a Beko DRCS68W and its a real pig! Remove the top panel and loosen all screws on complete back panel having removed circlip holding the drum spline on to the back panel. You will also need to disconnect wires/leads on top right inside panel to give you more space. Once you have done this you should be able to ease away the back panel far enough to get the new belt around the drum and over the drum spline in the middle. Then the tricky bit - getting the belt tensioned on to the motor drive spline. I did this before securing the drum and back panel, which gives a bit more flexibility. I also used about 15ins of 15mm copper pipe to ease the belt down over the motor spline. Hard part was getting the back panel back lined up with the screw holes as the belt tension distorts the casing. Finally hit on the idea of lying the machine on its side so the weight of the drum is pulling away from the motor and helping to line up the screw holes. Two and a half hours later job done! I guess if I ever did another it would be a whole lot easier but still not the type of job I relish!
    Mar 06, 2009 | Dryers
    Dryers Logo
    37 people viewed this question
    Top Dryers Experts
