Question about Ricoh Office Equipment & Supplies
My ricoh mpc 2551 is showing error 542 and i have replace with a brand new fuser unit yet not resolved. the worst part is that i could not log into sp mode to do sc reset. any clue pls. Am stranded here pls
  • Ricoh Expert
  • 398 Answers
Clear modes 1 0 7 hold stop 5 seconds, if you cannot get into service mode then the code will not be reset
Posted on Mar 21, 2014
4 Suggested Answers
  • 86 Answers
SOURCE: Ricoh Aficio MP 2510 SC 541, SC 542 Errors
To clear level A SC codes such as this SC541, you need to
Enter SP mode, and then turn the main power switch off and on, only.
Please check if the thermistors are the proper ones and are installed correctly in their position properly.
This is also useful for SC542.
Please check the thermostats and fusing lamps for open circuit.
Good luck and please rate me, thanks.
Posted on Jan 17, 2009
micromatikal
  • 2777 Answers
SOURCE: I need the reset procedure
This is how you reset that error:
press the yellow "C" button
enter 107
press the red "C" button and keep it hold till the display changes
turn the power off with the big red switch on the unit
turn power on again
Thanks much - if somehow that doesnt work please reply.
Tim
Posted on Oct 25, 2010
  • 183 Answers
SOURCE: How to reset the fuser
press yellow cancel and 107 and hold on 5 sconds on red cancel and yo will see 1 go to 4 and select 810 and press 1 simultanously with photo press you will see reset accepted or succes
Posted on Mar 26, 2011
Ricoh aficio SP 3510 error code SC 542
This is a fuser fault code. First need to check and repair fuser. Buy a new or rebuilt fuser or replace items that cause problem could be thermistor needs to be replace to over temp sensor is bad and needs to be replace or lamp. Once replace then you can clear code. You can buy. Service Manual will explain how to get into service mode and reset fault code. Or post how to reset code on web
Jan 03, 2018 | Ricoh Aficio Office Equipment & Supplies
Ricoh mpc 4500 sc 542
This a heat roller error. Get support at http://www.ricoh-usa.com/downloads/popup/popup_manuals_drivers_download.aspx
May 07, 2015 | Ricoh Office Equipment & Supplies
:Ricoh Aficio SP 3510SF error SC 542
Yes your MFP has had a fuser reload error. It's not permanent though. Sometimes the thermistors don't read the right temperature due to the thermistor getting excess toner built up on it or it gets moved away from the hot roller. This SC error usually can be reset by powering down the printer. It must be powered down correctly or you can corrupt the hard drive.
Hold the power button down on the operation panel until the screen goes dark. Then, physically turn the power switch off on the side of the unit. Once the unit has completely powered down and all lights are off, toggle the power switch back on. The unit should power back up normally. If the SC 542 returns, you'll have to have a technician check the fuser out.
Oct 24, 2013 | Ricoh Aficio SP 3510SF Laser Multifunction...
How to solve error SC452 for colour copier
sc 542 is the fuser error code. please check with a ricoh tech to fix it.
Jan 03, 2011 | Ricoh Office Equipment & Supplies
What is the error doe CS 542 on a Lanier 5645 thanks in advance
I know from experience that the AF2051 (B163) had problems with Fuser Errors. According to Ricoh direct techs after 100K to 200K copies on a new machine the Hot Roller would start to warp (ever so slightly) because of its thin wall construction (fast warmup time). I had 2 situations where I replaced the Thermisors,Themostats and the Thermostat Holders and the problem would keep coming back; after replacig the Hot Roller the problem was resolved (both copiers had between 135K and 165K when the problem developed).
Good Luck feel free for further assistance, rate, if helped
Nov 29, 2010 | Ricoh FT5832 Copier
Jan 17, 2009 | Ricoh Office Equipment & Supplies
Ricoh Aficio 2238c: Fuser Oil Unit
you really can not refill the bottle but I would recommend two things. One find a fuser oil unit on ebay and order it quickly. Next hit the yellow clear modes button, then hit the numbers 1 0 7 , then hold the red clear stop button till the display panel changes. hit copy sp, select 7 data log. now use the page down arrows located in the middle of the disply till you see 7804 push it then go to #10 oil supply and hit execute. this will reset the oil counter and allow you to use the machine till you get the new unit.
Oct 25, 2008 | Ricoh Aficio CL7000 Laser Printer
Ricoh aficio 2022 error code sc542
1. Mode(Yellow Button)
2. 107
3. Press STOP Button for 3 second (RED Button)
4. Copy Sp
5. 5810#
6. Excute
7. Power Off
8. Power On
Oct 23, 2007 | Ricoh Aficio 2022 All-In-One Laser Printer
Sc 542 error code
Error SC 542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won?t come ready until the prior error condition is cleared. The magic keystrokes, clear the error code: The Fix In order to clear error SC542, you must perform procedure 5810. Press and hold online + escape, then power on. Use up and down arrow keys to select SP2 Press Enter Use up and down arror to locate SP5 Press Enter Use up and down arrow keys to select 810 Press Enter Confirm the selection Power off and on. The error code is now cleared.
Aug 13, 2007 | Ricoh Aficio 2015 Copier
153 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
