My dishwasher quite
Washer stopped after start of first cycle start and can not able to do any thing no matter what I do?
    Master:
  • 397 Answers
The first step in finding a solution to this issue is posting it in the right section, you have posted about a dishwasher in the "PC Desktops" section.
Posted on Mar 19, 2014
Why does by dishwasher not cycle through
The timer controls the electro-mechanical components in the dishwasher such as the wash pump, drain pump, inlet water valve and heating element. The timer also advances the control knob on the control panel. Replace the timer if it fails to start and stop the components properly or fails to advance the control knob. Dishwasher Won
Oct 26, 2017 | Frigidaire Dishwashers
Fast flashing
The outlet pump could be triggered because the "anti flood device" polystireen float and micro switch at the base of the washer has detected a water leak from a leaky hose or water spil) This device automatically puts the pump out motor on and stops any washing process.You need to dry the base of the washer and determine what caused the water spill. This should start the washing prosess.
Mar 20, 2010 | Dishwashers
I turn the dishwasher on normal wash and never stop washing i let it run for 2 hours and stiil running
Your dish washer probably has a "turbidity sensor". This is an infrared sensor that checks the condition of the water and adjusts your wash cycle accordingly. There is probably build up on the sensor (especially if you have hard water) and this is causing it to run so long. The easiest fix for this is to run a cleaning cycle on the dishwasher. Start your empty dish washer on a heavy wash cycle and wait for it to start filling with water. As soon as it starts to fill, open the door and pour 1/2 gallon of white vinegar into the bottom of the unit. Close the door and let it run its cycle. At the end of the cycle, run a second cycle and see if things improved. If things still are not better, you may have a bad sensor. If you have more questions, write me back. Hope this helps!
Dec 16, 2009 | Dryers
Dish feels hot but not drying
sounds like your heating element is not working prtoperly or you are not washing in very hot water stop washer in middle of cycle and open it if steam come out hot steam be careful keep face away when you open itif not hot that could be the problem,A appliance serviceman once told me if water is hot enough and end of wash and rinse cycle not to run the dry cyvcle just open dryer a few inches and let the steam out Run hot water over a plate or a pot and set it in the drain tray in your sink notice how fast it dries itself while draining in the tray very hot water in a dish washer dopes the same good luck with this problem I hope my advice helps you oh yes one more thing always run the hot water till it get hot before you turn your dishwasher on
Dec 15, 2009 | Kenmore Dishwashers
Jenn air dishwasher- making loud noise in operating cycle
Hi I am Vortash by the sound of what you are descibing your pump bearings seem to be shot , although it is making this sound is it still washing properly if so it confirms it is the bearing and not the impeller catching and making the noise the pump gets to quite a high pressure to wash the dishes .. sort of an enclosed hot jet wash the force of which drives the spray arms .. so I am afraid it looks like you will soon need a replacement pump.. sorry to bare bad news .. Regards Vortash
May 22, 2009 | Roper 24 in. RUD4000M Built-in Dishwasher
Problems Keeping the cycle going
On the back of the selector switch there is a timer motor or clock motor assembly. The gears wear out or the motor has lost its ability to go through the cycles. Replace it and you should be fine.
Jan 16, 2009 | Dishwashers
Water won't drain, Soap Door open with soap still there and stops running at Plate Warmer cycle
Reset the washer manually. Close the machine, and slowly advance the timer till you here the fill valve start. Then let it do it's thing
Jul 21, 2008 | GE Nautilus 24" Built-in Dishwasher
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
