Android tablet not connecting to my bt hub
Keep getting authenticating problem showing
    Master:
  • 397 Answers
Delete the connection from your Android device, select your home-hub and enter the password again. If that doesn't work, try restarting both your tablet and your home hub and try again. If you still have no success, changing the type of security the home hub uses can help.
Posted on Mar 19, 2014
Paeroa
  • 457 Answers
SOURCE: BThome-hub connection
its poked get another particularly if everything is going good.............it has to be f........
Posted on Jul 15, 2008
  • 86 Answers
SOURCE: cannot connect to wifi on our bt home hub
Could be a variety of reasons.
Assuming you have not had it working before
Assuming the wifi is broadcasting it SSID
Assuming you have laptop connected by ethernet cable to hub:
Assuming you have XP:
Go to start/control panel/network connections/right click the wireless lan icon and select properties/select wireless connections and delete ALL previous entries.
With Vista go:start globe then
Control Panel\Network and Sharing\Manage Wireless Networks and delete all entries
Now:
press windows key and R
type cmd and enter
type ipconfig and enter
note lower set of figures ie 192.168.0.1
open browser and type in those figures and enter
should now open router firmware
When asked for log in use defaults of admin - admin or admin - password
navigate to wireless security and set encryption to WEP 64bit and create a simple encryption code - save settings
Change broadcast channel to 8
make sure wifi is set to open and not shared
Save all settings, allow hub to reboot and now see what happens
Posted on Dec 10, 2008
frankzjm
  • 191 Answers
SOURCE: Acer Aspire 7730 UNABLE TO GET WIRELESS CONNECTIVITY
you need to try
1) check bios aetup screen thereis setting wireless enable/disable
and check xp control panel--system--device manager wireless driver no yellow triangle mark( which need update driver)
2) check wireless switch at laptop frront or right side, set to "on" to make sure the wireless light not on. if wireless indicate light still black means your wireless card out of works, check wireless card by open small back cover clean pins and reinstall it again
3) finally you might need change a wireless card.
Posted on Feb 09, 2009
  • 3 Answers
SOURCE: I CANT GET CONNECTED TO BT HUB
have you typed the key exactly? viz uppercase/lowercase. The switch(hub) might have MAC address filtering on. also check if the switch(hub) has a DHCP running, which allocates IP addresses, if not you need to set your wireless connections IP address within the same range as the switch. If all else fails attempt to connect the switch via a utp network cable which should have been suplied with the switch(hub) so you can access the switch and make the necessary changes... email me on djtracer@vodamail.co.za should you need more info.
Posted on Aug 12, 2009
  • 13 Answers
SOURCE: acer tablet won't reboot
download this....http://www.multiupload.com/WCT2FYLMQC Leave folder compressed.
Transfer update.zip to an external SD card.
Place external SD card into tablet.
Hold the Power & - Vol buttons till it reads Booting Recovery kernel image
If you haven't attempted this before & did not root your tablet.
If it's within warranty, send it to ACER.
hen
Posted on Nov 19, 2011
I got new gigaset qv830 tablet can't connect to wifi & this is my first android
Android Tablet Wi-Fi Authentication Problem [Solved ...
www.tomshardware.com/.../45501-43-wifi-authe...
Tom's Hardware Guide
Oct 23, 2014 - 20 posts - ‎17 authors
I have a new Android Tablet, it seems to work okay, but I keep getting ... I am DETERMINED to get this tablet connected, though, and when I find ...
Gigaset 8" Quad Core 8GB WiFi Android Tablet w/Google ...
www.qvc.com/Gigaset-8-Quad-Core-8GB-WiFi-Android-Tablet-w...
QVC
Free
This holiday season, wrap up the gift that tops their list with this Gigaset QV830 tablet. Work and play--all from the same device.
Newsmy tablet T3 problem wifi connection - YouTube
? 3:48
https://www.youtube.com/watch?v=PSR9QU2eph8
Jul 31, 2012 - Uploaded by Jan Ochotnicky
Newsmy tablet T3 problem wifi connection. ... grey wifi/cant connect to google play error fix (root ...
[PDF]Gigaset QV830 Tablet - User Manual.pdf - liGo
Dec 26, 2015 | Tablets & eReaders
MY POLOROID TABLET WILL NOT STAY CONNECTED TO INTERNET. SAYS AUTHENTICATION PROBLEMS
Android tablet wifi authentication problem [Solved ...
www.tomshardware.com/.../43704-43-android-ta...
Nov 23, 2012 - 20 posts - ‎9 authors
Hello, every wireless device works except my new tablet from Acer running Android 4.1.1. ... Yes, I try to connect to the network router. ... You can hide the SSID - once your Android has it as a saved network it will ... gefraenk said: ... Hello all, I have the same authentication problem, worse, I m not sure what ...
Authentication Problem to Connect Android Tablet - YouTube
? 3:05
https://www.youtube.com/watch?v=2wul81jM7Ts
Apr 2, 2013 - Uploaded by Meroy Diniz
If you have Authentication Problem connecting you androidtablet. ... i got a different problem i cant even turn the wifi on, on my hudl 2 it blocked ...
Dec 25, 2015 | Tablets & eReaders
I cannot get started with the hudl 2 I have touched the screen with the bt wireless nuber but I still says authenication problem and check wifi settings
Make sure your tablet is updated on all its apps and software. If not and it has missed an update your tablet and it will show a authentication and wifi error.
Mar 20, 2015 | Tablets & eReaders
How do I get cnm touchpad 9 to authenticate wifi connection to the internet, what are the correct settings, keeps connecting to bt fon instead.
I am assuming you are on an Android platform, so the first thing you should check is to see if your Wifi is on....Settings, Wifi, then usually there is a on/off switch at the top...if its off turn it on and then try to join the wifi AP. If the wifi is on and your still connecting via bluetooth then shut bluetooth off, settings, bluetooth and try connecting...maybe there is a default setting somewhere forcing you to use the bluetooth ...I'd need to know what OS your using and the version number to give you direct information.
Dec 22, 2014 | Tablets & eReaders
Will not connect to BT HUB 5
Power cycle and try again. Ensure BT passkey is correct.
Motorola Support
Jan 29, 2014 | Motorola Mobility GOOGLE 8GB MOTO G XT1032...
Authentication Problems
wrong settings entered on tablet, try again.If possible connect tablet first via usb cable to computer or router to try connecting it , to determine the actual fault on connections.
Dec 28, 2013 | ZEEPAD New 7 Inch Android 2.2 Tablet Pc...
How do I set up my new MID M729 Android Tablet PC
my tablet android 4.0 loading how to sulution this
Dec 28, 2012 | mid Archos M729B Android Tablet
Connecting tablet to internet
I have no connection on my android tablet and when I try to connect it keep say authentication problem
Dec 21, 2011 | Tablets & eReaders
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
